Question about Intex 4000 GPH Filter Pump
Took my working 1500gph pump off and replaced it with the 4000gph pump. i opened the valves after hooking up the new pump and cracked the bleed screw on top of the filter and left it cracked until water started flowing freely out of it without air spitting out. I did notice that the clear tube between the filter and the pump still has an air pocket in it at the top. Try as I might I can not get that air out. So I assumed it was supposed to be there. Turn on the pump and it appears to "spit" water into the clear tube but will NOT prime...please help!
You'll never believe this, but you need to raise the intake hose up as high as you can. I had the same problem and thought the pump wasn't working. One time it took 5 minutes of it being raised before I could hear the sound change, the water change in the tube starting to swirl and then you could see it come out the output. Very weird, but it worked for me and now I am very careful not to lose the prime.
Posted on Jun 24, 2011
Chevy 88 1500 chevy scottsdale
I take it that you are talking clutch system . There will be little pressure in the master cyl side until you bleed out all the air. The suction you feel is when the piston returns and draws in more fluid from the reservoir so that there is a full charge of fluid for the next stroke. remove the bleed screw and place your finger over the hole and use your finger as a valve until you get full fluid flow. Replace the bleed screw and finally bleed out the air . that got in while you were replacing the screw.
Aug 17, 2013 | Cars & Trucks
How do i bleed the fuel line on a 2011 buick lucerne. FYI I just replaced the fuel pump
To bleed a John Deere 2240, find the bleeder port on the injector port. Crack open the bleeder port while you're pumping the handle on the fuel pump or cranking the engine. Keep pumping until you get a steady stream with no air. Be sure to keep pumping while you're closing the bleeder port screw. If you can't get it to run right after bleeding the pump, you may have to bleed the injectors. Just crack the nut loose on the injector and start pumping. Keep on bleeding until all the air is out.
FGTech Galletto 2-Master EOBD2
Dec 19, 2012 | 2011 Buick Lucerne
2000 Chev Silverado 2500, Brake lines rusted and cracked loosing all fluid. replaced all lines. Got front to bleed sucessfully, but no oil to back brakes. what do I have to do to bleed back brakes?
Try opening a front bleeder and depress the pedal ALL the way,should feel a light "tic" as it reaches the bottom,close the bleeder and try to bleed the rear again,but instead of pumping ,just take the master cover off ,open the rear bleeders and wait 10 min or so for the fluid to gravity bleed out the air. Thinking the proportioning valve is tripped so no fluid is allowed to reach the rear,opening the front should reset the valve . If there is alot of air the valve will just trip again if you pump the pedal,hence the gravity bleed.
Mar 09, 2011 | 2000 Chevrolet Silverado 1500
Took my 93' Toyota, has 193,000 miles replaced the
THE MASTER CYLINDER NEED TO BE BLED FIRST.BEFORE PUTTING ON THE CAR.TO MANUAL BLEED BRAKE SYSTEM.YOU NEED 2 PEOPLE TO DO A BETTER JOB.YOU FIRST BLEED THE LEFT REAR RIGHT REAR LEFT FRONT AND RIGHT FRONT. WHEN YOU BLEED THE BRAKES.HAVE THE HELPER PUMP BRAKES 3 PUMPS.AND HOLD BRAKE PEDAL IN.YOU NEED A CLEAR BLEEDER HOSE IN A CLEAR BOTTLE HALF WITH CLEAN BRAKE FLUID. WITH BLEEDER HOSE ON BLEEDER SCREW AND OTHER END BLEEDER HOSE IN BOTTLE OF BRAKE FLUID.WHILE HELPER PUMP BRAKE PEDAL HOLD IT IN OPEN BLEEDER SCREW 1/4 TURN ALLOWING AIR BUBBLES LEAVE THE BRAKE SYSTEM.CLOSE THE BLEEDER SCREW BEFORE BRAKE PEDAL RELEASE.HAVE HELPER PUMP BRAKE PEDAL 3 TIMES. WITH PEDAL HELD DOWN OPEN BLEEDER SCREW GETTING AIR OUT OF THE SYSTEM.WHEN YOU SEE SOLID FLUID COMING OUT OF BLEEDER HOSE THE AIR IS OUT THE BRAKE SYSTEM.DONT DRIVE CAR ON HIGHWAY IF YOU STILL CANT GET SOLID BRAKES. HAVE CAR TOWED IN TO BE PRESSURE BLEED.
Jun 19, 2010 | 1993 Toyota Corolla
How do I bleed master cylinder for 90 Toyota 4Runner? I have no pedal aftr replaceing rusted lines under gas tank and bleeding brake lines. When i start engine pedal goes to floor. when shut off pedal's...
You will have to bleed the whole system, front and back, start with the right rear, get somebody to pump the pedal, put a hose on the lock nut, catch the oil in a can, pump up the pedal, it won't get hard till a few times doing this, crack the bleeder, tighten it back up before the pedal is released, pump again, crack,tighten, pump, repeat, go all the way around the car, keep checking the reservoir, it will pump up soon enough. You might have to go around 2 or 3 times, Now,,,, the part about the pedal going to the floor and getting hard after car is shut off, sound like you didn't hook up the vacuum line to the booster. It has an atmospheric thing going on there. Check the big hose going into the booster, which is that big round thing behind the fluid reservoir. Hope this helps.
Apr 12, 2010 | 1990 Toyota 4Runner
What happens if the coolant bleed valve seat is broken inside the intake? 99 Chrysler 300M, new pump, therm, rad, hoses. Bleed valve screws all the way down, no contact with seat- had to plug hole to...
i tkink you have a big problem you know as well as i do what has to be done.my advice is to go to your local motorcycle/engineering shop.the old shops could put a new seat in on an inprovised tool and fix the problem but they will tell you it is only tempory.adrian;;;
Nov 12, 2009 | 1999 Chrysler 300M
No brakes after master cyclinder and booster replacment
To bleed the brake system open all the bleeders and let the system gravity bleed for @ 1/2 hour ensuring the master stays full. Then close all bleeders and starting furthest from the master (r/r) have someone pump the brakes 2-3 times,hold the pedal down, then open the bleeder,close the bleeder,and repeat untill there are no air bubbles and the brake fluid is running clear .Repeat for all wheels in this order R/R L/R R/F L/F ensuring master cykinder does not run empty. You cannot pump the pedal with a bleeder open you will be sucking air back into the system. Once you finish all wheels repeat to ensure there is no air remaining in system.
Apr 17, 2009 | Toyota Pickup Cars & Trucks
Are they taking advantage by replacing parts that dont need to be
Yes this thedo need to replace most what they say. where your water pump is located it is highly recomended to replace the timing belt as well. a/c and alternator belt will need to be replace if the show wear or are streached. i am inclosing a diagram of what they have to do to get to the water pump so you have an idea of what they are going to be doing to your vehicle.
please do not forget to rate and comment about your experience with fixya today.
3.5L Engine
  1. Disconnect the negative battery cable.
CAUTION Do NOT open the radiator drain or the coolant pressure bottle cap with the system hot and under pressure or serious burns from coolant may occur.
  1. Place a drain pan under the radiator. Open the radiator drain located at the lower right side of the radiator. Do NOT use pliers to open the plastic drain.
  2. Remove the coolant pressure bottle cap and open the thermostat bleed valve.
  3. Remove the timing belt using the recommended procedure. It is good practice to turn the crankshaft until the engine is at TDC No. 1 cylinder, compression stroke (firing position). This aligns all the timing marks and serves as a reference point for all the work that follows.
  4. Remove the water pump mounting bolts and pump. Discard the O-ring seal.
  5. Clean the gasket sealing surfaces. Do NOT scratch the aluminum surfaces.
To install:
  1. Install a new O-ring and wet with clean coolant. Be sure to keep the new O-ring free of any oil or grease.
  2. Install the water pump and O-ring to the engine block.
  3. Install the retaining bolts and tighten to 105 inch lbs. (12 Nm).
88173g40.gif Tighten the water pump mounting bolts to 105 inch lbs. (12 Nm)
Click to Enlarge
  1. Rotate the pump and check for freedom of movement.
  2. Install the timing belt using the recommended procedure. Verify that all valve timing marks align. This is most important. An engine out-of-time will be seriously damaged when first started.
  3. Be sure that the radiator drain is closed. Open the thermostat bleed valve. Install a 1/4-inch clear hose about 48 inches long to the end of the bleed valve and the other end into a clean container. The intent is to keep coolant off of the drive belt(s).
  4. Slowly refill the coolant pressure bottle until a steady stream of coolant flows out of the thermostat bleed valve. Gently squeeze the upper radiator hose until all of the air is removed from the system.
  5. Close the bleed valve and continue to fill up the coolant pressure bottle to the proper level. Install the cap back on the bottle and remove the hose from the bleed valve.
  6. Reconnect the negative battery cable. Start the engine and allow to run until normal operating temperature is reached.
  7. Check the cooling system for leaks and correct coolant level. Be sure that the thermostat bleed valve is closed once the cooling system has been bled of any trapped air.
Apr 16, 2009 | 1994 Chrysler New Yorker
Is the intex 4000 pump any good.... do you lots filters...
I have the new 4000GPH pump and its awesome! The pump itself needs modifying just a bit. As for your pool, get rid of the plunger valves. They restrict the flow by about 1000GPH or more. There is a plastic grate in the inlet side of the pump. I just took a small file and sharpened the leading and trailing edges to smooth things up. The biggest thing is with the plunger valves. I modified some PVC fittings so I can use 1.5 inch ball valves. When my pump starts up, you see the water moving. I no longer have problems with **** settling to the bottom of my pool. Oh, and it will run an automatic cleaner with ease.
I dont recommend using the 400GPH pump with hoses smaller than 1.5 inches as there will be too much pressure and is likely to cause problems.
Mar 07, 2009 | Intex 4000 GPH Filter Pump
Brakes won't bleed on ford windstar 2003.
Sounds to me like the proportioning valve might be tripped. Try opening the bleeder screws at all wheels and have an assistant stomp on the brake pedal (all the way to the floor) and hold the pedal down while you close all the bleeder screws. Continue with normal bleeding procedures. Stomping the pedal with all bleeders open equalizes the pressures and resets the proportioning valve, allowing the fluid to flow to all four wheels again.
Aug 14, 2008 | 1995 Ford F350
Intex 4000 GPH Filter Pump Logo
176 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
