Question about Acer Computers & Internet
My emachine DVD drawer won't open (even with the paperclip)
My computer is out of warranty, so I'm OK with opening the box if I have to--but are there any other tricks to try before I do that?
    President:
  • 1,257 Answers
Click on the link below to fix the issue:
http://www.windowsguru.org
Posted on Jul 02, 2009
Cant open dvd drawer
Sometimes DVD player drawers get stuck closed because the disc inside isn't seated properly. At other times the player may have another problem. The first step in discovering if it is the disc or another issue is to remove the disc. Most DVD players have a secret eject button. It allows you to open the drawer when a disc gets stuck and cannot be ejected normally.
For this you'll need a standard size paperclip.
  1. Unfold the paperclip and make it as straight as possible.
  2. Look closely at your DVD player . Push the tip the paper clip into the small hole on the tray cover on the front of the Toshiba. The hole is on the right side of the cover.
  3. Press inward gently with the paperclip until you feel a slight resistance, then continue pushing to engage the internal eject button. The tray should pop open partway.
  4. Gently pull the drawer until it's fully retracted. Be careful not to pull too far.
  5. Remove your disc from the drive.
  6. Before you reinsert another disc, use the remote and/or buttons on the player to close the door, and reopen it. You can also press carefully with your fingers. If you cannot open/close the drawer normally at this point, do not put in a new disc until you have repaired the problem.
What You Need
Dec 09, 2013 | Toshiba SD Computers & Internet
Have EMachine tower door will not open to install DVD
You can use a paperclip to open it.
On the front of the DVD you'll see a little pinhole; unrwist a paperclip and push the leg of the paperclip into that hole; it will manually push open the DVD tray
Nov 07, 2013 | HP Compaq Presario SR1650NX...
Dvd drive won't open on emachine el1333-21f
use a open paperclip and push it into small hole on the front of the drive its a manual release
Nov 16, 2012 | eMachines Desktop / AMD Athlon Processor /...
Brand new ASUS desktop DVD/CD R-W drive won't open.
hold the faceplate open, get a paper clip. There is a small hole in the front of the DVD/CD drive, place the paperclip in it and push slowly until the device drawer opens.
Jan 21, 2012 | ASUS Essentio Desktop with Intel Pentium...
The dvd drawer won't open. it is "stuck" closed.
Hello
A stuck drawer indicates a jammed mechanism or the presence of a mechanical drawer lock.
Locate your DVD player's manual Eject button. It is usually a small hole located underneath the DVD drawer.
Insert a stiff wire-such as a paperclip or safety pin-into the hole. Push gently and the drawer should open partway. Gently pull the drawer the rest of the way open.
Nov 23, 2010 | Denon DVM-1805 DVD Player
you can try opening it with paperclip if it's stuck. Straighten the clip and locate a small pinhole on the drive it and insert the clip in. You might need to push the paperclip in an out a few times to eject the drawer.
Jun 19, 2010 | Computers & Internet
Cd drawer
there is usually a small hole right around the button to open the tray. use a paperclip or something like that and put it in the hole and it should open
Apr 12, 2010 | HP Pavilion dv9000z Notebook
DISC DRAWER WILL NOT OPEN
First, start with power cycling the player. Turn off the player and disconnect the power cord from the wall socket. Leave it unplug for about 5 minutes. Turn the player back on and try to open the drawer.
If same problem occur, then follow the steps below:
1. Turn off your DVD player. You do not want to risk electrical shock while working with it.
2. Locate your DVD player's manual Eject button. It is usually a small hole located underneath the DVD drawer.
3. Insert a stiff wire-such as a paperclip or safety pin-into the hole. Push gently and the drawer should open partway. Gently pull the drawer the rest of the way open.
4. Remove the DVD and see if there is a problem with it. Most DVD player drawers get stuck when a DVD is warped or the label is starting to peel. If the DVD is warped, discard it. If the label is peeling, remove the label.
5. Turn your DVD player back on. If it gets stuck again on a different DVD, then the problem may be with your DVD player rather than with your DVDs.
Mar 21, 2010 | Panasonic DMR-ES10 DVD Recorder
My cd draw is stuck in the cd drive. How do i get it open
you should find a paperclip and straighten it out, on the front of the CD drive there will be a small hole just big enough for the straightened paperclip to fit in. Push it in until you feel tension and it should start to manually open.
Sep 12, 2009 | Dell Inspiron 6400 Notebook
DVD Drawer won't open-- paperclip method isn't working
Unplug it. You'll have to open the cover. Then you may have to remove the tray assembly from the frame. On the bottom you will be able to access the belt. If you're luck, it might be in another location on top or off to the side.
Apr 25, 2008 | GoVideo VR2940 DVD Recorder/VCR
Computers & Internet Logo
87 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
