Question about Toshiba TN43V71 43" Rear Projection Television
Losses pitchure than will come back on after some time
  • 767 Answers
First rule out the obivious ( Bad solder)
jigle the conectors in the back of the set
when its working , if nothing hapens
then grab both top right- left corner and
rock the a little fwd and backward .no change.
stamp on the floor near the set
it help if the set has a picture when you
try this so you can get feed back
if non of the activtes cause to picture to
change flicker , go on or off its
Probley a failing chip in the turner
or on the video board
hope this was helpful
Posted on Jul 02, 2009
What could it be on my LC320EM2 TV no sound or pitchur
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time.
Sep 07, 2014 | Emerson LC320EM2 32" LCD HD Television
No pitchure or sound
Your TV has gone dead. Please consult the service center or someone qualified to do the job.
Jan 17, 2014 | RCA Lg 42ls5700 42" 1080p Flat Panel...
Give me pitchures of cam timing marks
Assuming this is the 2.2.L engine you have, see here p28, 36
http://www.turboninjas.com/camry/eg1.pdf
Dec 23, 2013 | 1997 Toyota Camry
LOOKING FOR SOME PITCHURES OF SHIFTER HOOK UP ON A 1993 MITSUBISHI DIAMONTE
We have no such diagrams as they are part of the factory service manual. You can buy access to the manulas for the car here.
Aug 17, 2012 | Mitsubishi Diamante Cars & Trucks
My sony bravia 46' KDL3000 upon start up has horizontal lines going accross the screen that make the image blurry.after quite some time it seems to clear itself up and go away almost like once its warmed...
sony lcd blury when we view satelite its common samsung and panasonic give good pitchure then sony bravia tey some good monster cable it will give good pitchure
Jan 08, 2011 | Sony Televison & Video
The pitchure looks like its 3d. everything looks
You have a convergece board failure. Changing one board will not nescessarily fix it. It is recommended to change all 3 boards in the unit. many try this as a DIY and fall afoul because it is a specialist job to retune and reset the paramaters. The cost then becomes greater than if a tech did it correctly the first time. Be advised it is not a simple DIY.It requires soldering and desoldering skills, specialised tools and a knowledge of circuit diagrams.
Please rate my help++++Thanks for using FIXYA
Nov 17, 2009 | Sony KP-46WT520 46" Rear Projection...
Trying to delete pitchures from my sony cyber-shot
There is a button with a picture of a garbage can...this is the delete button and it works in review mode when you're looking at the pictures you've taken. Bring up the picture you want to delete and press that button...follow the on-screen instructions.
Sep 09, 2009 | Cameras
Sony 55 inch, pitchure goes out but have sound
probably lamp is getting weak, needs to be replaced.
Sep 03, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Toshiba TN43V71 43" Rear Projection Television Logo
111 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
