Question about HP Compaq Presario F500 F700 and G6000 Motherboard - 442875-001
Presario f700 no fan/lights = nothing at all. The charger works
Power switch = nothing at all. The charger works on test machine + light at charge port on object machine lights up. but when power button pressed we get all of no thing- no lights, no fan etc. Changed ram hdd made sure dvd is seated,with and w/o battery, installed, fan plugged in cmos batt. brand new. does anyone have a starting point?
compaq presario f700 1.9turion x2 1 gig ddr2 xp pro
  • 797 Answers
Sounds like the power converter. The power input and the battery are single voltage. The computer requires multiple voltages which are generated by a power converter. If you have installed this motherboard, ensure the connections to the power converter are correct.
Posted on Jul 26, 2009
Battery/charger
Charger go true a lot of power voltage regulators and in the end is not powerful inought to power loptop without battery, same capasity neaded to help maintain stable curent.
Feb 17, 2014 | HP Compaq Presario F500 F700 and G6000...
Laptop runs on battery and charges ok,but wont run just on the charger-hp f700
My compaq is power on for 2 second and off , how to fix is thank you
You need to print this out-on someone else's computer. Hope it works for you!
Remove the battery and charger/ac adapter/power cord from your Compaq Presario F700 laptop, press and hold the power button for 20 seconds to discharge any residual current inside the Compaq Presario F700 . This clears your RAM and is like a hardware reset. Replace the battery and charger/ac adapter/power cord and turn your Compaq Presario F700 laptop on.
Boot in "safe mode". As it starts up press F8, the computer ask you if you'd like to start in safe mode. Highlight "safe mode" and press enter. See if your laptop is booting up ok .
If your Compaq Presario F700 boots ok, do the following,
Try System Restore first,
Start Menu->All Programs->Accessories->System Tools->System Restore. Choose the most recent date before you the encountered problem. If it doesn't work, try the next date.
If System Restore does not fix it, as a last resort, you might need to fdisk, reformat your laptop hard disk clean and reinstall OS, that usually fixes all bugs. Before going that route, try following,
Uninstall unnecessary programs and applications.
Scan with a antivirus program
Scan with a spyware/malware program
DEFRAG C:
CHKDSK C:
Clean up and repair registry problems with registry repair software of your choice
If the problem persists, did you check if it could be your Compaq Presario F700 laptop power cord or power source problem? Defective or insufficient power supply might cause error messages that are misleading. Take the battery out and power on your laptop with the charger only. Make sure your Compaq Presario F700 power jack and charger plug tip are securely connected. Did you notice the power jack loose? You can find laptop power jack on ebay. Fixing and soldering the power jack requires professional skill though. The charger green/blue LED should be on. If not, replace the defective charger. Compaq Presario F700 laptop battery charger, especially its power cord/cable, lifespan is limited and does not last forever, consider buying a lifetime warranty charger online from company like www.topmic.com
Dec 29, 2012 | ASUS K52n-a1 Notebook
I have a Compaq Presario F500 When I press the power button all the lights light up for a few seconds then it shuts back off
remove the battery then try to plug the charger directly on your laptop without a battery.. to test if the battery is working properly. if not.. maybe your main board have a problem. just like athe compaq presario of my friend. also mainboard problem.
Jul 10, 2011 | HP Compaq Presario F500 F700 and G6000...
I have a compaq Persario F700. When I plug it in and press the power button, the power button lights up like it is turning on, but the screen remains blank. Then the power button light turns off, and...
I can't solve your problem, but can tell you what I did to my F761us which has same problem as you are, it happened 3 weeks ago(08/2010) after we bought it-- 2 years 4 months the shortest life we ever have over 30 years computer experiences.
I am pretty sure my HD, battery, RAM, fan... are all OK
--the fan is working (you can feel it from vent)
I could see my battery light is on whenever I took it out for a while then put back, and after a whille the light off (should be fully charged).
we bought expansion RAM card, so we have 3, I did test all of them in each ram slot.
I also switch my power suply between HP L2000 and the broken one. I notice the broken one didn't warm up the power adpter-quite cold. but the same power supply plug into L2000 it warmed up as normal. does it mean something ?
we spent around $10 to convert internal HD to external usb HD
and could be accessed by our another HP DV7. (unfortunately we formatted it as C : D: 2 partitions, that L2000 can't accept 2 partitions.)
indeed the touchpad comparing my oldest still working HP L2000 (over 6 years), my F700 was very hot before it broken.
I did diassemblle it and found one shorty hair in FAN, and very very minor dust.
Aug 10, 2010 | HP Compaq Presario F730US Notebook
Compact presario f700 laptop will not turn on. It
Was there any power outage in your area and was the laptop plugged in at that time, if so your Motherboard has been fried, your need a new Motherboard.
Jul 19, 2010 | HP Compaq Presario F500 F700 and G6000...
My compaq presario is not switching on.
Could be a number of things, related to the power supply. However if there are any lights on then it is likely to be a motherboard problem. Contact a local PC repair shop. I had a simiar problem and it was the on board video card. They should not charge to diagnose the problem. Mine cost £80 to fix at PCZone, Birchwood.
Feb 24, 2010 | HP Compaq Presario F500 F700 and G6000...
try to jump green and any black wire from the power supply...if the fan dont work..power supply is damage..need to change..
Jul 14, 2009 | HP Compaq Presario F500 F700 and G6000...
HP Compaq Presario F500 F700 and G6000 Motherboard - 442875-001  Logo
503 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
