Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Agitator cant be removed from base to get to clutch dog
I've been trying for an hour and searching online. I cant get to the cluth dogs. It wont budge is there a trick. Does the assembly that hold the dog screwed in or something.... please please help!
  • 1 more comment
  • tkemmler Jul 02, 2009
    I got the bolt off, I took the agitator placed it on the floor, stood on it, sprayed wd40 and tried to pull the heck on it. I cant remove the upper part from the base to get to the clutch dogs
    OMG!! That was it! I got a flat screw driver, saw the little holes that the manufacture filled with a hard plastic to fuse it together, used a hammer and punched the holes to remove the hardend melted plastic. Walah! The assembly went flying though hope I can put it back together.
    OMG!! That was it. After looking more closely I saw there was a white melted plastic covering where the 4 holes said it would be.. around the area where the nut would go. I got a hammer and flat screw driver and punched out the holes to remove the plastic that was fusing it together. I big pull and walah! It flew apart. Now I hope I can get it back together. Thank you! I called a tech earlier to detach the 2 pieces and said he would charge me $75 to take it apart. Thanks again.
    President:
  • 1,136 Answers
Hi, There is a 7/16" bolt that hold the agitator in. Remove the top cap on the agitator and the cap inside it to get to the bolt. Once you get the bolt out, pull the agitator out and seperate the two pieces.
I hope this help you. Please let me know if I can assist you further.
Vic
Posted on Jul 02, 2009
  • Victor
    Victor Jul 02, 2009
    Sometimes you need to use a flat blade screw driver and punch the 4 tabs around the bolt hole so they will release the two pieces.
  • Victor
    Victor Jul 02, 2009
    You are welcome. Let me know if I can assist you further.
    Please feel free to rate me responses to you so that others as well as myself will know how I am doing.
    Vic
How to remove dog clutch coupling from marine 351 cleveland
have you checked for set screws ???
a puller comes to mind
and some PB Blaster
Sep 07, 2014 | 1988 Ford Falcon
What's the cause of my washer's agitation and noise problem?
Possibly a bad basket drive. Or something is wrapped around the shaft under the tub or something is in the pump.
Aug 30, 2012 | Washing Machines
The machine will not agitate, but will spin dry and drain. Kenmore model 110.
When the agaitator doesn't work yet it spins/drains it is usually the agitator dogs that are worn out.
This tip i wrote about the dogs expalins in detail what to check and how to replace the dogs.
http://www.fixya.com/support/r10294924-top_part_agatator_isnt_turning_top_load
GENE
Aug 31, 2011 | Kenmore Washing Machines
Whirlpool model# LSN7233 top part of agitator does not turn
Hello Tim,
The problem with it is the part in the top of agitator called agitator dogs are wore out and slipping. Its pretty easy to fix and inexpensive for the part thats needed as well. This youtube video will show you step by step how to relace the "dogs" http://www.youtube.com/watch?v=0GQh8JLqVv8
the part number in the title of the video is exactly what you need, it could be purchased at your local appliance parts store or online at
searspartsdirect.com
repairclinic.com
assueredparts,com
apdepot.com
appliancepartspros.com
I hope my answer has helped you to resolve the trouble with your washer,
Gene
Aug 05, 2011 | Washing Machines
Agitator will move while empty, but when you put a load of clothes in it will not move...
Sounds like the (agitating dogs) are worn out. These are little arms with grippers at the end that grab the agitator . It spins free one way but the grippers grab the base of the agitator and spins it the other way. This is how you get the agitating motion. You can buy these at a repair shop for about $5. The cap at the top of the agitator will need to be taken off, just unscrew it. once it'a off you can see at the bottom a bolt that will need to be removed, once it is removed you can the pull the whole assembly out. The agitating dogs will be at the base of the shaft. These are made of a plastic/resin and wear out due to being old or overloading. There are diagrams on the net to show you exactly what they look like, search (agitating dogs.
Sep 09, 2010 | Kenmore 24902 Top Load Washer
The agitator seems to be stripped out - I need info on how to disassemble the agitator
Te newest ones are the easiest, a square hole can be unscrewed after removing the splash guard and belch dispenser.top Older models have a nut to remove. You must use an extension and socket for that. I have a nice video i found online: HERE
After I get the agitator out I set it on the floor and hold it down with my feet, I grab the top and yank it apart. I remove the old worn out agitation dogs and replace them with part number 80040 around $5 here. Line it all up and snap it back together without breaking the plastic locking tabs on the base of the agitator. While putting back the agitator take care not to make it come apart. This sounds hard but it is not. Anyone can do it.
Jan 15, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
I have an LSR7233EZ0 and the Agitator slips when you run heavy loads in the machine. Where is the best place to start clutch or gears?
"Where is the best place to start clutch or gears?" Answer= Neither.
Prescott,
What you have is a failed set of agitator dogs. Don't ask me why they call them dogs. I really don't know. Maybe it's because they "clamp" on to a relatively flat surface and the friction of the grip provides the "cam" action... kinda like "plate dogs" in iron work. But I'm speculating.)
Easy and cheap repair. The part number you'll need is 80040 (<--- plug that number into a search engine or call your local appliance parts place). What you'll need is a 7/16"socket, an 8" extension, a ratchet, and (possibly) an 8' pair of needle-nose pliers.
Pull the top off of the agitator. If yours has the "flat top", just pry it off with a knife. Then you'll see a mostly opaque cap down there... remove that (<--- just pull it out). Now use your socket and ratchet and extension and remove the bolt that's exposed down there.
Now lift the agitator up and out of the basket. Place the agitator on the ground and put your feet on the wide part, the base. Then lift up on the "screw"/agitator ... this will separate the two sections. Now pull the cam out and you'll see the dogs (<---the ones that need replacing). Remove them and install the new ones. There ya go!
All that's left now is to rebuild it in the reverse order and you're done.
If you have any questions, just write. If this solved your problem then show some FixYa love and rate it as Fixed!
SG
Jul 04, 2009 | Whirlpool LSR7333 Top Load Washer
Agitator and base won't separate.
I had the same problem yesterday, the tech online said that if you look closely there are 4 little thin rectangle holes... it may not look like holes since the manufacture fuses it with hard melted plastic to keep you from yanking it off. I used a flat edge screwdriver and pounded it in with a hammer (like using a chisel). Punch th 4 holes so the plastic seperates from the dog assembly. Place on floor, stand on it and pull straight up!
Jun 30, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
How to remove the agitator on a Kenmore 70 series
Set the agitator down and hold with your feet. Grab the top part and pull up sharply. It will come off. some are harder than others.
May 18, 2009 | Kenmore Washing Machines
Removing clutch assembly from agitator
easy bud, take the top off the agitator then you will see a cover. pop that off and you will se a bolt. remove and take off the middle prt of agitator and you can get to the dogs
Feb 16, 2009 | Whirlpool Washing Machines
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
135 people viewed this question
Dan Webster
Dan Webster
Sal De
