My Whirlpool duet washer/dryer is just 2 years old and the dryer is taking FOREVER to dry a load of...
(More)
My Whirlpool duet washer/dryer is just 2 years old and the dryer is taking FOREVER to dry a load of clothes. I have checked all the lint traps. Could it simply be an element even if there is still heat?
Duet Dryer control panel will not respond or turn on, tech said I need a new dial because the old...
(More)
Duet Dryer control panel will not respond or turn on, tech said I need a new dial because the old one is slipping. He said the dryer is acting funny because the dial is slipping and it is getting stuck in between cycles. I put new dial on dryer and now the control panel will not turn on. How do I get the panel to respond or reset it?
My GEW9250 will dry in auto mode for the first load then won't fully dry on subsequent loads.. I...
(More)
My GEW9250 will dry in auto mode for the first load then won't fully dry on subsequent loads.. I performed moisture sensor diagnostics referred to in Whirlpool Job Aid (Part No. 8178071). I must wet my finger to get the beep, dry finger won't get the beep. How sensitive is this sensor? Should I consider this a sensor failure?
Our whirlpool duet dryer randomly beeps displaying the 'CONTROL LOCK' light and will not reset by...
(More)
Our whirlpool duet dryer randomly beeps displaying the 'CONTROL LOCK' light and will not reset by holding the button. We unplug it and leave it for extended periods and struggle to get it to eventually run. Today it began beeping on it is own (had not been run for a day) and then locked itself. After unplugging and pressing a series of buttons half of the display lights were on. Repeatedly unplugging and resetting finally enabled the machine. What is wrong with this machine?
