That's an older 10 SEER unit. They are not made any more. The lowest SEER made, to date, is 12.
However, that being said, a 10 SEER, 3-ton unit such as the one you have, it is ONLY going to be as energy efficient as it is equally maintained.
To ensure you are achieving absolute BEST energy efficiency, I would strongly encourage you to take the following steps:
1. Unplug your unit, disconnecting the electrical service from the unit.
2. Remove the filters from the front of the unit.
3. In a typical quart spray bottle, add 4 packets of UNSWEETENED Lemon KOOL-AID, fill 1/2 full with water, screw top onto bottle, shake well for 30 seconds, remove top and add water to near the top, screw top onto bottle and shake again to mix it very well.
4. Spray the INDOOR COILS with the above KOOL-AID solution until all of the solution has been used. The CITRUS Acid in the KOOL-AID will penetrate the coils and not only remove unwanted dirt, dust and debris; but it will also clean the bi-metal portions of that coil, making it SHINE.
5. Let the KOOL-AID set on those coils for a MINIMUM of 30 minutes.
6. While the KOOL-AID is doing its job, take the filters that were removed and rinse them under a faucet, ensuring the water is flowing from the back to the front of the filters in order to dislodge and remove as much debris as possible. It is acceptable to now spray the filters with either a solution of 50% water and 50% hydrogen peroxide OR simply spray with any household disinfectant/cleaner such as Lysol or Mr. Clean or similar product. Bump the filters against your hand to remove any additional water or household spray.
7. After at least 30 minutes, take that same spray bottle and fill it with clear water. Spray those coils once more with clear water to flush what ever may have been left within those tiny coils.
8. Add 1 drop of light weight oil to the fan motor and bearing.
9. Re-install the front cover of the unit; and then reinstall the filters.
10. Plug into an electrical outlet.
11. Turn the unit to the COOLING Mode and HI Speed Fan Mode.
Enjoy continued usage of your A/C unit.
This should be performed at least once each year in order achieve the highest EFFICIENCY of your system.
SOURCE: what is the SEER rating on Goodman Air Handler model a32-05c?
Slightly more than 10 seer . Depending on the outside unit. A30 are 10 seer. Rusty
SOURCE: what is the seer rating and tonnage of a bryant
The Tonnage appears to be 2 1/2 ton,
024=24,000 BTU=2ton
030=30,000 BTU=2 1/2ton
036=36,000 BTU= 3ton
I dont think you have the correct Model Number, Look
on the outdoor unit, the model number might start with a 38. Hint Carrier and Bryant Products are the Same, just different nametag
SOURCE: I HAVE A GOODMAN MODEL CKL36-1D I'M TRYING TO FIND
Yours is a 3 ton unit with a SEER 10 rating.
Air conditioner is made by International Confort Products Corp in Lewisburg, TN. It was purchased for a condo in 2003 or 2004. It seems to be very inefficient but that
That's only a guess. We just purchased a condo so we have no history. I would like to know the seer number so I can decide whether to replace it or not. Model number is NAC036AKA5.
Here is an image of the outside tag.
