Question about Dell Inspiron 8500 Notebook
Inspiron 8500 won't boot - num lock and caps lock light up
I'm at wits end with my 8500. Basically, if I turn it off I won't be able to reboot it until about a day later. If I try to turn it on before that the num lock and caps lock lights will come on and stay solid for about 10 seconds, turn off and that's it - the computer never boots.
To boot it I HAVE to wait about a full 24 hours and try again; sometimes, waiting 24 hours won't even do it. In that case I take out the battery and disconnect the computer from the power supply. Then reconnect the computer to the power supply (without the battery) and voila! it boots.
Any ideas?
  • jlosquared Jul 02, 2009
    Thank you Dageezer (great screen name BTW!),
    I appreciate your recomendation but it did not fix the problem. Interestingly enough, the "B" DIMM slot does not work - if I insert a module into the slot the computer won't boot.
  • 3,940 Answers
Try reseating the Memory Modules. Try each module one at a time, see if the problem is Isolated to one module or the other. They may just need to be re-seated to ensure proper contact
Posted on Jul 02, 2009
  • IQUIT Jul 02, 2009
    OK, if you have a bad DIMM slot, then it is a motherboard replacement. On an 8500, I'd replace it before I'd repair one for that issue, not cost effective.
Dell inspiron will not boot
Try this:
tap F8 on boot and go to safe mode with networking. If you are unable to load the OS is seems as thou you have a corrupted OS and will have to reload it. I hope you have backed up your data and have a recovery disk.
Aug 17, 2012 | Dell Inspiron 1526 Laptop
My inspiron 1525 won't boot, the scroll light and caps lock blink
Remove 1 stick of ram and turn on, if no! take out the second one and put back the first, and power on, if okay you know the 1 stick is bad. Remove main battery and power on, "long shot" if no change chances are it is a motherboard issue.
Mar 10, 2012 | Dell Inspiron 1525 (dndppa1_3) Intel Core...
My laptop does no more boot up. As soon as i start , the caps lock and the scroll lock lights keep flashing continuously and the fan even does not run.
Well hellonihar, As far as your issue is concerned it seems to be some hardware issue. LED
Component
Error Condition
Blinking battery power LED
Battery
Insufficient charge on the battery
Blink: 1 - Caps Lock/Num Lock
CPU
CPU not functional
Blink: 2 - Caps Lock/Num Lock
BIOS
BIOS corruption failure
Blink: 3 - Caps Lock/Num Lock
Memory
Module error not functional
Blink: 4 - Caps Lock/Num Lock
Graphics
Graphics controller not functional
Blink: 5 - Caps Lock/Num Lock
System board
General system board failure
Blink: 6 - Caps Lock/Num Lock
BIOS
BIOS authentication failure
Apr 19, 2010 | HP Pavilion dv5-1000us Notebook PC
Keypad numbers are locked on, how do i unlock??
Boot to your Bios and look in advanced for num lock and disable.
or
go to run in the start menu.
typ: regedit.
Go to: HKEY_USERS\.Default\Control Panel\Keyboard
Then String value- InitialKeyboardIndicators right click click modify then choose a number below.
Explaination numbers.
0= Truns Off, Num Lock, Caps Lock, Scroll Lock
1= Turns On Caps Lock,
2= Turns ON Num Lock,
3= Turns On Caps Lock, and Num Lock
4= Turns ON Scroll Lock
5= Turns on Caps Lock, and Scroll Lock
6= Turns On Num Lock, and Scroll Lock
7= Turns On Caps Lock, Num Lock, and Scroll Lock
Hope this helps.
Feb 07, 2010 | Acer TravelMate 4230-6499 Notebook
HP DV6110us: 4 beeps, no boot
besides the beeps which indicate a motherboard timing issue. There should be LED blinking codes given on the front LEDs. I will include the blink codes below, but lets try to at least get the system up and running. First, I would like you to remove the RAM sticks from the laptop and just reseat one stick back in the machine. Try to boot with that one stick, if it does not, try the other alone. There have been issues when reseating the ram or re-installing it have temp. fixed the issue. If it does reboot, go to the HP support site, put in your model number of your laptop and download and install an updated BIOS. Below are the blink codes that may narrow down the problem.....
HP DV6000 LED Blink Codes
LED Component Error Condition
Blinking battery power LED Battery Insufficient charge on the battery
Blink: 1 - Caps Lock/Num Lock CPU CPU not functional
Blink: 2 - Caps Lock/Num Lock BIOS BIOS corruption failure
Blink: 3 - Caps Lock/Num Lock Memory Module error not functional
Blink: 4 - Caps Lock/Num Lock Graphics Graphics controller not functional
Blink: 5 - Caps Lock/Num Lock System board General system board failure
Blink: 6 - Caps Lock/Num Lock BIOS BIOS authentication failure
Oct 22, 2009 | HP Compaq Pavilion dv6110us Notebook
Computer wont turn on their is a lock with a letter (A) blinkiing
I use the same machine ... that light is for CAPs Lock which is on when it blinks.
I would suggest getting into the boot selection screen, by "tapping" del or F8 key while booting up & try getting into safe mode with networking & restoring teh machine to an earlier date.
Thanks
Fame !
Apr 28, 2009 | Dell Inspiron 8500 Notebook
Won't boot
was there any changes done to your system like upgrading anything
All your power seems to be on right
Dec 13, 2008 | Dell Inspiron 1525 Laptop Jet Black
I need to knkow how to reset the bios on a dell inspiron 4200 with windows xp home edition. sometimes it reconizes the hd sometimes not
  1. Boot up the computer into the setup
  2. Press 'ALT' and 'F' at the same time
  3. Turn 'NUM LOCK', 'SCROLL LOCK' and 'CAPS LOCK' on. (Make sure the lights on the keyboard are on.)
  4. Press 'ALT' and 'P' at the same time. The bios should now be reset to the factory settings.
Hope my info solves your problem.....
Thanx for using fixya....
Oct 04, 2008 | Computers & Internet
BOOTING PROBLEM DIAG PROBLEM
What os you running? it booting problem or diag problem? If you can access windows desktop, you can try use Microsoft Bootvis to Diag your boot problem and Bootvis also can optimze you boot time :)
Sep 26, 2008 | Dell Inspiron B130 Notebook
Open Questions:
Dell Inspiron 8500 Notebook Logo
1,097 people viewed this question
Alun Cox
