For error (or not) the projector was blocked for some students on the classroom; we power with remote control, and afetr ligth ask for some password, and then he lock and power off. Thank you for help
SOURCE: dvd10 optoma projector makes a loud noise
Hi, I'm not sure if it's the same problem I had..
I had it on picture mute, for maybe 15 mins, which may not have been a good idea. While it was muted, it made a sparking sound, and then a very loud grinding noise. When turned off, the lound noise stops, and the fan continues as usual for about a minute. As soon as it's turned back on, the grinding noise is back. But the logo seemed to display ok.
I took it in for repairs, and they said they needed to replace the color wheel to fix the problem.
optoma dv10 mode
SOURCE: EP716 Optoma Projector Fuse
There is no fuse. I took my EP 716 apart to find out why it died. I found a resistor had blown on the power board made by the Tiwan co. Quazarpower.
SOURCE: Optoma projector overheat issue - fan comes on but switches off
Most projectors have air filters. Yours may need to be removed and cleaned. No air flow = overheat.
SOURCE: I Have an optoma projector ep721 I plugged all the
Source input not geting signal,check with other input
SOURCE: Help needed for Optoma EP 719 DLP PROJECTOR
It's a setting in the menu. A few minutes poking around will fix it.
