Question about Dometic RM2652 Refrigerator
After having the recall done, I don't have any power to my fridge or range hood.
    Sergeant:
  • 163 Answers
They may both be on the same electrical circuit, check the circuit breakers in the breaker panel, one may be tripped.
Posted on Jul 02, 2009
When furance kicks onafter a while the furnace stops working the range hood and the refigerater. after a while its starts working again.
It is difficult trying to understand what you are trying to convey to me. If you live in an older house, this may be the problem. Your furance, refigerator and range hood may all be on the same circuit. Your furance should have a dedicated circuit, nothing else on it. The refigerator should be on a dedicated circuit also, the range hood can be on a circuit with other devices. To find out what is on a curcuit, go to the panel and find the circuit that powers the fridge, have someone watch to see when the light goes off in the fridge, that will be the fridge circuit. Now check and see if anything else is off, eg. if the range hood doesn't work, then it is on the same circuit. If the furance fan will not operate then it is also on the same circuit. Do the same thing with the furance circuit, turn if off at the panel and see what else does not work.
Remember, the furance and the refigerator need to each have their own dedicated circuit.
Feb 21, 2015 | 2002 Bounder 39r
Hood fan and light suddenly do not work. there is power to the unit. where can I get it serviced?
Unfortunately a service cal to have it repaired is often more expensive that replacing the unit yourself. All new units come with instructions and it is an easy item to take down and replace. Just make sure you turn the power off before do the work.
Most repair shops don't even attempt to repair the standard range hood, because troubleshooting time and then finding the right part can eat up more time than a replacement would be.
Sorry for the bad news, but you would be money ahead to replace versus repairing unless it is a very high end range hood.
Jun 14, 2011 | Microwave Ovens
Window regulators for power windows // was there a recall and if so who do I contact. Estimate cost
We have nothing to do with MFG or Dealer
automobile warrantees
You talk to a dealer about your car
recalls & warrantee work
If you have as I see, a 2000 vehicle ,
well it was out of warrantee years ago
I don't know why, but we get a few
warrantee questions every week on
ten year old cars
3or 4 years,35,000 miles your done,move on
Apr 26, 2011 | 2000 Kia Sportage
My truck has a loud ticking noise inside the dash and under the hood. The truck continues to loose battery power when sitting as well. The ticking continues even when I remove the keys
First, I would have a dealer run the Vin# for your truck for the Cruise Control recall. If the recall was not performed it needs to be done. Unfortunately after some of the earlier recalls were done, people had problems with the 4x4 controls and brake lights.
If you can identify the Cruise Control and there is an add-on fuse disconnect the fuse and see if the ticking goes away.
In your case I would spend a little time to save money and use your hands to find the ticking relay.
Your fuse block should be under the dash or behind a kick panel. You will see some oblong or square relays. Feel them and unplug the ones that are ticking. Keep track of their position.
Under the hood are some black power boxes filled with relays and fuses. Do the same "Feel" test on them. When you unplug the "problem" relay the ticking noise will stop. Then the problem area will not work and you can investigate the equipment on that branch. Be it power windows, wiper delay, A/C,
power seat, and so on.
If you have a Diesel your Glowplugs have a timer which is very loud and should stop in less than 90 seconds. It definitely pulls power. Do a "feel" test on it. Your glowplug wires will lead you to it.
Apr 22, 2010 | 2000 Ford F250 Super Duty Crew Cabs
My son has a 2001 Mercury Cougar and it has a slight hesitation problem when you ease on to the accelerator starting off and also at certain speeds (low rpm's). We changed the air filter, plugs and plug...
I assume the check engine light is not on. I suspect you may have a slight vacuum leak, especially if it idles a little rough. Check all under hood vacuum hoses for cracks and make sure they are all connected.I also highly recommend you replace the fuel filter if you have no done so.
Aug 03, 2009 | 2001 Mercury Cougar
Mitsubishi outlander cooling fans not operating
There is a Recall to replace your cooling fan module because of this concern.
Open your hood and look at the black box bolted to your radiator fan by the battery. If it does not have a green dot on it, you have not had the replacement fan module installed.
Contact your local dealer with your VIN handy to verify the recall has not been done and to schedule an appointment.
If the recall has been done, verify if you have power coming out of the module to the fans, as the fans do burn out eventually.... but rarely both at once.
May 16, 2009 | 2004 Mitsubishi Outlander
Venting hood to outside wall.
install ducting along with closing flap (so outside wind does not blow in) and power first !
Jan 25, 2009 | Jenn-Air JXT8142ADS Kitchen Hood
How to reset my Jenn-Air Jxt8836ADS kitchen hood?
According to Jenn-Air (Maytag) if you remove the power from the hood for 15 minutes it will reset the board. So depending on how long the power was out the outage would have done this. There is a good possibility that the outage ruined your board.
Oct 31, 2007 | Jenn-Air JXT8836ADS Kitchen Hood
Rangemaster cooker hood. model no.LEIHDC120SC/
hood should be connected to a fused spur outlet which you havent found. try removing the chimney and you may find it there. chimney only held by 2 screws at top usually.the fuse in the outlet sometimes goes when bulbs blow
May 31, 2007 | Rangemaster Broan 614804 BALLISTA 48IN...
Over the range microwave oven
The magnetron may not be cooling properly and the overheat is what is causing the shut down. The internal cooling fan will need to be checked for proper operation.
Jan 28, 2007 | LG 30" Over the Range Microwave Hood with...
Dometic RM2652 Refrigerator Logo
104 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
