Take a look inside your camera's CF card slot. I suspect that you may have a bent pin in there. If so, you may elect professional repair (likely more than you'd be willing to pay), or you might want to try the following.
Remove batteries and card. Use a small/skinny jeweler's flat screwdriver to bend the pin back as close as possible. The jeweler's screwdrivers that you see at the dollar store will work fine. Another tool that I sometimes use is a stiff wire with a bent hook on the end to get very flattened pins started. Take your time and use as much patience as you can muster (take a breather in between if needed). Just keep nudging it upward/straighter a "tiny bit at a time". Whatever you do, don't try to unbend it with one push/nudge, you won't be able to do it.
It doesn't have to be perfect, just as close as you can get it. When it's the best that you can get it, take your flash card and "SLOWLY" insert it. The card itself should fine-align the pin. Remove the card, and verify that the pin is still straightened. If so, reinsert the card and try it out.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Canon Digital Rebel XT / EOS
I hve been offered an unused Canon 5D Mark II body only for $1500, serial number 1120704112. As...
(More)
I hve been offered an unused Canon 5D Mark II body only for $1500, serial number 1120704112. As such bodies are upwards of $2500 I'm wondering if it's stolen, gray market, or repaired. Anyway of telling? thanks
I have a Canon Rebel Xt that occasionally has problems with the shutter button suddenly not working....
(More)
I have a Canon Rebel Xt that occasionally has problems with the shutter button suddenly not working. The camera is still on and all the menu buttons continue to work. It acts like the lens decides to quit communicating with the camera body. The only fix I have found is to take the battery out for 10-15 sec. and it works like normal. Any advise on whats going on would be great, Thanks Brandon
