Speaker wire colors.on car cd player plraese
SOURCE: WIRING FOR PIONEER DEH 16 CAR STEREO
you need to find the Pioneer website, or something similer... google the DEH 1600 diagram. really you just need something that tells what the different wires represent by color. then find a wiring diagram for the make and model of your ride that cooresponds to your stereo set up... then just match up the wires and there you go... personally i suggest haveing one of the boys at Best buy throw a harness... it costs like 15 bucks or something. plus you know it will be done right, and you can take it back if its not and have it fixed... bottom line they will be liable for any problems... hope this helps.
SOURCE: pioneer deh-p3500 memory wire color
12V Battery, Memory/Constant wire Yellow
FYI:
12V Accessory Wire Red
Ground/Chassis Wire Black
Left Front Speaker, Positive (+) White
Left Front Speaker, Negative (-) White w/Black Stripe
Right Front Speaker, Positive (+) Grey
Right Front Speaker, Negative (-) Grey w/Black Stripe
Left Rear Speaker, Positive (+) Green
Left Rear Speaker, Negative (-) Green w/Black Stripe
Right Rear Speaker, Positive (+) Purple
Right Rear Speaker, Negative (-) Purple w/Black Stripe
Remote Out, Power Antenna Blue
Remote Out, Power Amplifier Blue w/White Stripe
SOURCE: what is the speaker wire color code for pioneer
Crutchfield has allot of information on Pioneer receivers. They also have a number you can call for support. The wiring diagram can be found here: PDF File
SOURCE: wiring diagram for pioneer deh-p41
Yellow for memory.
Red for power acc.
Black for ground.
Blue for remote turn on(amps and accessories).
Gray pair is for right front speakers, solid for positive,striped for negative.
White pair for Left front, again solid is pos, striped is neg.
Violet or purple for right rear, same with solid or striped.
Green pair for left rear, same solid/stripe configuration.
SOURCE: Need Wiring Diagram for a Pioneer MOSFET 50 Wx4
Found the manual on Crutchfield's site
The wiring diagram is on Page 25
1989 Dodge Dynasty Car Stereo Wire Color Codes
Car Radio Battery Constant 12v+ Wire: Red
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Black
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: Orange/White
Car Stereo Antenna Trigger Wire: Yellow
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 3 1/2′
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Green
Left Front Speaker Negative Wire (-): Green/Yellow
Right Front Speaker Positive Wire (+): Purple
Right Front Speaker Negative Wire (-): Purple/Yellow
Car Audio Rear Speakers Size: 6′ x 9′ Speakers
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Brown/Yellow
Right Rear Speaker Positive Wire (+): Blue/Red
Right Rear Speaker Negative Wire (-): Blue/White
