Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
Lost Manuel From goin back an forth from the Canadian Tire store. My manuel for my salt water pump was misplaced. I don't know where to find out how much salt to put in or how much salt not to put in. Its very discouraging. My pool is having Algie build up now. Please help me.
My cs8110 salt water ststem pool filter has green on the ions .Lost manuel, how do you clean the pump ?
Posted on Aug 15, 2011
  • 297 Answers
What size is your pool I could let you know how many pounds should be in there.
Most likely it would be easier to test your salt content. You need a 12 dollar test kit that has 10 tests in it. It is very simple just put an inch of pool water in a cup and let the test strip sit in it for about 5-7 minutes. Then read the results. Compare with the bottle #'s if too high then drain some water and add fresh if too low then add salt. ( your ppm should be as close to 3000 as possible) Keep in mind algae is due to lack of chlorine or improper ph and alkalinity not salt content. How often do you run your salt system? at 80degrees I run my salt about 4-6 hours a night and then switch it over too just filtering for 8 or more hours.
Also keep in mind that for a pool to be truely filtered it should be turned over at least 3 times so if you have a 5000 gallon pool and only a 2000gph pump it should filter for 7-8 hours. If you have any specific questions feel free to contact me
Posted on Jul 02, 2009
I lost the manuel and my set up disc to my hp psc 2175 x1 all in one printer, in the moving it got misplaced,and could be found later, I don't know, I just know I have a printer and cannot use it....
Look in teh Drivers and Software section on the HP website for that printer and you should be able to download both the User manual and the Installation disc and drivers. www.hp.com
Jul 16, 2011 | HP PSC 2175 All-In-One InkJet Printer
I lost my manuel and don't know how to record a
Select the model of your phone from the list beginning at
http://www.uniden.com/owners-manuals/dect-phones/scat/dectphones_mnl/
Jul 09, 2011 | Uniden DECT 6.0 Cordless Phone
I thought I needed a new fuel filter because my Honda motorcycle was running choppy. After realizing it wasn't the filter at all, I was told at the parts store to clean the carberater. I've never done this...
Before you try to tackle a manuel cleaning of the carb, try this. Purchase a can of SeaFoam and add it to the fuel in your tank. Setting on the bike, lock down the fromt brake and rock the bike back and forth to mix the fuel and the additive. put at least a hundred miles on the bike with this mixture. If it hasn't improved, then consider the manuel cleaning of the carb, If it has improved, continue riding with the SeaFoam/fuel mixture. I use 1/4 can of SeaFoam every time I fuel, and don't have any problems with gummed carbs.
Apr 13, 2011 | Honda XL 125 R Motorcycles
Water is running out of the water pump on our 95
Haynes manuels - most auto parts stores sell this manuel or the chilton manuel
Dec 05, 2009 | 1995 Nissan Pathfinder
Water pump replacement ineed apicture of how brackets go back on
your best bet is to obtain an exploded view from a Manuel at your local arts store they often will allow you to return the Manuel as well otherwise find a similar vehicle and take a picture of the way they fit
Oct 13, 2009 | Ford E-Series Cars & Trucks
I lost my manuel & don't know how much salt I am supposed to have in it. My pool is an Intex 16 X 48.
I checked the manual.
For an Easy Set you need 110 lbs of salt
For the Metal Frame you need 125 lbs of salt
If you go online to the IntexCorp website, you can download an additional manual for free, takes a while to do but that way you'll have all the info in case you have any more problems.
Good Luck!
Jun 15, 2009 | Intex Automatic Salt Water System for ...
Instruction Manuel needed
Hi and welcome to FixYa!
You can get it here for free:
http://fisherpaykelparts.net/partmanuals/dd603guide.pdf
The "H" means you have the salt dispenser system...
Jan 28, 2009 | Fisher and Paykel 24 in. DD603H W Built-in...
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
247 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
