Question about Sony Handycam CCD-TR416 Camcorder
Broken power switch button on Sony CCD-TR416. I have unscrewed the front lens cover and can see the problem but am not sure how to fix it. Is there a technical manual that shows how parts go back together?
  • 73 Answers
U must to chaing that switch
Posted on Jul 09, 2009
How do I transfer videos from a sony handycam ccd-tr416 to my laptop?
You need a video capture tool (Composite A/V to USB dongle) and the software for it. TigerDirect has a number of them: http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=1428 . Walmart and Amazon also have these devices. You'll need to know the OS (particularly the 32-bit or 64-bit designation if you have XP or higher) for your laptop. Then check to make sure that the manufacturer of the dongle has written drivers for your OS.
You'll have to decide whether to use the L or R audio channel on the dongle.
I hope this helps.
Aug 28, 2014 | Sony Handycam CCD-TR416 Camcorder
Error code c:48:00
You may take following steps to resolve your problem.
1) Remove the disc and insert it again, then operate your camcorder again.
2) Remove the power source(unplug the power cable from the power source). Reconnect it again and operate your camcorder again.
3) switch off camcorder,Change the cassette. Press RESET, and operate your camcorder again.
hope this solution will solve your problem.
Good luck and rating the solution is appreciated please.
Aug 17, 2010 | Sony Handycam CCD-TR416 Camcorder
How can I transfer the video from a Sony Handycam CCD-TR416 to CD or DVD
How to Transfer video from Sony Handycam CCD-TR416 to DVD - You need a DVD Recorder / Player, connected to your TV. Then using the audio / video cables from your camcorder, connect them to the TV as well. Turn your TV on so that you can watch the video out from your camcorder and then select the record button on your DVD Recorder / Player. Then you have a DVD that can be watched in any DVD Player or Computer with out any compression. This is how I transfer my camcorder tapes to DVD.
Aug 10, 2010 | Sony Handycam CCD-TR416 Camcorder
Tape door wont close on my Sony CCD-TR416 camcorder
Try this for anyone having this issue:
HERE'S WHAT WORKED FOR ME PER SONY TECHS:
Take? OUT the battery or disconnect the AC cord.
Turn the camera ON (tape, memory, edit settings) for 15 seconds.
Turn camera to off setting.
Plug battery or AC cord back in.
VOILA!
Worked for me and I had the stupid C32:11 error code for weeks! Door would not close. Followed the SIMPLE and SAFE instructions and IT WORKED! Just like magic. I couldn't believe it! Save your money TRY THIS!
Sep 22, 2009 | Sony Handycam CCD-TR416 Camcorder
How do i transfer my sony handycam ccd tr416
Use the link below to transfer video to your Computer using A/V cable and the Video Capture software.
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&externalId=C428275
Aug 07, 2009 | Sony Handycam CCD-TR416 Camcorder
Sony handycam ccdtr416 ntsc
Its an old model and user manual is available on charge basis.
Jul 26, 2008 | Sony Handycam CCD-TR416 Camcorder
Sony ccd tr 416 camcorder replacement part
Dear Sharma,
Its an old model and hard to get parts in stock. Do you really want to repair it? If yes, I will try to give you required part/ board.
Jul 23, 2008 | Sony Handycam CCD-TR416 Camcorder
SONY HANDYCAM DCR-40
Lens cover error message comes when its not opend. There is a switch inside Front Cover (where lens and mic mounted) got bad contact. Open that Front cover and unscrew the circuit board, put 1 drop of W-40 cleaner oil and fix back all things.
Apr 27, 2008 | Sony Handycam DCR-HC40 Mini DV Digital...
Insert the tape
There are a variety of things that can go wrong. The process of elimination starts by taking the 2 screws out of the cover and removing. While the compartment is open, push the eject button and observe if there is any motion with gears or not. The main cam gear should rotate a few degrees in one direction and then back. If you see no motion at all then you have problems that are going to require real work. Most often when this is the situation, this main gear, which doubles as the mode switch, is broken and this is a sophisticated repair to replace.
Jun 26, 2007 | Sony Handycam CCD-TR416 Camcorder
Camera doesn't recognize lens cover...
I rednecked the crap out of mine. I pulled off the slide cover and placed a small piece of paper clip in the area of the copper to make a permanent contact. Then duct taped it secure and then cover the whole slide mechanism. I would not recommend this method but it worked.
Apr 28, 2007 | Sony Cyber-Shot DSC-T5 Digital Camera
Sony Handycam CCD-TR416 Camcorder Logo
113 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
