Question about HP Computers & Internet
I got a new one played the hidden object game no more left at all
This is wrong they should have 50 coins each thats far.
Why can't I play manor memoir hidden object game on my Apple iPad?
might not be compatible on the iOS you may need update the app by going into app store go to updates and see if it needs updating
Mar 17, 2018 | Apple Tablets & eReaders
How do i earn Compasses?
compasses ' Pearl's Peril Wiki ' FANDOM powered by Wikia
pearlsperil.wikia.com/wiki/Thread:5587
Aug 9, 2014 - 18 posts - ‎5 authors
You get compasses by playing and progressing to the next level in the game. ... You can also get compasses by replaying scenes, not just new scenes. Also ... Things that can keep you from getting compasses are upgrading buildings because the game will replenish the common building materials first, then it will give you ... Waiting for compass to build
28 Apr 2015
High Scores & Compasses
3 Feb 2015
Why does it take so long to get compasses?
3 Sep 2014
More results from pearlsperil.wikia.com
Can I expand the island? - Pearls Peril
https://wooga.helpshift.com/a/pearls-peril/?s=the-island&f=can-i-expand-the... It is not possible to make the island bigger, however, as you progress in the game you will be able to unlock new areas of land by using badges, coins, and compasses.To unlock new areas, click or...
What are the Compasses for and how do I find them? - Wooga Support
https://wooga.helpshift.com/a/june-s-journey/?s=the-island...compasses... You must collect Compasses to clear the clouds and open up new areas of Orchid Island. You can find them in Star Boxes, and sometimes they are awarded as bonuses for playing Hidden Object Scenes.
Mar 11, 2018 | Camping, Backpacking & Hiking
Why does the game crags and/or not load once I've purchased the Boost option??
Because that way they get more of your coins and time, which translates to more money for them. It could be a bug in their system though, so try contacting them if possible.
Oct 31, 2014 | Zynga FarmVille by Zynga
Why games keep freezing while playing, basically all games?
It's possible your video card is getting overheated. Laptops often use APUs (video card and CPU/processor combined) in a very small frame and they get dirty (or sometimes even damaged) over time.
I would need to know more about your system to understand what's wrong, but my best guess is that your computer has a lot of dust in it or is just outdated. The more programs you download into it, the slower it can become. The more dust that accrues, the more crashing that occurs when you run any intensive program, even a simple hidden object game.
A simple and safe solution is to buy a can of compressed air (specifically for electronics, make sure it says it's safe for them) and just spray in short, quick bursts into the vents of your laptop.
If you have a tower (a big PC box that connects to a monitor or TV), you can usually quite easily unscrew the side of the case (tower) and use the compressed air to blow dust off of the components. So long as you don't touch anything inside, you shouldn't damage it, but if you desperately feel the need to put your fingers in there, make sure your computer is unplugged and that you've grounded yourself by touching a metal object, such as your case if it's not plastic. Static electricity can, although rarely, damage the components inside.
Alternatively just buy a new computer. Sometimes a PC has just run its course and the parts inside aren't worth salvaging for the average consumer. You could probably get a few bucks for it online to put towards a new computer.
That also brings up the issue of clearing your computer, though, so don't just sell it without finding out how to do that. A factory reset would do it, but you usually have to reinstall the OS.
Jun 17, 2014 | Free Ride Games Player
How do i finish world 7-2 on super mario bros? Thanks,
level 7-2 is the White Mushroom House level, so go into this level trying to collect all the Coins possible to win yourself a great prize. This level requires you to collect a minimum of 46 Coins to make the White Mushroom House appear. Wear a Frog Suit if you attempt to get this challenge done. Go right past the Nipper to use an Ice Block on the left ? Block to find a Power-Up, and then head down the next pipe. Go to the far left to collect the Coins, trigger the P-Switch, and then swim right at top speed to collect as many Coins as possibly before they revert to bricks (note that this is impossible to do without the use of a Frog Suit though).
Head back up topside to fight Nippers and Venus Fire Traps as you head right to jump into a large area where a Green Paratroopa Koopa is (kill it). Now jump up to reveal hidden Note Blocks all the way across this area before heading down the pipe on the right for a Power-Up before heading down the pipe on the left.
Swim to the pipe on the left, head topside, turn right to go across the Note Block bridge (jump straight up off the seventh from the left Note Block to reveal a hidden 1-Up Mushroom), and then continue right to go down the first pipe you see leading into the ground to fight Nippers and a Pirahna Plant as you go right to get a Power-Up.
Head back topside (using the pipe you came down in) to go right past a slew of Venus Fire Traps, a Pirahna Plant, and a Nipper to find the one short pipe that leads underground to another pipe for Mario to take. Run off to the right to find the Slot Box and finish the level!
Aug 01, 2009 | Nintendo DS Lite Console
How do you get all the 240 coins in New Super Mario ?
You don't need to have all 240 star coins on you the entire time.
Though this does count the star coins for you, its not required.
As long as you've collected the star coins in each stage, then you'll have that coin for good and your total amount of codes still count.
So there's no penalty to spending the star coins if you want to.
You can't see how many total star coins you have however but you can check each level one by one to see if you have their star coins.
Also the star coins are pretty much meant to be spent.
After you beat the game you can find a new spot in world one. This is a semi hidden mushroom house.
You can go in and buy new backgrounds for the bottom screen with all your star coins.
Hope that helps.
Have fun.
Apr 23, 2009 | Nintendo New Super Mario Bros. for DS
Do you have cheats for "My Sims" nintendo ds game?
There is no cheat for star levels, but try this one for a boatload of coins.
Get 10 coins. Once you do that, go to the Tic Tac Trump game in the casino. Bet 6 coins, don't double, then lose. Even though you have 4 coins left, the game will allow you to bet 6 coins. Do this and lose, you will now have -2 coins. Quit the mini-game, but play again, bet any amount, and win. You should now have 9,999,999 coins.
Apr 14, 2009 | Nintendo DS Lite
Cannot get the last gold coin on super mario brothers ds lite
First of all you will need SMALL MARIO for this.
Play the level to the last green pipe that you have to go through (this is the pipe where you need to stomp on a red switch to be able to step and and get through the pipe). Once you step on the switch, proceed to the green pipe. Instead of going through the pipe, hop on top of it and on your far right, you will see a platform. You need to wall jump from the pipe to reach that platform. Once on the platform, go up the steps and then you'll get into a space (where the door is). The LAST COIN is on top of this little room. Just wall jump left to right until you get to the top of the room for the coin and finish the game. Cheers
Jan 11, 2009 | Nintendo New Super Mario Bros. for DS
Computers & Internet Logo
16 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
