Question about Toshiba Tecra A6 Notebook
Memory Install The Tecra says that it has two memory slots, and is upgradeable to 2gb RAM. The Main memory slot is behind the keyboard, but no manual says how to get to it, or if that slot is avaiable for bigger (1gb) memory. Any help please, Thanks Ian
  • 37 Answers
You can usually find manuals for gaining access to the Ram slots, but I have opened up a Tecra before. Though not exactly the same model. you have to remove the plastic strip along the top of the keyboard (under the screen). Most of these pop up with SLIGHT pressure from a screwdriver but be careful, it may have one or more screws in the bottom of the laptop. Turn it over and look for any deep holes that might have screws that screw into the plastic strip on the top. Once you have the strip off, you can usually see easily how to remove the keyboard.
Posted on Nov 09, 2007
How to replace RAM in Satellite M45-S165
You can click on any photo to enlarge it.
Step 3 photo shows the Memory Compartment.
Two ram memory (SO-DIMM) can be used. There are two ram memory slots.
1GB however, IS the largest amount for EACH slot.
Apr 14, 2012 | Toshiba Satellite M45-S165 Notebook
I can only find one DDR ram slot!! there is only one slot behind the panel on the bottom. where is the other slot located. I have the tecra m2v-s330. should i just take it apart to look for it...i have...
The 1st RAM slot is under the keyboard. This slot has a RAM module installed when you purchase the laptop. The 2nd RAM slot is on the bottom of the laptop.
For removal of keyboard and keyboard replacement check out this WEB site.
Apr 14, 2011 | Toshiba Tecra M2V-S330 Notebook
Can I upgrade my Ram on Gateway Desktop . I have 512mb, 2.0MHz. It's a good computer that I would upgrade for a project.
Number of Slots:4
Slot 1 Slot 2 Slot 3 Slot 4 Each memory slot can hold DDR2 PC2-5300, DDR2 PC2-6400 with a maximum of 1GB per slot.
Not to exceed manufacturer supported memory
Good Luck, and do rate the solution if got help
Dec 24, 2010 | Gateway GT5220 PC Desktop
I have a Dell Dimension 2400. I want to upgrade from 512mb of memory to 1GB. The manual says I have two memory connectors. Do I get the 1GB, or two 512mb to upgrade? Thank you for your response.
Yes, you can upgrade your system upto 2GB RAM, buy another 512MB RAM DDR 333Mhz and install it to empty slot of RAM, it will upgrade the RAM to 1 GB.
Hope it will help, if so do rate the solution
Good Luck
Dec 15, 2010 | Dell Dimension 2400 PC Desktop
I have a lap top Dell Precision M20 and replaced the old ram from the slot below the keyboard with 512 MB by a new with 1GB. It worked fine! Since I bought two times 1GB, I inserted also the second in the...
these different ram slots have different bus speed so they really don't work if you are using them both at once.
Please check your laptop's documentation about the speeds of these ram slots.
Dec 27, 2009 | Dell Precision M20 Notebook
Is it possible to install high desnsity memory RAM on a T42
The T42 can support up to 2 Gb of RAM.
The laptop comes with 512Mb of RAM under the keyboard and a spare memory slot on the bottom of the laptop.
To install 2Gb of RAM put 1Gb in the memory slot under the kerboard - need to remove the old RAM and put the other 1Gb in the memory on the bottom of the laptop
T42 Memory specs.
  • 64-bit Double Data Rate (DDR) non-parity SDRAM memory
  • PC2700 at 333MHz
  • Two 200 pin SO-DIMM memory slots, one slot is pre-populated with 256MB or 512MB, leaving one socket available
  • Supports up to two 1GB SDRAM SO DIMMs
  • Supports maximum memory up to 2GB
Sep 22, 2009 | IBM ThinkPad T42 Notebook
ECS GREEN556E Laptop Memory
the manual is here
pages 87 & 88 show how to install
it uses' ddr1 memory up to 2gb max total in the laptop
0MB on board, 2 SO-DIMM slots, up to 2GB
Support DDR 266/333MHz system memory
Feb 04, 2009 | EliteGroup ECS G556 Notebook
IBM ThinkPad T40 2GB Max RAM
The T40 has two ram slots, you can put a 1g chip in each totaling 2g. If the chip will remove, then it is changeable. Vista needs a minimum of 256 to run, so, when you change BOTH chips to equal 2g it will probably read 1.744g, or it may read the full 2g. If it only reads 1g, then the second slot under keyboard may have malfunctioned. It could also be that the 256 chip is bad and your really only running 512 now. With all that said, in order to achieve 2g, you will need to put a 1g chip in each slot.
Jul 08, 2008 | IBM ThinkPad T40 2373 Notebook
Computers & Internet Logo
120 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
