Question about Microsoft Xbox 360 Elite Console
No picture just sound
My xbox 360 has sound but no picture,when turned on the lights on the front are red instead of green. I borrowed someone elses cords but it does the same thing.
    Filmmaker:
    Uploaded 5 video answers.
  • 182 Answers
Ur xbox 360 is in high def turn ur xox 360 with ur controller and hold r trigger and y button together till it turns on. if it dont work than u got the rings of death try this there are fans in the back of ur xbox 360 put a straw on each to stop the fans from spinning wait till it has two red lights than disconected from the back and wait 20 minutes and try it see if it work. if it work this is just a temperary fix.
Posted on Jul 02, 2009
Cleaning disc areas, now 360 won't turn on when restarted
First of all I highly recommend not opening your Xbox 360 unit unless you are certain you know what you are doing. It's very easy for someone to make a problem worse instead of better.
Have you checked the light on your power brick? It should be yellow when the console is off. When you hit the power button does it turn green, stay yellow, or turn red? If it turns red, you have a serious problem and need a qualified technician to look at your machine immediately.
Jan 01, 2010 | Microsoft Xbox 360 Console
Xbox console will not run
usually orange light is a video problem check your av lead on the xbox suggestion borrow someone elses av lead to try
Feb 18, 2009 | Microsoft Xbox Console
My xbox 360 has no picture but sound only no red lights green ok
First take off my hard drive on the 360. Then plug it to the tv not with HDTV (use the red, yellow and white make sure it is on tv not HDTV) because it will not work for HDTV setting . then plugit into the wall with the 360 laying down not up and down and turned it on. (no picture but sound) with the 360 on take 1 towel fold it long ways and wraped it around 360 from back to front (make sure you cover the fans in the back to make it over heat.) leave your 360 on until it red rings (you can hear the 360 quit down. it takes about 15-30 mins depending on how fast it over heats. once this happens unwrap the 360 and turn it off wait 5 secs and power it back on and there you go you should have picture and sound again. if you still have problem you can now can send it to get repaired since there is a 3 year warrenty for red ringed 360's.
Feb 15, 2009 | Microsoft Xbox 360 Console
Xbox 360 3 lights, tried the fix still have 2 lights
2 Red lights displayed on the front of an Xbox 360 indicates it is overheating here are some solutions provided by Microsoft
http://support.microsoft.com/kb/907533?sd=xbox
If it continues - Under the circumstance that you have not voided your warranty or allowed it to expire you can send your 360 away to get a replacement.
Hope this helped ;)
Blazamane
Jan 07, 2009 | Microsoft Xbox 360 Console
Have sound no picture and 2 green rings around power button
They are green?!? usualy when people have problems with  the xbox 360 hardware, the lights turn red. This xbox 360 may have a birth defect... Best thing to do is call 1800-4my-xbox. Talk to a representative about sending your xbox in, ONLY if you have not voided the warranty. If so, you will most likely have to buy a new xbox or new motherboard for it.
Also try changing your video settings to tv instead of hd, or hd if it is plugged into a hd tv. You might have toggled the HD switch on the video/audio chords.
Dec 31, 2008 | Microsoft Xbox 360 Console
When i turn it on there's no picture
Replace your cables for the xbox im betting one of the contacts i worn, borrow a set from someone if you can and see if it fixes it.
Dec 12, 2008 | Microsoft Xbox 360 Console
Xbox360 and the 3 red lights
Three of the lights on the Ring of Light on the front of your Xbox 360 console flash red View products that this article applies to. if (!loadTOCNode) {var loadTOCNode = function(){}} Expand all | Collapse all if (kb_page_object) { kb_page_object.kb_imageExpandHoverText = 'Click to expand this image'; } SYMPTOMS Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360... loadTOCNode(1, 'symptoms'); Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360 console. The upper-right quadrant light is the only light that does not flash red. uparrow.gifBack to the top CAUSE The three flashing red lights may indicate that there is a hardware problem with... loadTOCNode(1, 'cause'); The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. uparrow.gifBack to the top MORE INFORMATION If you are experiencing this problem, you can submit a console-repair request on... loadTOCNode(1, 'moreinformation'); If you are experiencing this problem, you can submit a console-repair request online. However, before you submit your request, first try the following two steps to verify the problem:
  1. When you turn on the console, look at the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply light is not green, please follow the steps in one of the following Microsoft Knowledge Base articles: 906101 (http://support.microsoft.com/kb/906101/ ) Troubleshooting your Xbox 360 Power Supply when the light is red 906102 (http://support.microsoft.com/kb/906102/ ) Troubleshooting your Xbox 360 Power Supply when the light is orange 906103 (http://support.microsoft.com/kb/906103/ ) Troubleshooting your Xbox 360 Power Supply when the light is not illuminated
  2. Turn off the console. Wait 10 seconds, and then turn on the console again to see whether the problem re-occurs.
If your console continues to display three flashing red lights, your console may have to be repaired. For more information about how to start the repair process online, please visit http://www.xbox.com/support (http://www.xbox.com/support) , and then click Repair your console in the upper-right part of the Web page. Note Online console repair service is currently not available in all countries and regions.If you want to instead contact Xbox Customer Support directly, please visit http://www.xbox.com/support/contact (http://www.xbox.com/support/contact) for information about how to do this.
Dec 06, 2008 | Video Game Consoles & Games
RED RING WHEN TURNED ON OFF FOR A WEEK
Nov 26, 2008 | Microsoft Xbox 360 Console
My xbox 360 is not displaying any picture just sound
its overheating but will give u red light eventually try googling X-Clamp fix i fixed many with same problem
Mar 21, 2008 | Microsoft Xbox 360 Console
Xbox 360-Red to Green
Look on the back of your tv and make sure that the red and blue cables are plugged into the right slot on the back of your tv. This would be the most common cause for something like this that you are describing.
Feb 09, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Elite Console Logo
83 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
