Question about Hitachi Televison & Video
I have a Hitachi model 50V69A and have large yellowish spots on screen. It is most noticeable when watching programs with light background, like hockey games..
I havw a simialr problem mine is a blue stripe toward the center of the screen. The problem is most likely from the blue lens on mine or the yellow on yours. I was able to adjust it out somewhat and I am still tweaking it by using a setting in the technical menu called stripe.
You can access the technical menu by pressing the fowllowing on your remote:
MENU +MENU+ 8 + SELECT
Hope this helps
Posted on Jul 14, 2009
We have a hitachi ultravision model # 50vs810 made in 2005 our problem is when we turn it on the screen seems as if the whole thing should be kinda blue but the corners are kinda black then when we play...
Your TV has a defective optical block which should be replaced by a TV technician only. Due to the cost of the part and labor, it is almost less expensive to replace the TV. The part number for the optical block is UX23751 and is available at the following web site. I hope that helps : )
http://www.partstore.com/Part/Hitachi+Ltd/Hitachi/50VS810/Hitachi+Ltd/Hitachi/UX23751/New.aspx
Jul 25, 2011 | Hitachi Televison & Video
Having a big yellow spot background in the middle of the picture.
Hi , it seems you are experimenting a light engine problem.Here's how your tv works: http://www.youtube.com/watch?v=ZLLHnQ4y-wo Basically there's 3 LCD chips that create the colors and image by blending together.When these chips start to melt you will get those blue spots, pixilation even vertical lines.You will need to replace the light engine. Have a blessed one!
Apr 09, 2010 | Hitachi 50VS69 50" Projection HDTV
My Hitachi 60VG825 projection TV is 3 years old. For the past several months the screen has been turning blue around the outer edges & this past week a large yellowish green spot the size of a...
Sounds like Calibration is needed on the projection internals. Your TV uses a rear-projection system and the problem is either in the imaging LCD Unit or the light filter. I see in a previous thread you have changed the bulb. You can invest in a voltage regulator to keep the hardware in factory condition.
Also you can burn a DVD of a stuck pixel remedy video and run it on the screen with full brightness and full contrast. This is used for plasma burns and stuck pixels on conventional Flat panel TVs but can repair color issues with projection systems. This therapy is focused on the imaging unit between the projector and the main drop of your tv.
please feel free to post a more in-depth description or any changes
Nov 06, 2009 | Hitachi 60VG825 60 in. LCD Television
Blue spot on screen
there are light filters at each of the 3 lcd panels in the optical engine with a coating on them that determine the color. one of them (most likely the blue) is burnt from the heat and needs replacement. it could also be the fly-eye lens (whick evenly distribute the light) has burned as well. either way, it's very involved to replace, if you can get the parts. it's easier to have it sent in to get repaired.
Jul 31, 2009 | Canon LV-LP11 Projector Lamp for LV-7345,...
I have a sony KDF - 60 WF655 projection tv
SONY HAD A RECALL ON THE KDF50,52,55,AND60. CALL SONY
Mar 19, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Bluish hazy texture on my screen
It sound like the light engine is going out or already out. I would take it to a certified Hitachi dealer have them check it out then I would call Hitachi to have them fix it for free.
Nov 14, 2008 | Hitachi 50VS69 50" Projection HDTV
Yellow spot in center of screen
I have recently developed the same yellow spot problem on my Sony KDF-E50A10  50" LCD television...a large yellow circular hue that takes up the bottom center of the picture and is especially noticeable against a white background.  It has been diagnosed as the optical block (light engine) and without an extended warranty Sony refuses to assist with the repair cost.  Repair was estimated at $1,100 plus tax and travel fees to my home.  So you see, it is not only a Hitachi problem.  You would think they could build something that would last more than two years considering the initial cost of over two grand for the TV !
Jan 03, 2008 | Hitachi 50V710 50" Rear Projection...
Red spot when screen is black
Your light engine will need to be replaced as you have a LCD panel failure. Here is the link to the part number for the model 50V500 if you have the 50V500A it has a different part number. http://www.partstore.com/ProductDetail.aspx?ProductSKU=8286849&ProductType=PART&ModelID=374014
Mar 14, 2007 | Hitachi 50VX500 Television
Televison & Video Logo
310 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
