Question about Lincoln Welding Tools
T140 Lincoln mig The wire feed starts and stop
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 3 Answers
How often does it start and stop? Are there minutes in between or milliseconds? If there are minutes then it's just getting hot and needs to cool down before starting again. If it's milliseconds then your guides probably aren't tight enough. Let me know if you can be any more specific and we can get to the bottom of it.
Posted on Jul 02, 2009
I have a Lincoln power mig 216 and as soon as you strike an arc on metal my feed wire either kinks or breaks at the feed rollers and starts rolling out the side I have replaced the tip, liner and diffuser
Are there any kinks in the feed line from the spool to the tip that is causing the wire to not feed? Cut a length of wire and pull it though the feed line to see if there is a lot of friction in it, that would prevent wire feed. Finally, check the wire size - I know, but it is worth checking just in case.
Mar 04, 2015 | Lincoln Electric Lincoln Power MIG 216...
Porblem with lincoln mig welder 135
Use a voltage tester to make certain you have current at the steel roller assembly that the wire feeds through. Check the diameter of the wire also, to assure contact at the feed rollers.
Mar 18, 2012 | Lincoln Electric Welding Tools
I have a lincoln sp-175plus, when trying to weld it the arc just melts the wire and it balls up at the end. I also put a new contact tip in. As well sometimes the wire feed just stops. I then press...
Your drive tension is too light. There are rollers that the wire feeds through and they need to be tightened. They should push the wire through the gun but slip if you put the tip against a solid object and pull the trigger. If they do not slip, they will jam your gun. Give the tensioner another turn.
Jan 08, 2011 | Lincoln Electric LE 83180 Century...
I reloaded it with wire and now it wont stop feeding wire.I have a lincoln handy mig.Any help would be appreciated.
Is your trigger sticking or gummed up on your mig gun! Contacts may be loose also! Good luck!
May 29, 2010 | Welding Tools
Century mig welder. The wire speed is spinning at max speed as soon as the machine is turned ON. Will only stop when machine is OFF.
My Century 225 mig has lost its power ...with adjustments to max it leaves a high weld deposit and low penertration.
What is the fix ?
Aug 14, 2009 | Lincoln Electric LE 83180 Century...
Owners manual for a century wire feed 83160 mig welder
I believe century was bought by lincoln. call 1-866-236-0044 ext 3. Ask for century parts.
Paul
Apr 19, 2009 | Lincoln Electric LE 83180 Century...
Welding Tools Logo
93 people viewed this question
Top Lincoln Welding Tools Experts
Steve
Robert Monigold
Robert Monigold
Are you a Lincoln Welding Tool Expert? Answer questions, earn points and help others
