Question about Intel D865GBF Motherboard
Pc stuck in start up loop
Pc will not boot up, loops back to start up screen . no safe mode, no restore, no command prompt. cannot boot with xp cd, error msg, will not boot from cd, code 4....checked Ram and reseated. set bios to default, tried everything i could think of....help...windows xp pro os.nothing hooked up except keyboard and mouse.
  • 3 more comments
  • fpl42 Jul 02, 2009
    when i try to boot with cd, error says cannot boot with disk ,code 4.....when i select f8 the options come up but will not go into safe mode or any of the other options, just goes back to black and white start up screen again.
    F8 works and screen shows up, but when safe mode is selected or restore or any of the other options, it goes thru the motions as if it is loading but just goes back to the previous start up screen. when start normally is selected it does the same thing, dont know any other way to explain it.
    oh, it has two memory modules
    can get to blue screen...Stop, 0x0000007E (0xc0000005, 0x000040D8, 0xF890F54C, 0F890F248) are the error codes.
  • NinaE May 11, 2010
    What error message when you boot with the CD ? What happens when you select F8 repeatedly to try to go into Safe Mode ??? Do you have multiple memory modules or one ??
Ram and Power supply are the main cause of your problem with this motherboard by replacing these one at the time could fix it
Posted on Jul 08, 2009
Medion problems
Hi
Run a chkdsk from the command prompt, once you have done this see if you can get on in safe mode and then restore it to a time before the update attempted to install
Cliff C
Aug 23, 2014 | Medion Computers & Internet
How do I stop my laptop from reboot loop?
Just insert a windows CD and repair your OS. Your problem will be solved while preserving all your files and folders! Good luck
Jun 14, 2013 | Acer Aspire 7520-5185 Laptop
My ASus eee pc is in a constant loop. It starts up with start windows in safe mode safe mode with command prompt or start windows normally... After I select start windows normally it's in a loop and starts...
Ok-Go to Safe Mode-any-click on start menu-run:msconfig-hit enter-click on restore option-choose date-go! If you can't do that, on boot you machine should tell you what other option you have-like"push ESC button to aces setup" or something like that. Hit that button and go to RESTORE function.Good luck and Happy Holidays!
Dec 27, 2010 | ASUS Eee PC 901 XP Notebook
XP won't boot up.screen shows safe mode
The operating system files got corrupted.You can try repair the windows using operating system cd.
Siju
Oct 26, 2009 | IBM ThinkPad T60 Notebook
I have a HP a0310n desktop. I is rebooting in a
Well you can try in safe mode with command prompt and than
To start System Restore using the Command prompt, follow these steps:
  1. Restart your computer, and then press and hold F8 during the initial startup to start your computer in safe mode with a Command prompt.
  2. Use the arrow keys to select the Safe mode with a Command prompt option.
  3. If you are prompted to select an operating system, use the arrow keys to select the appropriate operating system for your computer, and then press ENTER.
  4. Log on as an administrator or with an account that has administrator credentials.
  5. At the command prompt, type %systemroot%\system32\restore\rstrui.exe, and then press ENTER.
  6. Follow the instructions that appear on the screen to restore your computer to a functional state.
See if that works
Jul 31, 2009 | HP Pavilion a1310n PC Desktop
Acer aspire one stuck on windows safe mode restart loop? I turned on my acer aspire one and it is stuck in some loop? It continuely looks like windows is about to start than ends up going back to black...
You have a corrupt Windows system configuration/registry. Someone else chime in if there is hope, but my only solution (given it won't start up in safe mode) is to wipe and reinstall.
Jul 15, 2009 | Acer Aspire One AOA150-1635 Notebook
Stuck during installation of xp
Your HARD DRIVE is likely bad, or your CD is scratched, or your ram is bad, or your CDROM is bad - or some combination of this
May 21, 2009 | Compaq Evo D300 PC Desktop
Windows xp stuck in restart loop
Needle in the tower? Wow! Who told you that? Geek Squad.
OK in all seriousness this is what I want you to do.
Press F8 as the computer boots up.
Choose "Safe Mode with Command Prompt"
Let me know if you're able to get that far and then we'll proceed from there.
Feb 24, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
My compaq Presario V6000 will not start windows, it continously loops to an options screen with the following start options; Safe mode, safe made with networking, Safe mode prompt command,Windows last...
what you are describing is the blue screen of death, meaning theres a hardware or software problem, try to boot into safe mode and perform a system restore, if that doesn't work use your XP cd, let it load the drivers and the ask it to fix the existing XP installation, anything that you have saved in my documents should be safe and the problem should be solved. If the blue screen reappears then you have a hardware problem
Nov 13, 2008 | Compaq Computers & Internet
Intel D865GBF Motherboard Logo
396 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
