A/c problems i have a 2003 chevy tahoe and i replaced the compressor, dryer and orphis tube . during replacing parts i heard something like a door close and alittle bit of wind hit my hand from out of the hole that the dryer was screwed to , and when i got done putting everything together i charged the system and everything looked good , but the a/c in the front is not gettin cold but the back is gettin cool but not cold, and also the pipe between the dryer and orphis tube is gettin cold but but not the dryer its self.
  • 11,896 Answers
Check the filter.
Posted on Jul 02, 2009
I have a 2003 chevy tahoe Lt the air works in front and with back controls but heat is only working in the front it blows with back controls but puts out no heat what causes this?
Your climate system can only cool or heat but not both. The temperature has a big effect on this. The cooling needs the compressor.
Apr 02, 2015 | 2003 Chevrolet Tahoe
2003 Chevy Tahoe Rear air conditioning not working but front does
The problem is probably the blower motor relay/breaker. It is located under the hood, in a plastic cover with the rest of the relays. It is labeled either next to the relay or on the inside of the cover.
murf427
Aug 02, 2012 | 2003 Chevrolet Tahoe
What is 2003 Chevy Tahoe speakers in the front door? name? and size?
The door speakers on the Tahoe are roughly 6 3/4" and are made specifically for GM.
Any aftermarket 6 3/4" speaker will fit however if you're looking to replace them.
Apr 07, 2011 | 2003 Chevrolet Tahoe
2003 tahoe - started smelling something hot , heard loud noise, ac stopped working immediately - , any ideas where I should start to look , appreciate any/all feedback
Not sure how long this may happened to you, but check the serpentine belt to see if the compressor locked up and caused the belt to break. If the belt isn't broke, the bearings in the compressor may have come out causing the pulley to bust something inside the compressor. With it being a hot smell, It sounds like the compressor locked up.
Jul 10, 2010 | 2003 Chevrolet Tahoe
My AC compressor became weak ,is it true that it cannot be repaired if the AC system is serviced &must buy new one?
what do u mean by serviced ? most of the time you would not get that part "repaired " unless the prob is in the clutch , best to find a reman . and be sure to change dryer and orphis tube (most wil not warr the comp without changing these as well
Apr 28, 2010 | 1996 Mercury Grand Marquis
2003 Chevy Silverado 2500HD
check to see that your cooling fan is operating correctly
Jun 28, 2009 | 2003 Chevrolet Silverado 2500HD
2003 Tahoe (5.3). AC belt/tensioner/compressor (Chatters)
The compressor is bad. I have the same problem. Apparently none of the tahoe's compressors are worth a ****! im having to replace mine too. You have to change the compressor, the accumulator/dryer, orifice tube and flush the lines. If you look on ebay you can buy a complete kit to change it all for about 300 bucks. The dealership tells me that you need to change the fan clutch as well. They told me that the reason for the noises is the fan clutch isnt working properly and it lets the compressor get too hot causeing higher pressures in the compressor due to the heat. They called it liquid slugging I believe. Mine doesnt break the belt but when you give it very much gas it makes a squeal and then a grinding noise like your trying to put a standard transmission in gear with it running without pushing in the clutch. I asked if you could just change the fan clutch and they told me no its too late, you have to change the compressor and dryer/orifice tube.
Jun 08, 2009 | 2003 Chevrolet Tahoe
Heating & Cooling Logo
73 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
