Question about HP OfficeJet 6110 All-In-One InkJet Printer
Error 388 keeps coming up
I only get this error when I try to fax long distance---not sure why...any ideas
  • 56 Answers
The local machine has originated a fax session and detected a remote fax machine but has been unable to detect any T30 frames. If the machine is in V.17 mode, it is likely the connection has been interrupted. In V.34 mode is also possible for this error to occur due to compatibility problems with certain machines and/or line conditions.
Solution:
1. Reattempt the fax transmission at a different time when telephone line conditions have improved.
2. Disable V.34 on the local machine and attempt the transmission using the V.17 mode. ( See error 227 for changing to a slower speed or disabling V.34 .)
http://h20000.www2.hp.com/bizsupport/Tec... Source(s): http://h20000.www2.hp.com/bizsupport/Tec... just try this out buddy
Posted on Jul 02, 2009
Hp laser jet m1536dnf MFP won't send fax comm error 388
You can start by making sure that the photocopy is working, this is to ensure that the scanner is working. Next, try to isolate the issue if this is only happening to only one fax number? If all of these have negative results, I suggest for a hardware reset. Follow the steps for reset found here, How to Reset the HP LaserJet Pro M1536dnf Multifunction Printer. Goodluck :)
Aug 14, 2012 | HP PSC 2410 All-In-One InkJet Printer
Fax won't transmit long distance faxes
Your long distance access is being blocked by the telephone company for some reason.
Apr 07, 2010 | Brother MFC-7220 Plain Paper Laser Fax
I have a HP Photosmart All-in-One series C7200. I keep getting an error message saying "Image on Fax Teport is set to Off". Error 388. The proble occurs when we try & send long distance. What should I...
Definition
There is too much noise on the line for a valid connection between two fax machines to complete. The noise problem might go away over time.
Solution
Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
to check the error codes and there solution
click on the following link Hope you its satisfactory
ERROR CODES C7200 Series
http://h10025.www1.hp.com/ewfrf/wc/document?docname=buu02549&cc=us&lc=en&dlc=en&product=3382185#Error386
Jan 03, 2010 | HP Office Equipment & Supplies
Receiving error 388. Can receive faxes but won't connect with other fax machines when trying to send
The reason for the error code:
4e5e48b.jpg Error Code: 386, 387, 388, 389, 390, 391, 392, 393, 394, 395 Definition
Solution
Solution
Please Click here and follow the instructions to resolve the issue.
May 21, 2009 | HP Officejet 6310 All-In-One InkJet...
When trying to fax connects ok but comes back failed error 388
A list of HP aio error codes:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu02549&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
You could try running the Fax test. Press setup > Tool> Run Fax test.
This will give you instructions about what you need to check and what you need to do if it failed on some of the tests.
Then try to send a fax to the HP fax test server detailed below:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00259105&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
Jan 19, 2009 | HP Photosmart 2410 All-In-One InkJet...
What is error 388
there is not error code for the OfficeJet 4315. however, there are similar code for other Hp printer.
error "388" is lised as unable to detect T30 frames. in other words, the machine fail to establish comparable connection. this can be the machine trying to send out fax in high speed, or the phone line problem.
consult the user manul how to set a lower transmission rate, or try to send the fax at a differnt time of the day . If that still give you problem, please call the phone company and have they look a the phone line.
Nov 10, 2008 | HP OfficeJet 4315 All-In-One InkJet...
Sending faxes
Error 388 is for telephone line conditions being bad, have you called your telephone company and head you telephone line checked...?
If not please have it checked.
For more details on the error message check the link bellow with Error codes any their reasons:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu02549&cc=us&lc=en&dlc=en&product=79477
Good Luck
Oct 11, 2008 | HP PSC 2410 All-In-One InkJet Printer
Fax not working Error 388
We had the exact same problem. Static on the line. We had the cable company check and sure enough our digital modem for the phone line was bad. The new replacement fixed the problem instantly.
Aug 06, 2008 | HP Officejet 5610 All-In-One InkJet...
Error Codes
Hi Sir
this is very common error that happens in fax
i am sending a link which has all the things of hp
please follow that arcticle it is going to resolve the issue for you
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&dlc=en&docname=bpu02549
Jun 15, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Fax
error code 388 says :-
Unable to complete the handshake.
*Try to send the fax at a different time when telephone line conditions have improved.
Mar 06, 2008 | HP PSC 2410 All-In-One InkJet Printer
HP OfficeJet 6110 All-In-One InkJet Printer Logo
436 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
