Question about Garden
Mowing blade turning the wrong direction
I am not sure if i have conected the wires correctly to the battery of my ryobi cordless mulching machine mower model bmm2400
    Genius:
  • 1,114 Answers
I think you did diagnose the problem. A DC motor will run backwards if the wires are switched around and polarity is reversed. Try switching the wires
Posted on Jul 02, 2009
Why does it bog down in grass maybe 6 " high?
The likely cause of this is that the grass is too high for your mowers deck. You should try just mowing about 1/3 of the blade at a time (if you can) until you reach your desired length, so if you grass is 6" high, only take off about 2" at first to reduce the stress on your mower. Set your mower deck to it's highest setting and give it a shot.
Also, be sure that the blades are sharp, and if you don't have mulching blades, you should get some! Grass this high will leave long clippings on the lawn which can suffocate the grass, mulching blades will chop up the clippings into smaller pieces, which is beneficial for your lawn!
Finally, make sure you aren't mowing wet grass. If you mow when the grass is wet the clippings can stick together and clump up under the mowing deck which will cause excess strain to the mower and maybe even cause it to shut off.
If none of this works, you may want to use a string trimmer to remove the first two inches of your grass and then continue mowing as normal!
Hope this helps! Happy Mowing!
Aug 03, 2015 | Garden
How to use mulch plug on cordless mower
Mulch plugs are typically a cover that is affixed to the discharge chute of a mower deck. As blades spin, they cut grass, and lift them up into the swirling air above the cut grass and below the mower deck. The clippings are suspended until they are blown out of the chute.
Mulching, is the process where grass clippings aren't simply discharged out of the chute after cutting; rather they are kept under the mower deck and spin around suspended in the blades resulting in repeatedly being cut. Instead of long clippings exiting the chute, much smaller clipping result from multiple cuttings and settle back on to the lawn under the deck. The smaller clipping allows them to decompose much quicker and return nutrients to the lawn.
Long clippings take longer to decompose and can turn into thatch on top of soil between blades of grass - effectively smothering the lawn. Long clippings can sit on top of cut grass and choke off sunlight, etc. and cause dead spots. Thatch can occur with mulching too - but takes longer to accumulate.
I nearly always mulch
Apr 17, 2015 | Worx Garden
During mowing grass will gather underside of deck leaving 2 streaks on r and l if you turn deck off grass will fall out of deck before restarting u need tgo move or mower will stall from grass build up...
There are a couple of things going on here. First, the blades are likely worn out and need replaced. As they wear and loose some length they can leave a trail. Second, if you have regular blades on a deck configured (by having discharge plugged) for mulching and you are using regular blades, then you can have a problem with build up. Third, you can have clumping problems if the grass is not dry when you are mowing.
I hope this is helpful for you.
Aug 24, 2011 | Ariens 48" Riding Lawn Mower Blade ...
Blade nut is stuck and will not move to unscrew. Have tried everything I can think of.
Make sure that you are turning the screw in the correct direction. They are reverse thread. Sometimes the blade lock button either wears out or just does not hold very well. Have you tried to cut into a board, then while the blade is in the kerf of the cut, remove the battery and then try to use the wood to help hold the blade while turning the screw. If you have a bench vise, this will also help hold the blade while trying to remove the bolt. If you have a small torch, like the one a plumber may use, you can try to heat the bolt first. The bolt should shrink a bit to help it back out. If you use this method, be very careful to not melt any plastic or burn yourself, they get very hot.
Nov 17, 2010 | Ryobi 12v Lithium-Ion Cordless 3-3/8"...
This is my second mower. First one damaged after hitting a rock. My replacement mower will not discharge grass out of the side discharge. I have the mulching attachment in and the discharge chute as...
it could be a low lift blade on it. try to get gator blade for mulching..... or a high lift blade. lol, size does matter!!! this may fix the issue. there is so many blades out there now, experiment till you find what your looking 4......
Sep 21, 2010 | Worx 19-Inch 24 Volt 17 Ah Mulch/Bag/Side...
To mulch my grass clippings, do I have to use the side discharge or can I simply remove the bag and insert the rear plug?
Insert the rear plug if mulching is desired. The key to mulching is to mow the lawn frequently.You want to keep the mower deck height high enough to cut the grass and allow the mulching blades to work, but just low enough to actually cut the grass in a smooth uniform height. To low of a cut setting will clog the mower and create a mess. 2 times a week is a good frequency to start with.
Jun 10, 2010 | Toro Lawnmower 20099 Mower Mowers Lawn
Toro lawn mower choking on mulched clippings multiple times
there is a product called mowease that you apply to the blade and mowing decked after a good cleaning. it helps keep the grass from adhereing to the deck
May 13, 2010 | Toro Co M/R Blwr/Trmmr Rear Bag Kit
Garden Logo
112 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
