Question about Refrigerators
I have this ice maker and after 6 months I had to call for a repairman and they fixed it and then came back and told me to shut it down and not to eat any of the ice because it was contaminated but they won't tell me with what. Please tell me if any one has had any problems similar to these.
  • 10,865 Answers
Whenever the icemaker is worked on, the water in the tube feeding the icemaker has the potential of picking up a little rust or other debris from the fittings that are opened up.
To fully put your mind at east just toss out the first two batches of ice, tand the first six cups of water to assure that both your ice and your water are clean and fresh.
Posted on Jul 02, 2009
Ice maker is slow to make ice. It dumps sometimes. it builds a large mountain of forzen ice that mounds up under the tray. even though we remove it it always comes back. ice is also runnig down the...
Ice maker problems are almost always a problem. Sometimes I will locate an issue and fix it and then it will work for a short period and then break again. So, now I just replace the ice maker as a general rule. This is much more likely for success. However, the replacement ice maker is often not an exact match. And again, the this and the that sometimes causes problems. I will never accept a new customer on the grounds that I am going to fix their home ice maker. Make sure the ice machine is getter water like it is supposed to. Check the filter and the tubes. If the problem persists, get a new ice maker. If that ice maker angers you, get some ice cube trays.
Jun 11, 2011 | LG LSC26905TT Side by Side Refrigerator
Ice maker does not make ice
when my ice maker went out in an older model the first thing i checked was to see if water was getting to the ice maker. then i was told by a repairman to manually turn the ice maker's teeth. i had to take the cover off to see the knob. i don't know which way your's is supposed to turn. be real careful. i have an old kelvinator,but that did it. repairman also said it is good to keep the maker making ice by using the ice up. hope you get it going again
Nov 05, 2010 | KitchenAid KSCS25FKSS Side by Side...
The ice maker is not working
There is a way of testing the ice maker.
Diagnostics for ice maker starts on page 27
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 01, 2010 | Samsung RF265AA Bottom Freezer French Door...
Melting ice in icemaker. Repairman out twice and says he fixed it and yet my ice continues to melt and drips inside the freezer.
One of my most disliked things in life is to have a repairman go into the home and make repeat visits. Then when they have the gall to say it is fixed and they are back for a 3rd time.... (need I say more!?!!
Melting ice in the icemaker only means that the mold heater element for initially loosening the ice cubes from the tray in the icemaker is not shutting off or the bi-metal thermostat in the icemaker is bad.
The ice maker test procedures are here:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=12&newsdesk_id=34
I would print that out and hand it to the repairman the next time he walks through the door. Simply state "This may help you compete the job right." and leave it at that.
The sad news it it could take replacement of the ice maker to rid yourself of the melting ice saga.
Hopefully he can use the printout and then get the necessary parts to get you back in business real soon.
Thanks for using Fixya!
Feb 06, 2010 | GE Profile PSW26P Stainless Steel Side by...
Musty smell/taste from water dispenser in refridgerator
The icemaker has mold or mildew in the little nooks and crannies. An appliance parts supplier might have something available for flushing but I am not sure. There might be something in the ice bin or on the auger contaminating the ice and water as well. Check back to the source as the water supply filter may have accumulated something unpleasant while the ice maker was down. Hope this input helps.
Dec 30, 2017 | Hotpoint HTM17BBSSA Top Freezer...
Ice maker has ice in lower back part of ice maker, rotation stopd
you say ice in back of ice maker??? only the rear 2-3 cubes are filled??? adn the front 5 or so are empty??? then yes its possible low water pressure from a faulty filter can be an issue, shoudl be replaced at least every year. so you cant go wrong by changing it , at least rule it out!
Nov 22, 2008 | Frigidaire FRS26R4A Side by Side...
Ice maker is leaking into the tray where the ice is dispensed causing the ice to become embedded into the tray
there is a screw in the ice maker unit that can adjust the water level open the ice maker whit cover and you should see it but turn it gently little by little each time...and see how much you getting :) very EZ good luck
Jun 06, 2008 | GE PDS22SIS Bottom Freezer Refrigerator
Kenmore Refrigerator stopped dispensing water
Look up through the ice despencer on the front door of the freezer. Is the flapper door open? If so it needs to be fixed. If its not then try leaving the freezer door open for 3+ hours to defrost the frozen line in the door. If that doesnt work, the water valve must be changed.(located behind fridge, take off back cord board panel at bottom, the valve is blue)... GOODLUCK!
Dec 31, 2007 | Refrigerators
Another Ice Maker Problem
i suspect that repair man got it wrong. ice may be blocking return duct to fridge. worth a chance to turn off for 24 hours with doors open then retry
Jun 14, 2007 | LG LSC26905TT Side by Side Refrigerator
Refrigerators Logo
48 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
