Question about ASUS P5GD1-VM Motherboard
Problems with usb 2.0 hispeed enabled (also fullspeed)
If I enable from bios the usb 2.0 controller and select Hispeed option, the system hangs and doesn't bootup any system, otherwise the system works well, but not usb 2.0 !!
  • 42 Answers
What happens is you don't enable hispeed but leave 2.0 on?
Posted on Nov 10, 2007
How to enable usb port LG 22LD330
On the desktop, right click on MY COMPUTER, and then select MANAGE option. a new window will appear, in that select SYSTEM TOOLS, in that click on DEVICE MANAGER, on the right side of the window pane, a list wil appear,
If USB is enabled in BIOS or EFI but the USB host controller does not appear in Device Manager (under Universal Serial Bus controllers), or a yellow warning icon appears next to the host controller name, then the version of BIOS or EFI may be outdated. Contact the maker or vendor for your computer and obtain the current version of BIOS or EFI.
If the controller appears in Device Manager, right-click the controller name and then click Properties. Problems and suggested actions are displayed under Device status.
USB ports have a separate entry in Device Manager. To check the device status, click Universal Serial Bus controllers, right-click USB Root Hub, and then click Properties. If you do not see USB Root Hub, you might not have a USB port installed on your computer
On the USB Root hub Properties page, it may tell you this device is working properly, or there is a Troubleshoot button. At the bottom you have an option to Enable or Disable the USB hub.
Jan 22, 2014 | LG Computers & Internet
How to use a usb keyboard
as a P/S2 keyboard.plug it in the USB contact in the back.in any USB port.
Apr 08, 2013 | Dell Inspiron One 2305 Desktop Computer...
Keyboad failure on dell gx520 boot
Usb or Ps2 keyboard ?
Shut down the computer and disconnect the USB keyboard. Connect a PS/2 keyboard to the PS/2 connector port on the rear of the computer. Enter bios restart your computer you will see a certain to press to enter set up usually the Delete or the F2 key this will vary depending on you computer and bios. Wait for the main BIOS setup screen to appear. Press the right or left arrow keys to move the cursor to the "Advanced" or "Advanced Settings" menu option. Press the "Enter" key. Move the cursor to the "Integrated Peripherals" or "Peripheral Configuration" menu option. Press the "Enter" key. Press the down-arrow key to navigate to the "USB Controllers" option. Press the "+" or "-" key to change the menu option to "Enabled." Move the cursor to the "USB Legacy Support" or "USB Legacy Function" field. Press the "+" key repeatedly until the value option changes to "Enabled." Press the "F10" key to save changes to the BIOS settings and exit the setup utility. Wait until the computer begins to restart and then press the power button and hold it for approximately four or five seconds. The computer shuts down completely. Unplug the PS/2 keyboard from the computer and set it aside. Reconnect the USB keyboard restart the computer. As soon as you see the initial boot screen, tap the "Delete" key several times and wait for the BIOS setup screen to appear. If you are able to access the BIOS setup screen with the USB keyboard, USB support is active in the BIOS.
Enable PS2 & USB in BIOS You can enable PS2 and USB settings in BIOS by entering the BIOS setup screen when the computer boots. You will need to changes to the appropriate settings in this screen. The exact procedures vary by system, but there are a few common methods that may work if the motherboard manual is not available for guidance. The general procedure is the same for any modern computer system, but the menu arrangement and keystrokes to enter the setup program can vary greatly from one machine to the next. Power on or restart the computer and watch the initial boot screen to find the keystroke required to enter BIOS setup. This is often shown at the bottom of the screen. Typical keystrokes include pressing the "F1," "F2," "F9," "F10" or "Del" key. Press this key when the prompt appears on the screen. You can find the proper key in the computer's motherboard manual or on the website of the motherboard or computer manufacturer. Enter the BIOS setup screen and look for the "Advanced" or "Onboard Device Configuration" menu. Use the arrows to select your choice and press "Enter." Change the settings for the PS2 port by moving the menu choice to the "PS2" setting. Press "Enter" to bring up a smaller menu with the options to enable or disable the PS2 ports. Select "Enabled." You can also use the arrow keys or the plus key to change the current selection from "Disabled" to "Enabled" in order to enable the PS2 port. Change the settings for the USB port by moving the menu choice to the "USB" setting. Press "Enter" to bring up a smaller menu with options to enable or disable the USB ports. Select "Enabled." Alternatively, use the arrow keys or the plus key to change the current selection from "Disabled" to "Enabled" in order to enable the USB port. Save the settings and exit by pressing "F10" or using the "Esc" key to back out of the current menu. Choose to save and exit from the main menu if needed. Follow any additional instructions on the screen to save or navigate the menus. Hope this helps.
Dec 13, 2012 | Dell OptiPlex GX520 PC Desktop
Asus p5gc-mx erorr on all usb port, sometimes on bootscreen appear text 'usb port error' system will automaticly shutdown' help please
Hi again newbie7,
1.enter your bios setup >>> Advance >>> Usb Configuration >>> USB Controller mode >>> HiSpeed
2.enter Chipset section >>> Southbridge Configurations >>> Usb 2.0 Controller >>> Disable
3.save and exit
If problems exist,ask me for more
akee_akee@live.com
Aug 16, 2011 | ASUS P5GC-MX/1333 Motherboard
My Samsung G2 Portable external hard drive, 640GB, when i am copying stuff unto it, it is very slow. I just got it new
If you're using a desktop try checking the speed of your USB thru bios setup. Here's a sample below, Change fullSpeed to HiSpeed.
1. To access bios setup, press Delete on your keyboard. 2. Look for the USB configuration. 3. Just change the settings on USB Controller Mode nothing follows. 4. Save and exit. pcsyke_53.jpg
Hopefully this Helps. Thank you for posting.
Jul 08, 2011 | Samsung G2 Portable External HX-MU032DC/...
My printer is plugged into one of the two usb ports at the front but I got a message saying it would run faster if it was plugged into a high speed port which when I checked it says I have 8 of but where...
Usually the main usb ports for the pc will be on the rear panel of the machine. If you feel safe to do so, switch the machine off and unplug from the power source, remove the side of the machine and touch a piece of bare metal on the chassis to remove any static build up in your body, then have a look around on your mainboard, try to trace the cable from the front usb connections to the mainboard, and see if there is a usb2 version of the socket which they are plugged into, swapping to this may solve your problem.
Hope this has been helpful.
May 06, 2011 | Dell Dimension 3100 PC Desktop
Please can you give steps to disable the onboard usb controllers to use the CPI USB Card. I've installed the PCI Card after the onboard stop working
2.4.2 USB Configuration
The items in this menu allows you to change the USB-related features.
Select an item then press <Enter> to display the configuration options
USB Function [Enabled]
Allows you to enable or disable the USB function.
Configuration options: [Disabled] [Enabled]
Legacy USB Support [Auto]
Allows you to enable or disable support for USB devices on legacy
operating systems (OS). Setting to Auto allows the system to detect the
presence of USB devices at startup. If detected, the USB controller legacy
mode is enabled. If no USB device is detected, the legacy USB support is
disabled. Configuration options: [Disabled] [Enabled] [Auto]
USB 2.0 Controller [Enabled]
Allows you to enable or disable the USB 2.0 controller.
USB 2.0 Controller Mode [HiSpeed]
Allows you to configure the USB 2.0 controller in HiSpeed (480 Mbps) or
Full Speed (12 Mbps). Configuration options: [HiSpeed] [Full Speed]
BIOS EHCI Hand-off [Disabled]
Allows you to enable support for operating systems without an EHCI
hand-off feature. Configuration options: [Enabled] [Disabled]
NOTE!!!
Do not disable the BIOS EHCI Hand-Off option if you are running a
Windows® operating system with USB device
hope above given details with give you a detailed description as you desired.
good luck
Feb 04, 2010 | ASUS P5LD2-VM Motherboard
Usb 2.0
Yes, your M2V board is USB 2.0 complaint.
How do know if your PC has USB 2.0?
You can identify whether your PC has Hi-Speed USB or relatively easy. Open control panel, open System. Click the Hardware tab & Click Device Manager.
Scroll down to Universal Serial Bus Controllers. Click the + sign to expand. There should be an "Enhanced" USB host controller present. Windows 98 systems may use a different name, because Hi-Speed USB drivers in this operating systems are not provided directly from Microsoft, (Windows ME, 2000 and XP)
get their drivers through (Windows Update). There should also be two "standard" version USB host controllers present as well. They are embedded in the USB chip which routes the differing
USB speeds accordingly without user intervention. nVidia (shows as "Standard" controller) & not enhanced but are still USB 2.0
You need to enter your bios. How to enter your bios?
When you turn on your Pc press the delete key every 2 or 3 seconds. Your system will load the bios. Use your manual & go to pg. 4-16 section 4.4.2. Make sure you have Enabled USB 1.1 & enable USB 2.0. Enable Legacy USB support & set USB 2.0 Controller Mode to HiSpeed. Bios EHCI Hand-off, set to Enable
Save & Exit your bios. When your system has finished loading run Windows Update. This will update your USB driver to 2.0
How fast is USB 2.0? USB 2.0 has a raw data rate at 480Mbps.
If you have more question just ask!
please vote...
Feb 12, 2008 | ASUS M2V Motherboard
Usb 2.0 problem
If you do turn off USB 2.0, you may have two options, "Full Speed" and "HiSpeed". Make sure you use "Full Speed", as it's faster than "HiSpeed". But the real answer is that you need to install the USB driver for your motherboard. If it came with a CD, insert the CD and read the instructions on installing drivers from it; otherwise, check Asus's website under the Support/Downloads section.
Oct 01, 2007 | ASUS A8N-SLI Premium Motherboard
ASUS P5GD1-VM Motherboard Logo
268 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
