Have it fixed 3 times now warranty out green and red lines on screen in dark areas of screen (like black coats or dark guide list
SOURCE: I have the common "color contouring" problem (red
The T-CON board get the power from the logic board switched transistor that supplies the voltage to the T-CON board. Check to see if the 12vdc feeding the T-CON board is clean voltage and not higher than 12vdc. The problem can also be the logic board which sends the signals to the T-CON board. Does cooling the T-CON board with electronic freeze spray make the problem goes away. Some of the work I have to do is to install a small DC fan to keep the T-CON board cool and some time using heat sinks.
http://s807.photobucket.com/albums/yy352/budm/VIZIO%20L32HDTV10A/
http://s807.photobucket.com/albums/yy352/budm/LTV-32W3HD/
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
SOURCE: My Vizio SV470XVT1A, when turned
All plasma an lcd TVs have boards that control vertical and horizontal output to their respective areas. They are connected to the screen by ribbon cables. If one of these boards fails all together, has a failed chip, a bad connection, or a bad ground somewhere it will result in a black line in the area of that board. A bad ribbon cable connection on the bottom will result in a vertical black bar though the screen. Many times resetting the connection will fix it, if the ribbon cable has been nicked there could be a severed connection. They can sometimes be fixed, but it is a pain. An yes I have done it, and the bar is gone. The same will happen if the chip that outputs to that area opens. The connectors are the first place to look paying close attention to the cable, they are extremely delicate so great care must be taken if you decide to tinker with em, the usually have lift locks that release them, but it is very easy to wreck em.
Good luck.
