Question about Car Audio & Video
Install climate control - Car Audio & Video
  • 13,433 Answers
Could you be a little more spesific?
Posted on Jul 02, 2009
Climate control disable after install after market radio
The new radio or many other items, may not work
or be compatible with a CAN System Vehicle
Needed to check with a Dealer, before you did the
different radio
Sure you didn't remove something related to the
climate control module?
Dec 05, 2014 | 2014 Toyota Prius
Climate control
It most likely has to be reprogrammed. The tech should be able to program only the A/C control unit.
Apr 02, 2014 | Jeep Grand Cherokee Cars & Trucks
Climate control not working on 2001 volvo
I was having the same problem with a dead climate control module after disconnecting the battery on my 2002 v70. i tried (one method that sometimes works for people) disconnecting the battery again, shorting the leads for 10 seconds, and reconnecting with the key at position 2, to no avail. I managed to get my climate control back again when I jump started the car after the battery conveniently crapped out. then i got a new battery and when i installed it the ccm died. i jumped it again, with the new battery still hooked up, and the ccm came back. it's something try.
Jan 28, 2012 | 2001 Volvo S60
Heater only works on #1 setting after I replaced resitor pack
resistor is working but switch is bad. You can get a new switch from autozone for $20. Here is autozone procedure for pulling the control panel. Let me know if you have questions.
  1. Disconnect battery negative cable from battery and properly isolate to prevent accidental reconnection.
  2. Remove or disconnect the following:
    Audio unit Instrument panel console bezel retaining screws
  3. Pull the instrument panel console bezel forwards and disconnect the electrical connectors.
  4. Detach the temperature and air distribution blend door Bowden cables from the climate control assembly.
  5. Remove the climate control assembly.
To install:
  1. Install or connect the following:
    Climate control assembly Bowden cables to climate control assembly Climate control assembly electrical connectors Instrument panel console bezel and securely tighten the screws Audio unit Negative battery cable
Dec 16, 2010 | 2000 Ford Focus
97 nissan maxima switch doesnt work on 1,2,3 but work on number 4 only. what is wrong and how can i fix the problem. how can i r&r the climate control panel. thank your
problem is usually the resistor, but switch may be going bad too. The resistor is next to the blower motor, above the passenger's feet. You may have to take the glove box out to get to it. See picture below. Also, please see my tip at http://www.fixya.com/cars/r6234839-doesn_t_heater_or_air_conditioner_blow for additional diagnostic info. Please get back to me if you have any questions.
                        REMOVAL & INSTALLATION, Climate Control Panel
                        1. Remove the center console trim fascia.
                        2. Remove the radio to allow access to reach behind the control panel.
                        3. Remove the control panel attaching screws.
                        4. Remove the center console bracket, if necessary, to allow for easier removal.
                        5. Separate the control panel from the trim panel.
                        6. Unplug the harness connectors and vacuum lines from the control panel.
                        To install:
                        1. Plug in the harness connectors and vacuum lines from the control panel.
                        2. Install the control panel into the trim panel.
                        3. Install the center console bracket, if removed.
                        4. Install the control panel attaching screws. Do not overtighten them, as they are screwed into plastic.
                        5. Install the radio.
                        6. Install the center console trim fascia.
                        7. Operate the climate controls and check for proper operation.
                      Dec 13, 2010 | 1997 Nissan Maxima
                      How do i install dual climate control for 2001
                      gfffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffff
                      Nov 04, 2009 | 2001 Jeep Grand Cherokee
                      1999 Audi A4 Climate Control Removal/Installation
                      You have to remove the trim panel around the stereo/climate control to expose the screws that hold it in place. Once you do that, and the screws are removed, it pulls straight out and unplugs. No need to disconnect the battery and no tricks to it once it slides out.
                      Jan 18, 2009 | 1999 Audi A4
                      Ac switch light
                      Illumination Bulbs — A/C Switch
                      Removal
                      1. Disconnect the battery ground cable (14301).
                      1. Remove the shift console panel. Refer to Section 01-12 for the removal and installation procedure.
                      1. Remove the three climate control assembly screws.
                      1. Disconnect the climate control assembly electrical connector.
                      1. Depress the tabs on the air door shafts and remove the three climate control cable ends. Pull the climate control assembly from the vehicle.
                      1. Remove the A/C switch electrical connector.
                      2. Depress the tabs on the A/C switch and remove the A/C switch from the climate control assembly.Twist and pull out to remove the A/C switch miniature bulb from the A/C switch.
                      Jan 09, 2009 | 1997 Ford Aspire
                      Climate Control
                      The electronic climate control is much more elaborate as you would expect and I see many more power connection points. These might be empty fuse sockets on your model. The factory would have installed only what was needed for the basic A/C.
                      Same with the Mach 460 system. The basic audio system with amplifier does not even include a separate plug-in for a sub. You might be able to get some degree of functionality but not without a lot of extra work.
                      Jun 30, 2017 | 2001 Mercury Mountaineer
                      Rear Climate control console
                      The rear ac controls have the snaps built in onto the unit. When they installed the overhead dvd they prolly stuffed the ac controls up in the headliner. You will have to replace entire headliner to reinstall the panel correctly. Be cheaper to repair dvd unit, and reinstall over the hole. The front controls in that car are the master controls anyway, you dont have to have the rear ones to make the rear ac work.
                      Oct 15, 2008 | 2005 Chevrolet Suburban
                      Car Audio & Video Logo
                      15 people viewed this question
                      Top Car Audio & Video Experts
                      xxxxxx xxx
                      Are you a Car Audio and Video Expert? Answer questions, earn points and help others
