Question about Dell Dimension 8200 PC Desktop
Dell dimension 8200 keyboard compatibility- won't
Dell dimension 8200 keyboard compatibility- computerwon't recognize new hardware(keyboard) second keyboard tried after original failed. usb connection.
dtm
  • NinaE May 11, 2010
    Both keyboards are USB and both failed ??
    Scholar:
  • 38 Answers
From what I understand you have a compatibility issue with your new keyboard.
Here is what you can do, because it's probably a driver issue.
Youcan check if you are missing drivers by going to Start>(RightClick)My Computer>Properties>Hardware>Device Manager. If yousee any drivers that are yellow or with a ! those are the drivers youneed to find, download and install.
Windows Updates ~ When you go to Windows Update, do not "Express"update, rather "Custom" - Once it has loaded the screen, on the lefthand side you will see hardware. Download the hardware drivers there.They work 98% of the time, and Windows Update is pretty good now daysso it might fix your problem easy.
I don't understand the question entirely however.
Does your original keyboard work?
Is the new keyboard the only one not being reconizied?
Try differen USB ports, see if it makes a difference. Also, turn off the PC, and then plug it in. Sometimes the PC has to be restarted/turned off, before you change hardlike like keyboard and mouse or other accessories.
Hope I've been of some assistance!
Posted on Jul 02, 2009
Dell 8200, xp. plug & play config error. can not bring up ms xp. disconnected everything except keyboard, mouse & monitor.
Plug and Play Error? Check and see what CD/DVD Device you have connected. An 8200 uses Either SATA Connectors or IDE (WIDE GRAY CABLE) to connect to the hard disk and the Optical Drives. You may also want to check the jumper settings on the CD/DVD Drives. You will see if it's been set to "Cable Select," which is AUTO for most Dell computers. Dell OptiPlex and Dimension computers can be tricky so try "Cable Select" first. If you have TWO cd/dvd Drives in the PC, you have to have one SET for "master," and the other one to NOT HAVE A JUMPER AT ALL. Dell computers just work weird that way.
Sep 17, 2013 | Dell Dimension 8200 PC Desktop
Does a DELL Dimension 8200 have the Sleep and/or hybernation features that laptops have? Using Windows 2000.
Hello-
Welcome to FixYa, the world's largest product support community.
"...Microsoft Windows 2000 and later support hibernation at the operating system level (OS-controlled ACPI S4 sleep state) without special drivers from the hardware manufacturer..."
Source: Wikipedia
URL: http://en.wikipedia.org/wiki/Hibernation_(computing)
Regards,
Deathschythe
Nov 01, 2010 | Dell Dimension 8200 PC Desktop
Dimension 8400 locks up. Keyboard won't respond.
Generally and indication of a software issue that is locking the system. There can be hardware causes too.
  1. Run diags on the system (From Resource CD or F12 menu) see if any failure. If you have a hardware failure then address it and see if the problem is solved.
  2. Update bios and drivers from support.dell.com
  3. Edit MSCONFIG, startup group, remove entries that are not required (Generally only AV and printer scanner items are needed here, most other items will function without and item here)
  4. Edit the Virtual Memory settings, and set it to Custom and an amount double the RAM (EG: 4 GB RAM set initial and Mas to 8200 MB VRAM)
Apr 04, 2010 | Dell Dimension 8400 PC Desktop
How to add memory to dell dimension 8200
http://www.tigerdirect.com/applications/category/memory_config.asp?ClsId=100
Enter the following information in the blank
and you should come up with which ram is compatible with your computer
then refer to this link on how to install the ram into your computer
http://static.tigerdirect.com/html/guide_installing_desktop_memory.html
Dec 30, 2008 | Dell Dimension 8200 PC Desktop
Dimension 8200 Upgrade Heat Sink Problem
you can contact online for techsupport at dell at www.support.dell.com this a live tech support session totally free they have helped me out numerous times keep me posted on how this goes ok best regards mike
Aug 12, 2008 | Dell Dimension 8200 PC Desktop
Will This Hard Drive Work In My Dell 8200?
Yes it will work. You probably will have to use the CD that came with the drive to make sure the HD is recognized.
Jul 13, 2008 | Dell Dimension 8200 PC Desktop
Switching keyboard and mouse
Mice and keyboard are the two most basic input devices for the modern computer. Not much is needed to change them out.
Turn your computer off. Remove the old keyboard and mouse. Connect the new keyboard and mouse into an available usb port. Restart your computer.
You may have to wait anywhere from 30 seconds to a few minutes, depending on your computer, before the operating system recognizes the new hardware, but once it does, it will start responding.
Jul 03, 2008 | Dell 2 Button Mouse 6u226
Dell Dimension 8200 PC Desktop Logo
272 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
