Print is faint
HI,
I share a informative links please visit and read it... http://www.dymo.com/CountrySelectorView?locale=enUS and
Support and Techsupport Printer
Thanks,
SOURCE: won't print
Here is the Dymo site for this issue:
https://global.dymo.com/enUS/RNW/RNW.html?pg=std_alp.php?p_li=&p_accessibility=0&p_page=1&p_cv=&p_pv=2.22&p_prods=21%2C22&p_cats=&p_hidden_prods=&prod_lvl1=21&prod_lvl2=22&p_search_text=&p_new_search=1&p_search_type=answers.search_nl
Type "light print" into the search box and the first result is the link you are looking for.
Here is the text of the link:
Poor Print Quality from Electronic Labelmaker
Question
I have an electronic labelmaker that is printing poorly. The print on the label is either very light, incomplete, or striped. How can I resolve this?
Answer
Proceed with the solutions listed below if you have an electronic labelmaker. If you have a LabelWriter printer that is printing poorly, click here.
Solution 1:
Replace the existing batteries with a new/fresh set of alkaline batteries. The print
head requires a significant amount of battery power to ensure proper
printing on the label. Light print on the label may be an indication
that the batteries need to be replaced.
Solution 2:
Replace the existing tape cassette with a new tape cassette. Light printing may be an indication of bad label stock.
Solution 3:
Using
the special brush supplied with your labelmaker (located on the inside
cover of the cassette compartment) or a cotton swab with a soft solvent
(e.g. rubbing alcohol), carefully clean the transporter roller and print head. Dust, dirt, or glue may accumulate on the rubber transport roller or print head inside the cassette compartment and adversely affect print quality.
If the solutions listed above do not resolve the problem, please contact DYMO Technical Support to obtain a Return Material Authorization (RMA) Number.
Obtaining a Return Material Authorization (RMA) Number:
-hope this helps.
SOURCE: Faint Printing
TRY PUTTING NEW BATTERIES IN THE DEVICE AND THE LETTING WILL GET DARKER SO YOU CAN SEE IT
ROD
SOURCE: how do you print vertical labels?
Here is the link to your users manual, which will help explain other functions you may find useful.
http://global.dymo.com/enGB/Manuals/LetraTAG_QX50.html
Hope this helps...
Gods Bless.......
SOURCE: I have a Dymo Letratag XR and it is only printing
change the batteries! there is no ink, this problem is nearly always flat batteries...
SOURCE: i have a dymo letratag
Dymo LetraTAGs are thermal printers, so they don't use ink - Change the batteries and it will fix the problem.
