Question about E-Machines T6524 PC Desktop
T6524 bios update needed
Emachine T6524 bios suspected as POF
possible power surge overnight; windows had attempted to restart but, was hung
Windows XP will not boot, period - gets to winxp splash screen with the blue bars - hangs during blue bars - everytime
will not boot in safe mode / last known good / normal
will not boot from a winxp bootable cdrom such as barts pe or ultimate boot disk
bios has been cleared
all cards and driives have been removed - using alternate known good cdrom drive
RAM passes diags but has been swapped
system will boot from cd media into DOS where I can run diagnostics
no detected failures
scenario reminds of incorrect bios setting(s)
  • 144 Answers
This isnt necessarily a bios problem mate , its just windows got corrupted during the power surge. Use the link below to do a repair install. Note , repair installs do not erase your personal files or setings or software !
http://michaelstevenstech.com/XPrepairinstall.htm#RI
Hope this helps you
If you found this solution helpful , please rate below
Kind Regards
1234s282
Posted on Jul 02, 2009
Restore my emachines w3507 back to factory settings how do i do it
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu
Please select an option: Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice. To perform a system restore, follow these steps: 1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue.
or
It is possible for the Windows operating system on your eMachines computer to have a critical failure. If the operating system on your eMachines computer is failing, you can use your recovery discs to restore your computer. Recovery discs come with your purchase of an eMachine, and contain your operating system and all your basic drivers. You can recover your eMachines W series in about an hour.
Turn off your computer and press "F8" to enter the BIOS menu. Tab over to the "Boot Sequence" or "Boot Order" menu. Move your optical drive to the top of the list. Press "F11" to exit and save changes. Insert your recovery disc into your optical drive, then restart your computer. Press any key to boot from disc. Select the "Full Recovery" option from your recovery disc menu. Allow the recovery procedure to complete. Hope this helps.
Dec 28, 2012 | eMachines W3507 PC Desktop
Boot sequence for emachine M6811
As SOON as you press the Power On button, start tapping on the DELete key.
Tap in 2 second intervals.
You may hear beeps. This is a Stuck Key Error Beep. (Or beeps)
Ignore the beeps.
You will now be in the BIOS Setup utility.
The BIOS program is made by Phoenix.
It is Version NSF03.P0
Release date - 07/28/2004
http://www.notebookreview.com/default.asp?newsID=2170#specs
Scroll the page down a little, until you come to the bold heading -
EMachines Desktop Replacement Notebook Specs
Scroll down until you see the sub-heading - Detailed specs
Left-click on - Click here to See appendix for detailed specs
Now look under the bold heading - DMI, and [ BIOS ]
When you are in the BIOS Setup utility, you CANNOT use your mouse
anymore. You have to use your Keyboard.
At the top of the BIOS Setup utility you will see headings;
Main, Advanced, Security, Power, Boot, and Exit.
The BIOS Setup utility automatically opens to the Main screen.
Use the Right Arrow key, and stop on the - Boot - tab
What is listed is a Boot Order.
In the list of the Boot Order are Boot Devices.
What is at the TOP is the first boot device the laptop will boot from.
Should be;
1) CD-ROM Drive
2) Removable Devices
3) Hard Drive
4) Network
Having CD-ROM Drive at the top allows you to install a different Operating System, that the laptop did not have from the factory.
ALSO; Windows DOES NOT like to be written over, with a lesser operating system, or the SAME version of operating system.
Examples;
Trying to install Windows 98SE, on a Windows computer that has Windows XP on it.
Trying to install Windows XP, on a Windows computer that has Windows XP already on it.
Using CD-ROM Drive as the first boot device, will allow you to install what you wish.
[ Doesn't work for installing Windows XP over Windows Vista. There is a special procedure ]
If I haven't answered your question, or you have additional questions, please post in a Comment.
Regards,
joecoolvette
May 04, 2012 | eMachines M6811 Notebook
Emachines W3619 won't load ntldr
Take a windows XP CD, Switch on your PC and go to "BIOS" menu and select "Boot From CD/DVD" whichever is applicable for your pc.
Now insert the Win Xp disc i drive and start PC, Boot the Pc From CD Drive and you shall get the Blue screen of windows Installation. Restart the PC by hard pressing the power button for 30 secs.
Now you will be able to login to windows.
Dec 02, 2011 | eMachines W3619 PC Desktop
My T6524 PC will not shut down when I hit the button.
Please check following KB article:
Advanced troubleshooting for shutdown problems in Windows XP
http://support.microsoft.com/kb/308029
Sep 13, 2011 | eMachines T6524 PC Desktop
"NTLDR IS COMPRESSED PRESS CTRL+ALT+DEL TO
Repair PC
press delete at startup
go2 BIOS option
1ST BOOT DEVICE CD/DRIVE
2ND BOOT DEVICE CD/DRIVE
F10 SAVE
RESTART PRESS F12
Feb 22, 2011 | eMachines T6524 PC Desktop
BSOD after power failure during check disk-now I cannot reboot from recovery console or disk. How can I uninstall the OS then reinstall OS from eMachines T6524?
You need to enter the BIOS. immediately upon starting the computer start tapping either the F2 or the tab button. Once in the bios, go to boot order and set the cd/dvd drive as the first boot priority, hard drive second. It is ok to leave this permanently, save and close settings which will reboot the system and considering everything goes as planned you should be able to start up from a disk and then repair or replace XP. When replacing XP remember to delete partition and write a new copy. THIS WILL ERASE ALL INFO ALREADY ON THE HARD DRIVE!!!
Feb 23, 2010 | E-Machines T6524 PC Desktop
I have corrupted files in Windows XP and EMachines provides "Restore CDs" But with my NEW LG widescreen monitor the instructions on how to startup the CDs is actually cut off. So when I attempt to load the...
hi there! if you can configure your bios set up and go there, priority yout cd rom as first on the list,2nd your hard drive, in able to start and configure your windows set up promptly.How to open your bios set up,after switching on your pc, press F2 or delete depend on your start up windows appear on left bottom of screen if cmos/bios appear on blue screen select the boot sequence and arange the list of booting up your windows.In your screen resolution this will be adjusted after you finished the windows set up to new xp,you can adjust your scrren resolution, by left clicking on your windows xp on screen,click proreties, on properties box there adjustment of screen resolution there slide function key to 1680 X 1200.then click apply,click ok then restart your pc for effetivity or sometime it was auto restart after you change your screen resolution...,regards
Mar 27, 2009 | E-Machines W3052 PC Desktop
Only getting EMachines/Windows XP Logo when boot up T3882
you have not set the cdrom as first boot device in the bios (press F2 or Del on boot up to get in bios), choose cd as first boot device, save settings and restart the pc with your cd in the drive and then when prompted press enter
Aug 18, 2008 | E-Machines eMachines Desktop PC
E-Machines T6524 PC Desktop Logo
1,035 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
