Question about Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television
I have a HCN 4727W model rear projection tv and it will not produce a picture when I turn the tv on.....worked once today, then gone later after I turned off the tv...
    Problem Solver:
  • 8 Answers
Might have to replace the stk/convergance board model number BP95-00142p its 100.42 plus shipping cost that should fix your tv hope this helps...
Posted on Aug 16, 2009
  • 50 Answers
The bulb may have gone out. call a tv repair shop. search google.
Posted on Aug 07, 2009
Philips Magnavox 9P6031C103 projection tv quit working 2 years ago (before, the picture began to shink and expand until it finally quit completely with no audio nor video -- turned it on two years later to...
Based on what you described I would say your TV has the "shrinking and expanding" fault. Its a common problem on that model and the symptoms can range from the video shrinking and expanding or no video or no audio....You can read more about this fix on the site www.TvRepairKits.com
Jan 13, 2013 | Philips Magnavox 9P6034C 60" Rear...
WS-55805 55" screen that I've had since 2000. Always worked just fine until today! No picture, just sound.
Check Your Rear Projection Light Open Back Cover it a little Door on the back ov your TV Set Possibilty Light Burn Out ....Cause of this Problem Fan Malfunctioning Or The Bulb as to be change for new one ... Type The Brand and the Model ov your TV According To your Model it will gave you a list ov different Light Projector Make Shure You dont Touch the bulb with your bare Hand when you put it On Because those light produce very hi Temperature and cant burn out immediatly or explode.
Sep 22, 2010 | Mitsubishi WS-55805 55" Rear Projection...
Philips 55PW9363 hd tv has sound but no picture. Was working fine before it was turned off and this happen when it was turned on about an hour later.
You may have a bad, small signal board. Once in a while you may get a picture back....if the TV has been unplugged and plugged in after a few days.
Jan 30, 2010 | Philips 55PW9363 55" Rear Projection...
Picture tube
Ur tv tube it still good.It ur deflection board have burn capacitors and transttors.The Fly back transformer is dead also,that where the noise came from.
Dec 07, 2009 | JVC HD-61Z575 61" Rear Projection...
No picture
Your sweep module has gone out. Probably be lucky if can find part for this set.
Sep 08, 2009 | Zenith IQA56M98W 56 in. Rear Projection...
RCA Rear Projection problem
the problem with that is probably that your blub has gone out and need to replace it.
Sep 24, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Picture is concave on top and bottom. With ed and green ghosts.Worked fine, turn set off and on about 15 minutes later and picture was as described. Help!
The convergence chips in your tv have gone out. They control the three picture tubes and align them so that they create one picture on your screen. I recomend having a qualified technican replace them and realign you convergence. Thanks.
Apr 02, 2008 | Akai PTH5498 54" Rear Projection...
No sound or picture
HLP, HCN HL-S The Start-up Problem or/and
3 LEDs in the front blinking.
Unplug the set, pull out the lamp module (not all the way - leave it on the track) and push it back in.
Power issues (Tv not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
Sep 29, 2007 | Samsung HLN467W 46" Rear Projection HDTV
Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television Logo
147 people viewed this question
Jerry Greenberg
Jerry Greenberg
