Question about E-Machines Bestec ATX-300-12E Rev. D 300w E-Machine GTW Power Supply Part 100929 (ATX30012E) Power Supply
I cannot get my w3611 machine to turn on, what can I check?
  • E-Machines Master
  • 5,660 Answers
Replace the power supply. 70 to 80 percent of the computers that come to my shop are dirty inside, and the power supply has failed because of this.
Even if you get a green power light, your power supply isn't supplying enough power to turn the processor on.
All the lights use less than 1 Watt.
EACH fan uses 2 to 3 Watts
Harddrive just sitting there spinning, uses about 3 to 5 Watts.
When it's time for the processor to turn on, the power supply can't handle it. Not enough power! Processors use 55 to 125 Watts, depending on the processor!
Posted on Jul 02, 2009
Emachine w3611 power button blinks but won't start computer
Try unplugging from power source and leaving for about three minutes and then plug it back in.
May 12, 2015 | eMachines W3611 PC Desktop
Monitor says no signal when turned on
Check the memory cards are inserted correctly (remove and reseat)
Dec 27, 2013 | eMachines W3611 PC Desktop
How to get hdmi on emachines model w3611 without buying anything, is there a plugin inside?
No. The W3611 only has a VGA output on the motherboard. To add an HDMI port, you will need a video card. If you choose an internal card, the machine will probably need a better power supply (400W or higher). You will also need to remove the card that is currently in the PCI-e x16 slot (probably the Fax modem).
There are some external video adapters that connect to the USB port. Some have HDMI out. However, if you want to play games or moves, these are often not a good option. They are limited by the USB 2.0 port.
CNET gives the specifications for the W3611 here: http://reviews.cnet.com/desktops/emachines-w3611/4507-3118_7-32329686.html .
I hope this helps.
(no computer has "hidden" video output ports. All have to be visible from the outside of the case.)
May 01, 2013 | Computers & Internet
I just need to re set my e machines w3611 the way i got it from the store
I think you can't reset that thing, but you can reformat the program that e machines
Apr 11, 2011 | E-Machines Computers & Internet
Upgraded memory in W3611. Won't start. Gives three long beeps instead. Restored old memory. Won't start. Gives three long beeps instead.
Remove RAM(S), clean the ram slot by blowing air, fix RAM(s) back in position untill both the side clamps are properly locked.
If problem persists try resetting motherboard via jumper pins on the motherboard.
Sep 03, 2010 | eMachines W3611 PC Desktop
Who manufactures my w3611 cd drive so I can load
Hi
They use a variety of different drives and in all fairness the operating system should install the drivers for the device automatically. The only software you may need to obtain would be something like nero to enable you to burn items to disc, but even then windows itself is capable of doing this.
Thanks
Taz
Oct 28, 2009 | E-Machines emachines (emachinees) CD-ROM...
Freezes while trying to do fresh install from
this indicates a bad hard drive, or Ram or both
Jul 29, 2009 | eMachines W3611 PC Desktop
Motherboar reconected
Remove the hood, and double check that all of the cords and wires are correctly plugged in and secure. Hope this helps, Thanks
May 27, 2009 | eMachines W3611 PC Desktop
Repalcing video card in emachine w3611
no signal try open your system unit get the memory then put it back then try to switch on your computer
Apr 07, 2009 | eMachines W3611 PC Desktop
My emachine w3611 revs up and makes noise
try take it apart and remove any wire on the way of the fan.
Dec 27, 2008 | E-Machines Bestec ATX-300-12E Rev. D 300w...
E-Machines Bestec ATX-300-12E Rev. D 300w E-Machine GTW Power Supply Part 100929 (ATX30012E) Power Supply Logo
232 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
