My computer doesnt work
Hi i have an sis amd sempron chip set and it has worked for a while but all of a sudden it started to go into blue screen all the time but i think its because of the hot weather i am having but i havent used my computer for a couple of days and i went to turn it on this morning and it cam on for literaley 1 millisecond then i reset the checksum and it did it again so i remove an extra molex cable that i made my self using diy andit did it again after i repaired a wire that came out of the joint on it and it did it again so i completley removed it from the computer and plugged it in outside the case and it worked fine then i put it back together and all of a sudden i had nothing going to the monitor and i tried removing the graphic card and using the on board graphics but it still didnt work and i know it isnt the ram because i have them on my brothers computer right now which im using and i heve removed everything including the board and psu and plugged a monitor into it and the psu into the board and it still wont work and i can not get it to work what so ever so please help!!!
  • ashley hunter Jul 02, 2009
    yes the computer powers up fine as if there is nothing rong but there is just nothing going to the monitor i have it switched on right now but its not giving th monitor anything
  • 180 Answers
Have you checked the power supply. Try to connect another power sypply.
Posted on Jul 02, 2009
AMD Sempron, with sis 964 chip, the monitor gets no signal when the computer is turned on, any suggestions how to get a signal
remove the bettery frome the mother board for 10 minuts, and make sure the main power cable is unplugged, the try again....or your RAM might be broken,,,,
May 11, 2010 | HP dx2250 Monitor Personal computer AMD...
I recently purchased a new battery for my acer Aspire 3050 and was told that it wont work if my laptop was dual core.I'm not sure what that means, is my 3050 dual core
you are in luck the answer is no its not dual core
Acer Aspire™ 3050 (LX.AV10J.037) PC Notebook The Aspire single core™ 3050 from Acer® provides performance, flexibility and value in a compact system. Featuring an AMD Sempron™ processor, wired and wireless connectivity and a stunning 14.1” WXGA display, this notebook brings productivity and entertainment to a new level.Please rate my help++++Thanks for using FIXYA
Nov 30, 2009 | Acer Aspire 3050-1733 Notebook
Sound problem in pc of amd sempron 3200tm
dear if you install the new operting system then install vga and sound card driver then it is solved...if still unsolved then contact me
Aug 21, 2009 | AMD Sempron 3100+ 1.8GHz 256k Socket 754...
I have problem with my xp os in amd to intel
You can fix it by installing XP on the intel computer. Don't clone unless the hardware configuration is exactly the same. Wipe the hard drive and start over.
Jun 30, 2009 | AMD Sempron 64 LE-1200, 2.1 GHz...
Cpu
If functioning correctly, your motherboard will support the following types and speeds of CPU's
  • Supported Processors:
  • AMD Athlon XP/Sempron/Duron
  • Socket A processors
  • 200/266/333 MHz FSB
So likely it tops out at Athlon XP3000+ /333MHz
or
Sempron 3000+ socketA/462.
May 31, 2009 | SIS741GX-MN Motherboard
Blue screen on start-up. Mobo SIS-741 Chipset SIS741GX Rev 03
This problem can be caused by several things. First, are the memory chips exactly identical (brand, type, size, etc.)? If not, that will definitely cause the problem. Second, how many memory slots are there? If you have four, check the manual and make sure you're putting the memory in the correct slots. Some Mobo's require that you put chips in slots A1 and B1 and not A1 and A2. Also, some Mobo's have DDR slots and DDR2 slots, so make sure you're putting the right kind of memory into the proper slots. Some people fudge the memory by putting 400 mhz memory into slower slots, and that works one chip at a time - but if you install a second, identical chip, the system will fail. If all else fails and you've met these conditions, check the type of memory to be sure of the proper fit (use manufacturer's recommended brands and numbers) or try a different chip in the second slot. One chip could be bad.
May 25, 2009 | SIS741GX-MN Motherboard
DRIVER PROBLEMS
you have to install the chipset driver using your driver cd...
is this cleared your problem?
Feb 19, 2009 | AMD Sempron 3100+ 1.8GHz 256k Socket 754...
How do i restore factory settings?
if you have a dell when you start your computer and the screen with the blue line at the top press control f11 will take you to the system recovery. but if you dont have a dell i dont know
Sep 09, 2008 | Linare Desktop, AMD Sempron 2200,40 GB HDD...
Open Questions:
Can I hold DHHS accountable for the burden they put upon me? If not, is there someone that can be held accountable? What can I logically and honestly do to remedy this prob. I explained my prob below! I was getting QMB part of Mainecare and my spouse at the time we were dating but living together was getting the QI part of Mainecare. We are both disabled and only get SSDI. However being honest and do our best to always do the right thing we go to DHHS office on Griffin RD in Bangor, ME within a month of us getting married where the worker we saw tells us we don't qualify for anything but the min of FS and both Q1 part of Mainecare and serious voice tells us to divorce. I have made a few trips within last months to same DHHS. One sends us to Eastern Area of Aging to see if there were secondaries we can get. This past Monday hubby and I went to our appt with Eastern Area of Aging & was told they strongly believe I could get spousal exclusion also warning it could mean my hubby loses help but because it was a volunteer a newer one at that she couldn't tell me definitely cause she didn't know the formula as she still learning; tells us to go back to DHHS to ask about spousal exclusion. So I go back to DHHS this past Thurs and got a worker with more smarts, heart with approx 10 yrs working for DHHS tells me I qualify for spousal exclusion and took the time to answer all my questions. I told her I had QMB till hubby and I married June 2016 & shared with her what the DHHS worker told us when hubby and I went in to show marriage certificate to update the change. She looked at me with shocked eyes and dropped jaw in bewilderment. Then says I would of never lost it as I would of qualified for spousal exclusion from the day we married. And had it been her that we got when we were being honest wouldn't have only told me about spousal exclusion but would of applied me as she could see I have major medical problems that is too much a financial burden for my hubby and I. She also told me I was to submit all unpaid bills even if monthly making payments were being made. I thought I was only to submit bills I paid in full or on a payment plan. So started Thurs night on a Medical Bills Tracker to go through all the medical bills and sort things out. I haven't even put a dent in the pile and see I'm responsible for just over 6K I'm predicting once done I could be closer, if not over, 10K. In collections is currently 1K but once done with pile amount in collections could be closer to 2K or more. So the mess has impacted my credit and if things were done by professionals I wouldn't be losing my hair stressing over my medical bills and how it declines my credit. I know I'm in a small group that actually pay their medical bills any and all bills to be honest! I am disabled and get SSDI. Worked 1992-2013 a lot of times working 2 jobs! Dr in 2013 practically dragged me out of work as was just diagnosed with Hep C, CKD Stage 3 & liver disease! I also have depression disorder, panic attacks, anxiety disorder! So even this incompetent DHHS worker putting extra financial burden on me unnecessarily affects those things. I am trying to do the right thing but get kicked down by the very people that are paid to help me. What are my rights and can I fix this at a faster pace then not even fixed it by the day I die?
Jun 23, 2018 | Major Computers & Internet
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
