Question about Polk Audio XRt12 XM Radio Receiver
Polk XRt12 no digital out. Analog out working normally.
    President:
  • 1,114 Answers
Check your settings. Default setting is analog. Go into setup/menu find audio settings and set to Digital or auto. hope this helps
Posted on Jul 02, 2009
  • mr_mike_21 Aug 25, 2010
    it doesnt show that option! i finally got a digital processor and now i find out my optical or coaxle never worked! cant be...
  • mr_mike_21 Sep 10, 2010
    any gura's out there that can help!
Analog on digital watch not working
when a watch has analog hands and has digital portion, 9 times out of 10 it will have 2 batteries inside. A lithium battery and a normal battery. It is possible one died before the other. Usually the lithium (digital portion) lasts longer. Have the battery changed.
Dec 06, 2013 | Watches
I have an mfc240c fax. i just changed to comcast and now i can only send and not receive. comcast says it's not their problem,and they don't work on fax machines. however, it was working just fine...
well, comcast is digital transmission whereas fax machines are analog. you can try to change the transmission mode/speed which sometimes helps. press "menu" "2" "0" "2", use your down/up arrows to change from "normal" to "basic", then press "menu" again to make setting take effect. press stop key once or twice to return to normal display. fax machines are only reliable on analog lines. so if problem persists, only option left is to have a dedicated analog line run for your fax.
hth and good luck,
razors
Sep 20, 2011 | Brother Office Equipment & Supplies
I am getting intermittent static from the tweeter in my polk audio RT3. What could this be?
You don't mention your electronics.
Is it on all audio sources or only certain ones? Have you swapped the speakers Left-to-Right to isolate the speaker from the signal chain as a cause?
If it's only an analog source doing it I would suspect a bad audio cable or a switch somewhere in the signal path. Typically, it might be a switch you rarely use, like a Tape Monitor. It's wise to occasionally (with power OFF) operate all manual controls throughput their ranges a number of times to wipe oxides from their contacts.
Mar 10, 2010 | Polk Audio RT3 Speaker
I think direct sunlight screwed up the LCD screen so I can't see or tune it. Where can I ship for repair?
You can contact the company that made the product and they can tell you where to take it
Mar 05, 2010 | Polk Audio XRt12 XM Radio Receiver
Digiatal input indicator keep flasing
The flashing digital input for DVD means its digtial input is either not connected or not transmiiting. If yoy still hear the DVD it is probably because you also have the analog cables attached. Is that right?
If you had both attached the receiver would opt for digital over analog but would default to analog if the digital signal was not there.
If you can connect the DVD's digital cable you will get actual 5.1 surround sound from DVD.
http://www.sherwoodusa.com/pdf/RD-6500(English).pdf
Apr 04, 2009 | Sherwood Audio Players & Recorders
No analog stations on my hdtv 37 inch, have no digal box just regular cable, regular cable works on normal tv
Try an antenna if you want to get analog over the air. I have a feeling that with the way the standards are changing, you will only be able to get digital channels. After February, the analog channels won't be around.
If you are using cable tv you need an HDTV box to get high def.
Jun 13, 2008 | RCA HD52W59 HDTV Projection Television
Green Plaid then Vertical Lines, Failure of hard controls, Analog Board?
You are absolutely correct, When anyone complains of vertical lines or bars, the next step is to see if it happens on only digital inputs ( digital board ) , only analog inputs ( analog board ) , or both ( DMD board ) .
Analog board can be purchased at www.partstore.com ,
Jun 04, 2008 | Samsung HLR5067WX 50" Rear Projection HDTV
Analog
Seeing the word "analog" on your screen means the monitor has recognized video input on the vga "analog" input connection.
Most computers output "analog" vga (15 pin) which must be converted to digital for a flat panel monitor to display the image.
Many LCDs now have both analog and digital inputs.
Mike
May 01, 2008 | ViewSonic VP191b 19" LCD Monitor
Viewsonic VA712b issuses
Digital-to-Analog Converter - DAC When referring to Audio, DAC is also short for Digital-to-Analog Converter and is the process of converting a digital signal into an audio signal.
Random Access Memory Digital-to-Analog Converter - RAMDAC Pronounced Random Access Memory Digital-to-Analog Converter, RAMDAC is the ... the digital data to an analog signal to be displayed on a computer monitor.
Good Luck, Please dont for get to Vote/Thank you.
Dec 19, 2007 | ViewSonic VA712B 17" Flat Panel LCD...
Surround sound help
A few questions... What components are involved? How are they connected? Can you hear sound from the speakers for any other input device i.e. radio, cd, vhs, etc.? I suspect that there is an issue with the way the system is connected. I have the Surround sound output from my DVD player connected to the digital surround sound input on my reciever. I'm using digital coax cable (looks like a "normal" RCA cable), not the optical fiber connection. I had to buy a special cable for the digital surround sound. A normal RCA cable would not work. I don't know why. If you're using a similar connection, that could be your issue. make sure that the output and inputs you're using are compatible. A digital surround sound connection (in or out) can't be connected to an analog connector (in or out). Remember, Digital to Digital with a Digital capable cable; Analog to Analog with an Analog capable cable. If this is not your issue, post back here with more info and we'll see what we can figure out.
Sep 05, 2007 | Zenith XBS344 System
Polk Audio XRt12 XM Radio Receiver Logo
101 people viewed this question
Top Polk Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
kdigby
kdigby
Level 1 Expert
Are you a Polk Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
