Question about Kenmore Elite 45986 Front Load Washer
Front washer is torn. need replacement information
  • 15,935 Answers
A lot of concerns have been raised about door bellows molding, mildewing, and/or ripping and needing replaced. A replacement bellow isn’t cheap (prices vary, but are around $75-80), so hopefully these helpful steps will eliminate the need to call a repair service and pay the additional labor charges. This is a repair of MODERATE difficulty. Just follow these steps:
1. Unplug the washer.
2. Remove the washer top panel by removing the three torx-type screws (or 7mm) where it attaches in the rear of the washer. The panel should slide back, and then lift off.
3. Remove the operator console by removing the dispenser and the scew(s) behind it. Take a putty knife and insert it under the console seam right above the door. If you push in slightly while pulling outwards the panel pops off. Use care not to pull or damage any of the wiring. You can leave the wires attached and simply lay the console across the top of the washer out of the way.
4. Locate the wire hoop retainer around the rubber door boot. It is located behind the rubber seam where it attaches to the door frame. Follow this hoop around to the bottom of the door opening and locate the wire tension spring. Gently pry this spring apart and pull the wire hoop from the groove. Pull the rubber boot from the frame and push it inside towards the wash tub. You will also have to remove the door boot from the fill tube on the left hand side of the door opening. There is a small wire clamp holding it in place.
5. Remove the three screws that hold the door latch assembly in place. This is on the right hand side of the door opening. You can leave the latch in place as long as you remove the screws and push it inside slightly to remove it from the front casing of the washer.
6. Remove the door by removing the screws holding the hinges in place. Use care to support the door hinges when loosening. They can bend. Set the door aside in a location where it will not get stepped on or broken.
7. Remove the lower kick panel under the door. There are 3 screws under the bottom edge holding it in place. Sometimes the panel can stick. A slight tap on either side will knock it free.
8. Remove the front washer casing by removing the four remaining screws that are holding it in place. There should be two at the top and two at the bottom. Set the front casing aside.
9. Remove the old door boot by locating the large clamp that attaches it to the wash tub. Loosen the 7mm nut and the boot will detach from the tub. Also remove the boot from the fill tube coming from the dispenser.
10. Install new door boot on the wash tub and install clamp. There should be instructions that come with the door boot with guide marks to ensure you align it correctly. Once you have the boot in place, tighten the clamp enough to where it is snug. DO NOT over-tighten or you may damage the tub and or clamp. In most cases the clamp will break.
11. Once you have the boot in place, re-install everything in the reverse order of how I explained to disassemble. Make sure you connect the door latch assembly BEFORE you re-install the outer portion of the door boot. Also, make sure you install the boot completely over the fill tube. There should be a ridge on the tube where to stop. Sometimes the tube is not inserted all way into the boot and water will leak behind it. The clamp is always difficult to get back in place. If you cannot get the clamp to go back over the tube, you can live without it. Some newer models do not have them installed. Just make sure it is a snug fit where the rubber boot fits ALL the way back to the plastic ridge on the tube.
12. When you get the point where you are ready to install the door boot back over the frame of the door opening ensure you fit it snugly all the way around the door. Beginning at the top of the door, start inserting the wire hoop back into the groove. Make sure to wire spring points towards the bottom. As you work your way around the door to the 4 and 8 o'clock positions, you will need to maintain some constant downward pressure while pulling the spring apart in order to snap it back into place. It would be advisable to use a second set of hands to hold the wire hoop in place while doing this as it has the tendency to want to come out of the groove.
13. Once the door boot is back in place, re-install the operator console and washer top.
14. At the operator console, select DRAIN SPIN, NO SPIN and press any button under OPTIONS 4 times (has to be the same button, though). This will place the washer in diagnostics mode. You should hear the door latch lock and "C00" will be displayed on the console. The washer will run through a series of tests filling the tub, tumbling, draining, and then a final spin. If you do not wish to wait for the test to complete you can press CANCEL at any time. The test checks out everything and takes about 15 minutes. Look for any leaks.
Step 6--Removing the door. After you remove the three screws in Step 5, there is only one screw to remove in step 6 on my model. It was hidden behind a plastic cover that makes the hinge look pretty. You'll see on the inside of the door that two plastic prongs/tabs extend into holes in the hinge. If you push on them laterally and pull out, the tabs will pop out. Outside the door on the left side of the machine, you'll see the plastic cover that is connected to those plastic tabs and is hiding the hinge. On the outside cover piece, there is a flat tab that extends up into the plastic housing above it. If you gently pull the cover downward and out the whole plastic cover will come off revealing the one screw that needs to be removed to take the door off.
Step 7--Removing the Kick Panel. The middle screw is more difficult to reach than the sides. You may need an extension for your screwdriver and/or shims or a helper to prop up the washer while you remove the middle screw.
Step 8--Removing the washer casing. The step says to remove the screws and set the casing aside. My model (2005-ish) has wires connected to it. Rather than being able to remove it, it swings open like a door with the wires as the hinge. I simply used a box to prop up the outside part of the door so it did not sag and stress the wires.
Step 9--After you remove the old rubber bellow, you will likely see a lot of dirt, mold, and junk where the bellow was. Clean that stuff off with a cloth sprayed with a gentle cleanser before installing the new bellow. We replaced our bellow because of mold and mildew and bad smelling stuff. That dirt and junk is part of the problem. Clean it up before you install the new clean bellow.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 11, 2010
Torn door gasket / collar
It requires technical expertise and speccial tools. Part isn't expensive, labor may be depending upon where you live
May 05, 2010 | LG WD-14124RD Front Load Washer / Dryer
The washing machine is leaking from the bottom starting at the wash mode
To accurately determine the source of your washer leak, you will need to remove the lower toe panel an inspect the washer interior cabinet. The following link explains how to access and inspect a front loader for leaks:
http://www.fixya.com/support/r3576656-washer_leak__front_loader
In the majority of cases, a front loader leak is caused by a ripped or torn door bellow. If your bellow is damaged, it must be replaced. The following link explains how:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
Replacement parts (if required) can be found at the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The average cost varies, so shop and compare. The first three websites I listed also have helpful exploded view parts diagrams that can help you locate and properly identify the parts you need.
If you have any questions, please post back with your MODEL NUMBER. I hope you fid this information helpful.
Mar 27, 2010 | Kenmore Elite 45986 Front Load Washer
Clothes are getting torn in the washer. How do
check the fins in the washer,and run your hand in the washer make sure there is nothing caught in the basket
Feb 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
The boot seal/tub seal is torn and I want to replace this piece
door boot or baffle as it is sometimes called can be replaced. however it is not an easy job as there is a large spring that hold it on.
Oct 04, 2009 | Kenmore Elite 45986 Front Load Washer
Torn seaL ON KENMORE ELITE WASHER
i have a kenmore elite washer the red lite is lit on controlles locked how do i solve this
Mar 22, 2009 | Kenmore Elite 45986 Front Load Washer
Torn bellow on Maytag front load washer
there is a spring style clamp holding it to the front panel simply peel back slightly and "pop" it off, then holding it to the inner tub is a screw style clamp, depending on yr of production, either a 5/32 scrwe or a phillips, holding it in the 2 oclock position, release clamp andreinstall boot, it might take some time to get to fit backaround hte tub but itll bo, you gotta walk it on in spots ( like changing a tireon the bikes as a kid) itlll strectch over the rim and fit, just have to work it
Dec 03, 2008 | Maytag EPIC MFW9700S Front Load Washer
Front Loader Kenmore Mod # 110.44832202 is leaking.
The rubber seal is known as a bellow. If the bellow is torn, more than likely it IS the cause of your leak. Your only course of action is the replace it. Searspartsdirect.com carries replacements. Just type in your model (as you provided) and look under the "Door and Latch Parts" heading for item number 1 (part #8182119). It is not a cheap part, but it will cost you much more to have an appliance repair company install it for you. This is not a difficult repair, and you can accomplish this on your own if you follow these steps:
http://www.fixya.com/support/r385210-replacing_door_bellow_kenmore_elite
Some additional parts that normally do not need replaced, but you may consider just in case are the front and back clamps that hold the bellow in place. They are listed under the same heading as items 6 and 14. They don't cost that much and may consider them just in case you need them. In particular, the front clamp, can break or the spring becomes stretched. Inspect these items just to be sure.
I hope you find this information helpful. If you require additional assistance, please let me know.
PS You may also try repairclinic.com for comparative pricing. They also carry the same parts (sometimes for less).
Sep 12, 2008 | Kenmore Elite 45986 Front Load Washer
Torn Door Boot
the way to replace it is you undo seal from front which might be a thin spring clamp behind the lip of the door seal it will be metal undo your lid look down the front of your washer to see the inside of the back of your door seal it will either be another bigger spring clamp or a screw clamp undo door seal will pullout replace backwards to how youve undone m8
Aug 13, 2007 | GE WBVH6240F Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
Sal De
fordexpert
Whirlpool
Whirlpool
