PM800-8237-6A7L2B0DC-00 WARNING! CPU has been changed or CPU Ratio changed fail. Please re-enter CPU Setting in the CMOS setup and remember to save before quit! press F10 and Y for save. Re-start, and the problem it yet
  • mr Overland May 11, 2010
    this your MB biostar P4VMA-M
    President:
  • 948 Answers
If you have correctly set the CPU in the BIOS, and saved the settings and still get the error, the CPU is not compatible with your system.
Most likely you have not set the BIOS right or have not saved it.
Posted on Jul 02, 2009
AFTER SWITCHING ON, SCREEN STAYS FROZEN AFTER SAYING CMOS CHECKSUM ERROR- DEFAULTS LOADED
When starting your PC, the following error message is displayed:
CMOS wrong
CMOS MEMORY size WRONG
CMOS Checksum Bad
CMOS checksum error defaults loaded
Warning! CPU has been changed please re-enter cpu settings in the cmos setup and remember to save before quit!
You are prompted to:
Press F1 to resume
Press F2 to load default values and continue
This is due to the fact that the CMOS, which contain data related to the BIOS, has been reinitialized and that your PC has been reset to factory settings.
Solutions:
Reinitializing the BIOS
  • Change BIOS battery
    • If the problem persist this may be due to the fact that the battery powering the CMOS (when the computer is shut down allows the CMOS to store information), is depleted.
    • The CMOS battery is a small pin found on the mother board, you can refer to the manual provided with your motherboard to change it or have the nearby computer technician change it for you if you don't want to risk any damage.
    • More information with: Replacing the battery of your motherboard (CMOS battery)
Post back if it is not working we will be happy to help you.
Hope this helps.
Cheers!!!!
Jan 12, 2011 | Sharp Actius PC-RD10 PC Notebook
Cpu ratio has been changed?
Boot the computer while pressing the "F2" key
May 23, 2009 | Everex IMPACT GC2500 PC Desktop
CMOS Battery do no work
Just change your CMOS battery with a new one and after that goto the bios settings and update the time and dare.
After that just save the settings and then check that the warning message is coming or not.
If its coming then it means you need to change the CMOS jumper settings.
Mar 09, 2009 | Asrock 845GV (P4I45GV) Motherboard
CMOS setting distrubed for mercury PVM7 ver 1 board
just press del to enter to the cmos and then change the date and time of cmos and press F10 to save your configeration if you start the cpu again and if you see the message "press F1 to continue and del to enter bios it time to replace your cmos battery inside of cpu is like a coin inside of your computer
Nov 24, 2008 | Abit AB9 Pro Motherboard
I'M TRYING TO SEARCH IN THE WEB BUT I CAN'T GET
Normally Checksum errors mean that the Battery on the board may not be holding a charge any longer. Best suggestion that I can give is to replace that battery. You can buy it in any electronics store. Just make sure to buy one with the EXACT same size. If that still does not work you may ahve to update your BIOS you can message me about that.
Sep 02, 2008 | Computers & Internet
I tried to add memory ram to my computer, but it was not compatible and now my computer does not start. the monitor only shows me a "CMOS ERROR" AND warn me that my CPU has been changed or the...
if you put your old memory in and boot into bios setup and go to default or fail safe settings that should work then get the right memory that u need and install as usual
Aug 20, 2008 | Systemax Computers & Internet
Problem with my BIOS CMOS Setting
Its due to your default CMOS setup does not match with your CPU configuration especially with CPU speed.
  1. To fixed the above problem goto BIOS and navigate settings of CPU, speed etc. Set the speed with the proper value as per manual. And save the settings.
  2. Infuture when you will load default, at that time also set the CPU settings.
  • The CMOS battery might not be connected properly or may be its not producing enough power as per needed by board. So have a look with another battery. Also clean the connection point of the CMOS battery.
Good Luck
Iqbal
Apr 22, 2008 | Biostar P4M80-M4 Motherboard
CMOS Checksum error - Defaults loaded
When the CPU speed stored in BIOS and the actuall speed of CPU differs then this error comes.
To fix this you have to select the actuall speed of your attached CPU to the board. Just set the actuall speed and save the changes. It will fix your problem.
Thanks
Iqbal
Mar 23, 2008 | EliteGroup P6STP-FL Motherboard
Buying Used Pc but cannot get pass password
hi
first check your cmos cell and change it if it is old.then start your pc press del key untlii enter in bios setup.if it need password then power of the system and put away your cmos cell in your pc mother bord 15 minutes away then after 15 minuts put the cell in its position.then start pc again.
now
in bios setup go to the first cmos setup set your systm date and time .then go to second advanced option detect your hard disk and cd rom.
then press ESC key then y key to save changes in bios setup.
then your pc start.
Mar 18, 2008 | Computers & Internet
Monitor on but not working properly
If you just built the computer..the motherboard will give you a warning that some hardware has changed. you have to connect your keyboard and go into the bios and make sure everything is right. To be safe select set to default factory settings , save and reboot the computer. This is to prevent the settings for a previous cpu be used for the new one.
Feb 24, 2008 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Computers & Internet Logo
292 people viewed this question
Alun Cox
David Payne
David Payne
