Question about Whirlpool LER4634J Electric Dryer
Whirlpool dryer froze and wont tumble just makes noise where try
My whirlpool model LER3624EQ1 was working fine, i put a load of clothes in dryer turned it on and it tumbled like 4 times then froze and wouldnt turn. just makes a sound where you can hear it trying to turn.we have checked the belts and they are fine
    President:
  • 1,136 Answers
Hi, This dryser only has 1 belt. When you chacked the belt, was the belt located in the middle of the drum?
This model has an idler pulley that is no longer being used. They have went back to the roller style idler which is easier on the belt.
Raise the top and then remove the 2 screws holding the front to the cabinet. Remove the front cabinet and locate the idler next to the motor pulley. Look at the belt while you have the front off and see if there is any bad spots in it.
I hope this helps you. Please let me know if I can assist you further.
Vic
Posted on Jul 02, 2009
Problem with tumble dryer that has started making loud noise.
Dryers are designed to operate in one direction. Some models turn clockwise and some turn counter-clockwise. Do not run it backwards. The direction of air flow will be impeded or reversed.
Mar 07, 2017 | Whirlpool Dryers
Whirlpool dryer awz 121 only tumbles counter clockwise. This is a dryer that briefly reverses direction, so the only tumbling is when it reverses. The rest of the time, the dryer makes a noise but d
You may want to contact a professional that will have the diagrams for your machine online. there are some here or you can go to another site. like (Just answer.) Be more specific about your problem. It can be fixed . There's no worries.
Are you saying that it does not heat up either ?In addition with not tumbling clockwise ?
Disconnect the dryer first. You can remove the top and front of the dryer to check to see what is happening. If it does not heat . You may need to replace the temperature control relay. If that does not work , the heating elements themselves may need to be replaced.
For the tumbling problem, they also have relay switches that go out.
BUT, if it is tumbling to one side and keeps tumbling then that will probably be enough to dry your clothes. As long as it is not too heavily loaded.
Mar 19, 2014 | Whirlpool Dryers
Ler3624eq1 whirlpool makes clunking noise
May have a bad bearing go to Repairclinic.com and watch their video on dryers
Dec 13, 2013 | Dryers
When washing Machine goes into spin cycle, , it starts making a grinding noise and never goes to full momentum and starts to slow down, after the grinding noise. The clothes aren't fully dry as they...
Sometimes, a Whirlpool dryer may not function as you'd like.Although specific details vary by model, the company offers several generalguidelines to troubleshooting your Whirlpool dryer and getting it back intoworking order.
Verify that thedryer is connected to its power source if it won't turn on. Whirlpool alsosuggests checking your home's circuit breaker, as the high power needs of thedryer may have tripped the circuit. If the circuit has been tripped, reset itby flipping it back into the "On" position. Push the door of the dryer. Whirlpool designed its appliances to not turn onif the dryer isn't secured and notes that the dryer door may not be fullyclosed even if it appears shut. Push firmly at the top and bottom of the door,as some Whirlpool models have two latches. Press the "Start" button again. Whirlpool reports that some modelsrequire you to press and hold the button for five seconds to fully start themachine. Depending on the model, the button may be labeled "Hold toStart," "Start" or "Push to Start." Check that the dryer's settings knob is set to an actual drying mode and notsimply "Air" or "Tumble." On most Whirlpool models, themanufacturer states that the settings knob should be set to"Accudry," "Timed Dry" or "Automatic Dry." Clean the lint trap, typically located at the top of the dryer and removedby pulling its plastic handle. Over time, lint and dust builds up here. Thethicker the trapped layer of lint, the slower your dryer performance. Whirlpoolrecommends removing built up lint after every dryer load. Remove some of the wet clothes inside the dryer if it's taking an unusuallylong time to dry your clothes. Whirlpool warns that placing too much clothinginside the dryer reduces hot air circulation, which also reduces dryingcapabilities. Recommended dryer load s vary, with compact Whirlpool modelsholding approximately 3.4 cubic feet while extra large Whirlpool dryers holdingmore than 7 cubic feet.
Jun 07, 2011 | Washing Machines
MODEL GLER642A - Dryer started making a very loud vibrating sound the other day. It tumbles and dries fine. The noise gets louder with a smaller amount of clothes than with a full load. It is on a level...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Sep 14, 2010 | Frigidaire Dryers
ELECTRIC DRYER WON'T TUMBLE
Possibly the belt assembly. if you open the door and try to turn the drum does it turn with a little resistance, noises? this model has rollers, pulley, and a four groove belt 92 1/4" , sometimes the pulley sticks after yrs of use, belts wear, drum misaligns. the humming should be the motor trying to work.
Feb 03, 2009 | Whirlpool LER7646E Dryer
Can't remove motor from Whirlpool dryer (LER3624EQ1)
no set screw,,,put the motor back,,,put the motor clip back on...lock it back down...ok now take a wrench and put it on the end of the motor where the belt goes,,if your by your sef,,prop the wrench againt the inner cabnit wall,,,than turn the blower wheel its hard but it will come off you..just lock that motor shaft down,,grip pliers..wracket,,,please use glovers to turn blower wheel..housing is very sharp..onthejob
Jan 24, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool Ultimate care ii Dryer wont tumble
If your dryer doesn't tumble, check these:
Belt,
Motor,
Door switch.
Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time.
If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor:
Remove the belt,
Check for obstructions in the blower fan housing,
Manually rotate the shaft of the motor.
If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor.
If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again.
Go here to see a diagram for your model:
one of two types. "H" or "J"
http://www.repairclinic.com/0079.asp#DiagramH
Nov 09, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Dryer
beckerkim, you have one of two things going here, either your blower wheel has something jammed in it or it's broken or the motor itself is shot. Check the blower wheel first make sure it's ok. You also may want to check the drum rollers to make sure they are not seized up. Catriver...post back.
Oct 27, 2006 | Whirlpool GEQ9800P Electric Dryer
Whirlpool LER4634J Electric Dryer Logo
241 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
