Question about Lexmark JetPrinter X1185 All-In-One InkJet
How do I do a Head Cleaning Cycle? - Lexmark JetPrinter X1185 All-In-One InkJet
    President:
  • 1,335 Answers
Open the Lexmark Solution Center, go to the Maintenance tab, click Clean to fix horizontal streaks
Let me know if this does not work. Thanks.
Posted on Jul 09, 2009
Epson 3880 prit head cleaning
does it not have a head cleaning cycle
Oct 11, 2014 | Epson Office Equipment & Supplies
Magenta won't print at all on test page. Tried normal cleaning cycle several times to no avail. Also tried "power purge" cleaning cycle twice also with no success. Help!
The magenta print head nozzles maybe blocked.
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
May 20, 2013 | Brother MFC 6490CW InkJet Printer
My printer is blacking everything out
The print head nozzles may be clogged. From the Utility section found in the printer driver, clean the print heads by performing a head cleaning followed by printing a nozzle check pattern. A head cleaning and nozzle check must be performed as a cycle. After printing a nozzle check, examine the printed dot pattern. Each staggered horizontal and straight vertical line should be complete, with no gaps in the dot pattern. If there are gaps in the dot pattern, continue with another cycle. Performing up to 6 cleaning cycles is not uncommon if the print heads are severly clogged.
Now you will be able to print in colour.
Hope this helps.
Shane
Dec 21, 2011 | Office Equipment & Supplies
I have an Epson Picture Mate Charm Compact photo Style C11CA56203-N. The pictures are coming out yellow and I've tried 3 different brand new ink cartridges, is there a way to fix?
Hi!
Did you run a Head Cleaning Cycle after changing the ink cartridges? Run at least Three head cleaning cycle to clean the nozzles of your printer.
Hope this helps...
Dec 10, 2010 | Epson PictureMate 500 InkJet Photo Printer
New ink no print
Hi Good day!! Try to do a printer maintenance
Cleaning a Clogged Print Head
1. Press the cleaning button located on the front of the printer. Hold it down for 3 seconds to begin the cleaning cycle.
2. Run a cleaning cycle using your Epson printer utilities program. In Windows, go to "Start," "Printers and Faxes," right-click on your printer and choose "Printing Preferences." Select the "Utility" or "Maintenance" tab, depending on your printer model, and click "Head Cleaning." When the head cleaning cycle is complete, run "Nozzle Check." Repeat the head cleaning and nozzle check one to three times.
3. To access the Epson printer utility in OS X, select the Epson Printer Utility icon in the Applications folder in Macintosh HD. If prompted, select your printer from the Printer List, then click "OK."
Clean the print head manually. Remove the ink cartridges from your printer according to the instructions in your owner's manual. Turn off your printer. Dip a cotton swab in isopropyl alcohol, ammonia or hot water and rub the swab against the print head. Let the printer sit overnight.
Remove the print head according to the instructions in your owner's manual. Soak the print head for at least an hour in a small dish of hot water or isopropyl alcohol.
Preventing Clogged Print Heads
1. Use your printer at least once a week. Regular use will keep dried ink from clogging your print heads. If you have a color inkjet printer, print full color pages in addition to black-and-white documents.
2. Turn your printer off when not in use. This will prevent warm ink from bleeding onto the print head. If you have to store your printer, remove the ink cartridges.
3. Use a cleaning kit regularly. A cleaning kit usually includes a tube of ammonia that you spray on the printer head to clean dry ink.
Thank you for using FixYa
Please accept if my solution helps you
Nov 18, 2010 | Epson Stylus C84 InkJet Printer
PLSE HELP IM TRYING TO PRINT BUT NOTHINGS HAPPENING, IT IS ALL SET UP
test the printer first, so that we can isolate the issue. print a nozzle check to eliminate the possibility that the nozzles are clogged by dried inks. if nozzle check prints blank page or it printedr but w/ gaps or breaks, do head cleaning
Check the Print Head Nozzles: 1. Load a few sheets of plain paper in the sheet feeder. 2. Turn off the Epson Stylus CX4400 Series. 3. Hold down the cx4400_ug.1.79.1.jpg Stop button as you press the cx4400_ug.1.79.2.jpg On button to turn the Epson Stylus CX4400 Series back on. Hold down both buttons until the cx4400_ug.1.79.3.jpg On light begins to flash, then release the buttons. cx4400_ug.1.79.4.jpg 4. Check the nozzle check pattern that prints to see if there are gaps in the lines. cx4400_ug.1.79.5.jpg 5. If there are no gaps, the print head is clean and you can continue printing. If there are gaps or the pattern is faint, clean the print head. Clean the Print Head Nozzles: 1. Load a few sheets of plain paper in the sheet feeder. 2. Hold down the cx4400_ug.1.80.1.jpg Stop button for at least 4 seconds to start the cleaning cycle, which lasts around 1 minute. cx4400_ug.1.80.2.jpg The cx4400_ug.1.80.3.jpg On light flashes throughout the cleaning cycle and stays on green when the cycle is finished. Caution:
Never turn off the Epson Stylus CX4400 Series during a cleaning cycle or you may damage it. 3. Run a nozzle check to confirm that the print head is clean. You may need to clean the print head up to 2 times. You can also turn the Epson Stylus CX4400 Series off and wait at least 6 hours. Then try printing again.
Feb 15, 2010 | Epson Stylus DX4450 All-In-One InkJet...
Lines/streaks on paper even after deep cleaning and head alignment
Set the print head on a paper towel to dry, drying time will vary. ... Run a print head alignment and a regular cleaning followed by .... Normally you can clear up minor clogs and streaking by running the cleaning cycle found in .... After all the deep cleaning cycles I suspect I have now clogged ...
www.applefritter.com
Dec 06, 2009 | Canon BubbleJet i560 InkJet Printer
Poor printing / The print is hard to read. Just put in new ink
pls perform a cleaning cycle, this will greatly improve your print out to be much more clearer and readable
you could perform the cleaning cycle 2 ways 1 is by computer while your printer is turned on and 1 is by your printer itself.
always do a cleaning cycle for about 3 to 4 times....it will be indicated as head cleaning on your printer driver
Oct 15, 2009 | Epson Stylus CX3810 All-In-One InkJet...
My printer prints mostly all green
try to run a head cleaning cycle: are you on a mac or windows/ go to utility or maintenance and run head cleaning cycle
Mar 28, 2008 | Epson Stylus C86 InkJet Printer
Cleaning print head
Check my previous post below for info on under head cleaning. This should get you going again http://www.fixya.com/support/t137335-problem_print_outs_from_printer
May 30, 2006 | Epson Stylus Photo 1280 InkJet Printer
Lexmark JetPrinter X1185 All-In-One InkJet Logo
62 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
