Question about HP (350208-001) CD-RW/DVD-ROM (Combo) Burner
Dvd cd drive wont recognize disk
I think I need to replace the driver. Where can I download it from?
  • 85 Answers
Cd drives are plug n' play, check your device manager see if the device is working properly, if its not then delete the device and restart pc to redownload the drivers. please contact me if it is sowing that the device is working, I have another solution for you to try.
Posted on Jul 03, 2009
My cd drive does not recognise cds
Okay. First of all is it a cd drive in your computer as opposed to a DVD drive? If you put a dvd into a cd drive it cannot recognize the dvd. A dvd drive can recognize a cd, but a cd drive cannot recognise a dvd.
Does your computer actually recognize the drive as being present?
If the drive isn't recognized by the computer try:
power off the laptop
Physically remove the cd or dvd drive
power -up the laptop without the cd/dvd drive
power off the latop and refit the dvd/cd drive
power it up again and see if the drive is
recognized
If the drive IS recognized by the laptop but won't play any disk it's probably the drive itself at fault. You can try gently cleaning the inside of the drive - the optic that reads the disk. However, the usual cause is failure of that optic which read the disk information. It cannot be repaired.
The alternative to fitting a new drive is to buy a portable dvd drive. They connect via a usb cable. Have a look on Ebay
Dec 21, 2014 | Computers & Internet
The disk driver for a emachines desktop will not recognize any disks
I have had this same problem on 3 drives over the years, it is a failed drive, this of course must be varified by checking that the drive does show up in the window explorer drop down. You can buy these drives very cheap on eBay, I think paid $15.00 for the IDE interface DVD-RW 22X DVD/CD reader/writer I just replaced in my Dell running a XP operating system.
Feb 01, 2012 | Computers & Internet
Computer does not recognize CD/DVD disks in drive. My Windows XP PC has suddenly stopped recognizing disks in my CD/DVD drive. Device Manager shows that both of the listed drives (TST Corp. DVD +RW...
Most likely a problem with the reader on the CD/DVD Drive.
Very easy to swap out a different CD/DVD Drive. Add the new device and see if that resolves the issue.
May 02, 2017 | Computers & Internet
Can't write dvbd-s on my hp zd7000
First I would make sure your using the right media, sometimes when you purchase a 50/100 pack of DVD-R you will find a couple dead disks that the drive wont recognize.
Second I would make sure you have an easy to use burning program installed, either Roxio or Nero are my personal fan favorites. Both of these work like a charm and have a simple interface.
Third if your drive isnt even detecting that it is a DVD Burner then go to control panel / add/remove hardware and look (about midway down) through the list for your disk drive. Un-install and re-install the drivers for it. It should automatically install without having to download the drivers but if you go to www.hp.com/support and click on DOWNLOAD then you can find hardware specific drivers for your unit.
Fourth you may need to replace the drive. If none of the above work then we have determined that it is not a software issue with the device. Its easy to find cheap replacement drives for the unit simple go to www.sparepartswarehouse.com I live by it and its a great site to find n e thing you need!
Good luck! Please leave feedback!
May 15, 2011 | HP CD DVD RW Burner Drive For HP Pavilion...
HP DVD writer 1140D doesn't recognize DVD's thinks drive is empty. Research on driver versions shows it's using Microsoft drivers. I would like to have the HP drivers to download that came with the DVD but...
all dvd writers have drivers on windows...and are installed automatically when windows is installed..If it started not to recognize dvd-es ...specially the ones burned in data format with multiple movies (avi ) ..even burned on it ...but sees the original ones..or sees the cd'es ..than the issue is with its lens ..and either you need a cleaning disk to clean it up ..or it is gone ...and need to be replaced..I personally have to do with something like this sand tried to update firmware ..installed original driver from the support site ,,and all the same ..Clean the lens and see how it is behaving ..and if it does the same ..just replace it ..cause they do have limited life time..otherwise you will end up with a lot of frustrations and no results...
Mar 18, 2011 | HP DVD1140i 22x Pata Multiformat Dvd...
Why won't CD/DVD RW drive won't recognize DVD disk?
Make sure you have the most current driver installed for that model. Go to IBM website and download, install. Once installed, try reading the disk again. That usually solves the problem.
And - all CD/DVD drives don't recognize all CD/DVD's - lots of different formats. Check the documentation for that drive to see which formats it can read.
--Crazy PC Lady
Dec 24, 2010 | IBM ThinkPad T30 2366 Notebook
My dvd-cd drive wont read DVD's and wont burn music CD's. sometimes it wont even recognize that there is a disk in the drive it says please insert disk. i have a gateway MT3705 laptop.
There is a slight possibility that your drivers could be corrupt or may not be there at all. You can check that by going to the device manager and reloading the drivers. You can also try doing a system restore back to the time when your drive was working. Most likely, I would think that your cd drive would need to be replaced.
Jun 17, 2009 | Gateway MT3705 Notebook
CD Rom/DVD drive
Check out the Jumper setting of the CD/DVD drive as the Jumper setting is not proper or your H-disk and CD/DVD drive can have the same jumper setting so only can be used at one time .I think you should also update your CD/DVD driver form your system disk.
Jul 11, 2008 | Computers & Internet
HP (350208-001) CD-RW/DVD-ROM (Combo) Burner Logo
399 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
