Question about Toshiba Satellite 2435-S255 Notebook
Yeah same for me i mean my labtop only charges when its off!!
I would really want solution to this problem!!! I replaced the battery charger but still does the same and no it doesnt overheat i replaced the fan also!!
This could be a windows issue, have you tried charging the laptop while in the bios setup?
Posted on Jul 03, 2009
My battery won't charge even if I replaced it with new battery.
If your battery will not charge, you need to run a test on some components on the laptop. The battery, the charger and the laptop itself. Once you detect the faulty conponent then you replace it with a new one.
To test the battery:
1.Power off the laptop,
2.Take out the battery,
3.Insert it in another laptop,
4.Check of it will charge,
If the battery holds a charge there, then it means the problem is not from the battery, but if it does not hold a charge, then it means the battery is defective and need to be replaced with a new one.
To test the charger:
1.Unplug the charger from the present laptop,
2.Connect it to another laptop to see if it will charge.
If it charges the laptop, then it means the charger is alright, and if it does not charge the laptop, then it means the charger is bad and need to be replaced.
To test the laptop:
1.Turn off the laptop,
2.Disconnect your present charger,
3.Remove your present battery pack,
4.Insert a well tested battery into the laptop,
5.Connect a well tested charger to the laptop.
If it powers on, then it and charges, then it means the laptop is working fine, but if it does not charge, then it means the connection port of the laptop is bad.Hope this information was helpful.
http://www.chargerbuy.com/laptop-battery.html
Jan 14, 2013 | Computers & Internet
My toshiba P205-S6307 battery is not charging when plugged in
To test your toshiba p205 charger:
To test the laptop:
Jan 07, 2013 | Microsoft Computers & Internet
Battery not charging
Is it a replacement battery ,you purchased, with the EXACT same specs? Some aftermarket inexpensive batteries do not work well with your laptop. How do you know it's not charging, by the Icon in the Tray Notification Area? Again sometimes aftermarket batteries don't have the ability to communicate with the software. The pin-outs are not the same.
Dec 09, 2012 | Computers & Internet
Power is plugged in , battery is plugged in not charging with 0% available
To test the laptop:
Replacement Acer Aspire 6930 AC Adapter 90Watt 19V 4.74A
Nov 12, 2012 | Acer Aspire 6930 6930g 6930z 6930zg Laptop...
My hp compaq turned off by itself and won't turn on now, it won't even show the charging light when the charger is plugged in
Remove the PC labtop battery then re insert it again.
If still not charging check the charger connector if its connected as well.
If there was no problem in the charger connector,Check the charger itself.
These all what you need to check only,no problem in your labtop.
If still not charging means one of these :
1- The BATTERY may needs to be changed .
or
2- The charger may needs to be changed.
Jun 13, 2011 | HP Compaq 6720s Notebook
MY LABTOP BATTERY IS NOT CHARGING
sounds like it could be one of three things 1. either the charger is broken try plugging it in in different places or borrow someone else's to try, if it works buy a new charger 2. the battery is broken, try your charger on someone else's laptop and if it works and their battery works in your computer then its the battery. replace battery 3. it could be the power board if both your battery and charger work in another computer then power-board is shot. you can get it replaced but it is often cheaper to buy a net-book.
Apr 08, 2010 | HP Computers & Internet
I have a toshiba labtop but i can't seem to remember the model, but i was working on my labtop and then the charger stopped working and wouldn't charge my labtop, ive tried 4 different power outlets but my...
how old is the laptop/battery? rechargable batteries sometime with age; I'm told, over time lose their ability to hold a charge. As far as model number number, usually at the bottom side on the sticker you can find all information you need.
Aug 22, 2009 | Computers & Internet
Cannot charge battery
i would replace the charger 1st seeing as its the cheapest thing to do. if that doesnt solve the problem. return the charger to where ever you got it from and purchase a new battery.
May 18, 2009 | Casio Cameras
Dell Latitude D600 new battery won,t charge
the charger in the laptop is not functioning. pc will need repaired
Dec 28, 2007 | Dell Latitude D600 Notebook
Toshiba Satellite 2435-S255 Notebook Logo
165 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
