Question about Saeco Odea Go
I have a saeco odea and two red lights remain on even after descaling the dregdrawer and descale lights
Descaled it twice no improvement cleaned dregdrawer and sensors that I can see
    Habit-Forming:
  • Saeco Expert
  • 151 Answers
The red light for descaling you can turn off when press and hold the steam/hot water button for 5-6 seconds.
Posted on Sep 13, 2014
    New Friend:
  • 4 Answers
Descaling Problem SOLVED!
Folks, I really hope this helps a lot of you. I too encountered the dreaded descaling problem where it gets stuck in a loop and never finishes. I thought the machine was toast and see so many reviews that people experienced this and had to return the machine.
I tore apart the machine and figured out the issue and the super simple fix!
What happens is the water level sensor does not know it is running out so when the tank empties due to running dry, it never completes the cycle.
Where the water basin goes, if you look at the back lower down, you will see a small rectangular protrusion. This is the water level sensor that works by measuring capacitance. You know how sometimes your machine runs completely out of water and you have to prime it with the tea/hot water button? This is why! When you put the tank in full, water splashes over the edge and down the back. It coats the outside rear of the tank and the sensor with water so the machine thinks it still has an adequate level of water but then all of a sudden runs dry.
The FIX:
Take a paper towel and dry off the water level sensor and the back of the tank. When you put the tank in, do not fill it too high and put it in gently to avoid water spilling out.
Simple as that...fixed!
Posted on Jun 02, 2015
SOURCE:
  • 81 Answers
SOURCE: I Have descaled my Saeco Odea Go but still it doesnt brew coffee
That is serious, that means the grinder is jammed or not working. To check the components of the machine follow these instructions.
Press and hold the steam button and turn on the machine, when you see the lights going around in anticlockwise direction, release the button. Turn the coffee dial to the left and press the steam button, the grinder should turn. Dial on the right and pressing coffee ****. water pump runs. Press steam ****. brew group go up, dial 1/4 to left B/Group down.
If grinder not turning the motor is bad. Hope it will help to find out.
Posted on Mar 28, 2010
Coffee pup
  • 3 Answers
SOURCE: How to descale machine
you can download and print a manual for your Saeco here
ttp://www.manualnguide.com/download/manual-guide/saeco-odea-go-instruction-manual.html
Posted on Dec 12, 2007
  • 74 Answers
SOURCE: Saeco Odea Giro descaling problem
Ok first check if the machine is in greenlight state when you press and hold the water button, as it will not work when the red exclamation mark blinking.
also check if the button work at all flipping back and forth to hot water and steam.
I have never had this problem that it dident work.
But remember this, you dont have to do the descaling again as that has nothing to do with the reset.
You can even reset the descaling alarm with out having done the descaling.
If that for some reason wouldent work I would think its the CPU card is not working.
Posted on Jul 14, 2008
SkinWill
  • 148 Answers
SOURCE: Red alarm flashing
The flashing indicator light means something needs to be refilled or emptied.
Posted on Oct 15, 2008
  • 1089 Answers
SOURCE: Saeco Magic Comfort plus: Despite descaling the
Hi
In the menu there is a program below the descaling program that says Reset descale. Enter this program and choose "yes", and make sure that you push the enter button to lock your answer. If you don't it will still be there.
Also go to your water hardness and move it to the #4. This will prevent you from having to replace the boiler sooner than needed. Descale when told to by the machine.
Posted on Jan 09, 2010
Testimonial: "Fast, correct and thorough. The cryptic Manual was less than clear but your instructions were excellent. thank you"
How to open the saeco odea
After descaling and rinsing, you need to hold the hot water button for 6 seconds to reset the descaling indicator.
Mar 26, 2013 | Saeco Odea Giro Plus Coffee Maker
Flashing dregdrawer and descaling lights
Descale in the water tank...press nd hold water button and the mechine will do the rest automatically u jst hv to turn on or of the water knop...drawer take it out and take out the brewing unit put them back again thats it.
Aug 19, 2012 | Saeco Odea Giro Plus Coffee Maker
The coffee grounds lihgt and the descale light flash after I push the brew button on my seaco odea giro.
Same problem here. I've googled and see that there are many people with the same problem but no clues about how to solve it:
My Saeco Odea Giro is flashing two lights alternatelly (Dregdrawer Light and Descaling Light). What's the problem and how can I solve it?
Aug 10, 2010 | Saeco Odea Giro Espresso Maker -...
Flashing Red bulb
That is the descale light, you should run a descale through the machine. After you have done that hold on the water button and the descale light will go away
Jun 26, 2010 | Saeco Odea Go
Red light is on (looks like an M) and I don't know why??
It means time to descale , however if you want to get rid of it, just press and hold the water button until it goes off.
To descale..fill the container with descaler and let water goes through the system by openning the valve and catch the descaler with a container. Turn off the machine a few minutes and start the process all over again for 1/2 hr, and finally with water to wash the system.(donot want to heat up the descaler too much)
May 27, 2010 | Saeco Odea Giro Plus Coffee Maker
I have descaled it twice and the red light is still there
You have to press the hot water button for 10
seconds to disable the descaling
alarm.
The steam button on the left.
Feb 02, 2010 | Saeco Odea Go
I have descaled my Saeco Odea and the coffee beans light and the descaling light keep on flashing from one to the other
Hi, Try holding down the steam button for 10 seconds. It should reset the descale warning lamp.
Hope it helps.
Andrew
Dec 06, 2009 | Saeco Odea Go
My Saeco Giro keeps flashing red, what's wrong?
Hold the water button in for about 15 seconds.
Mar 30, 2009 | Saeco Odea Giro Plus Coffee Maker
Saeco odeo giro and the red squiggly light
This is the descaling indicator.
If it flashing your machine needs descaling.
Feb 22, 2009 | Saeco Vienna De Luxe Espresso Machine
Jul 14, 2008 | Saeco Magic De Luxe Espresso Machine
Saeco Odea Go Logo
686 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Pierre Laplante
Ray Murphy
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
