Question about Samsung RF265AA Bottom Freezer French Door Refrigerator
Same as other, white foam piece and sensor fell out of position
How does the foam piece and sensor "lock" into place? I am wondering if a small tab of some sort ay have broen off?
Also, is there an easy way to remove the drawer? Are the rollers similiar to a desk drawer?
Thanks in advance.
  • Samsung Master
  • 4,655 Answers
Check your model number. The number RF265AA is listed as an oven. If listed correct or if a refrigerator then I can help you, Sea Breeze
SITE=> http://servicepartstec.blogspot.com/
Posted on Jul 02, 2009
Changed battery .A square piece of metal the size of match head fell out. No alarm or light, casio forester FT200
mcdevito75 here, Of couse without the watch and piece of metal that fell out it"s very hard to say. Most likely it was part of the lock-down tab to keep the battery in place, in any event don"t lose that piece of metal. If your casio is working ok don"t worry about it, just don"t lose that piece of metal that fell out.
Jul 05, 2010 | Casio Forester PAS400B-5V Wrist Watch
A rubber piece fellout and there is a white wire hanging out.
This just happened to me.
The waxy piece has a clear plastic bracket, if its not connected, look around your freezer. The waxy piece fits inside the bracket, and attaches to the ice maker, just in front of the ice tray.
The white wire fits inside the waxy piece. It is the thermostat that tells the ice tray when to dump the ice.
This is impossible to feel around for, so you will need to remove at least the bottom freezer compartment as well as the ledge piece from just inside the freezer door. If you are a relatively thin/small person, you can extend the top tray fully outward, and slide underneath. Looking up at the ice maker, the plastic bracket should have a little prong. This prong will attach just behind the ice maker, with the thermostat facing the ice tray.
Mar 02, 2010 | Samsung RF265AA Bottom Freezer French Door...
No power up test when turned on after cleaning of the brewer; I suspect brewer out of sync. Spent 30 minutes greasing & cleaning to get everything in proper mode but still no good. Water does not seems...
hey just manually pull down brew group internals till neutral reached push waste flap in to lock position seen on rear tab and leave brew group unit and water tray / waste bucket out, place a small magent / metal on bottom rear left of inside panel ( check waste unit for small metal tab and align magnet on rear where this sits, at the same time then place small magnet where door tab hits plastic sensor in machine roof then power off and on machine resets to neutral remove magnets insert brew group and waste trays and u should be done. WARNING !! DO NOT ATTEMPT WITH BREW GROUP IN PLACE KEEP RESETTING MACHINE IF YOU FAIL AS IT SETS A FAULT AND WILL ENDLESSLY SPIN DRIVE
Jan 17, 2010 | Saeco Talea Giro Espresso Machine
My camera is telling me the card is locked. It
Remove the memory card from the camera if it isn't already, and look along the left edge of the card. Find a small tab and slide it forward (to the unlock position) and carefully slip the card back into the camera and try again. If it reports locked again, carefully remove the card to see if the tab has moved back to the locked position.
If the tab is moving to the locked position during the insertion process, you could place a small amount of tape along the card edge - over the tab - and carefully insert the card again. You might have to remove some tape to allow the card to fit into to slot. If you never lock the card - you could put a very small drop of super glue on the tab to hold it in place. Wait for the glue to set completely before inserting into the camera.
I hope this helps!
Nov 10, 2009 | Cameras
Wires hanging in ice maker area
Look underneath the 2nd row from left in the ice tray there should be a white plastic piece that pops in and out from the bottom of the ice tray. Pop it off. There should be a piece of styrofoam on top of the piece you removed. the white wire runs along the bottom of the ice tray there may be little plastic hooks to place wire along the way. The sensor should fit right where the white piece of plastic and styrofoam you removed goes. Just place it there and pop that piece back in. It really doesn't attach to anything just lays there.
May 26, 2009 | LG LSC26905TT Side by Side Refrigerator
A part fell out of the ice maker - makes 'soft' ice???
It goes on the bottom of the ice tray and snaps in that is the sencor that tells when the ice is frozen
Mar 28, 2009 | Samsung RF265AA Bottom Freezer French Door...
The memory card is locked and I cant figure out how to unlock it...the camera wont take pictures and cant even erase the pictures
remove the memory card and look on the side of it their should be a little tab move it to the other possion and try the camera again. if that does not work with the card out gently tap the camera on the card side. and reinsert it their is a sensor that tells the camera their is a card inserted in it. it might be stuck. hope this helps.
Apr 24, 2008 | Cameras
Canon d660 imageclass copier
Hello himsmyboy!
Sikna says
The ADF separation pad is the cause. To remove it lift the cover fully up then use a knife to get under the black tape tab at the top right of the large white foam pad. Pull the tape and the white foam pad loose but not completely - leave the bottom attached. Now you can see the ADF separation pad from below. Use a small screwdriver or spring hook to remove the spring and you will be able to wiggle the ADF separation pad out. First take a good look at how it fits in so you can put it back! The problem is caused by the small black foam pad under the white rubbery tape on the ADF pad assembly. I carefully removed the tape from the back edge to expose the compressed black foam pad. I then cut a matching size of 1/16" foam I had in my shop which was actually HP 98A doctor blade seal foam and just stuck it on top of the old compressed foam. (other similar foam should also work) Then I replaced the white rubbery tape and rubbed the edge down well. I then reinstalled the restored ADF pad and the spring which holds it. Last I just pressed the large white foam pad back into position - being sure to pull it with a slight tension as I pressed into place. This fixed the ADF feed and it worked like new again...
Sikna out...
Jan 15, 2008 | Ricoh Aficio SP-C210SF Printer
Samsung RF265AA Bottom Freezer French Door Refrigerator Logo
420 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
