Question about Samsung LN-T4671F 46 in. LCD Television
Seemed to short circuited through power surge from
Seemed to have short circuited through power surge from tree limb falling on outdoor power supply. TV turns on, but all touch features on the TV itself do not work and any button I push on remote either turns off or on TV and that is all (Doesn't matter which button I push). Fixable? Any thoughts? Reset?
  • 1 more comment
  • jswinger Jul 17, 2009
    Thank you, that is exactly what is happening, so that is great in validating the work being done. Thank you!
  • Anonymous Mar 21, 2014
    Samsung LA40B530 40 in. HD-Ready TV fuse again and again short circuiting in power supply area
  • Anonymous Mar 25, 2014
    power surge. Had power outage caused tv to have no power. do i have a reset button or did it die because of power outage,,,
  • 304 Answers
You have a bad Main bd. Have a trained Samsung tech repolace the Main bd.
Posted on Jul 17, 2009
What are some tips to cut tree limbs by a pole saw?
safety helmet
safety glasses
cut smaller branches first
cut small lengths
have a friend as a look out for power wires and other obstructions that branches can fall on
never cut while on a ladder
use a trestle and not a step ladder
Apr 09, 2018 | Garden
What is the benefits of using a telescoping limb saw?
hi,the benifits are that you can reach the limbs you need to cut from the ground,hope this was of some help all the best.
Mar 14, 2018 | Garden
When and How Should a Surge Protector Be Used on a Fixed Switch?
Common Causes of Lightning Strikes
  • Outdoor network cables or power cables are routed overhead.
  • A switch is deployed outdoors but is not properly grounded.
Damages of Lightning Strikes
  • If power cables of a switch are routed overhead in an outdoor environment, lightning strikes may burn the power supplies.
  • If network cables of a switch are routed overhead in an outdoor environment, lightning strikes may burn interfaces of the switch.
When a switch undergoes lightning strikes, overvoltage is induced by lightning on network cables and transmitted to interior of the chassis. The surge protection measures, such as lightning rod and chassis grounding cannot prevent the damage. Therefore, surge protectors or surge protection circuits are recommended.
Surge Protector Use Precautions Take the following precautions to protect a switch from lightning:
  • Ensure that the ground cable is connected to a ground bar or a ground point on the cabinet.
  • Avoid routing cables overhead in an outdoor environment. Bury cables underground or route them in steel tubes.
  • To protect network interfaces against lightning, use 8-line surge protectors (or Huawei certified 4-line surge protectors).
  • When installing a network interface surge protector, connect the IN end to terminals and the OUT end to network interfaces of the switch.
If a fixed switch is installed in a network box, follow these instructions:
  • Connect the ground cables of the switch and surge protectors to the ground bar in the network box.
  • The maximum length of a ground cable cannot exceed 40 cm, and a length of smaller than 15 cm is recommended.
  • If the network box is located outdoors and power cables are routed aerially over a long distance (more than 300 m) to the network box, it is recommended that you install a power supply surge protector in the network box. The decoupled power cable must be at least 3 m long
S2300 Switch Thunder link com
Dec 08, 2016 | Office Equipment & Supplies
Maple tree spots on limbs
may be Verticillium wilt.
May 12, 2014 | Garden
Completely loose tv hd signal for days then signal comes back
Sounds like you have a loose cable ( either inside or outside ) that allows moisture in. Or you might have a tree limb or other obstruction.
Mar 15, 2013 | One For All OUTDOOR HD ANTENNA RCA ANTENNA
I have a kitchen aid electric range kesc307hbs8. we lost electricity one day and when it went back on the stove began to smell burTt. the range heats up but the control panel and touch pad are not working....
Hi.It is advisable to turn off your fuse or appliance when there is a power outage..When the power turns back ,it will produce surge amount of voltage that would eventually damage your appliances.when power comes back it has a very abnormal current flow.it may rise or fall which might beyond the wires capability.meaning it goes beyond what the wire can carry..It might be that when the power supply return it gives high current and short circuit the ground and live wires of your electric range.You better check continuity using an OHMETER.MULTITESTER if there is no short circuit.If the reading of the multitester if set to ohms is too high thats beyond the maximum amount going to the right,then there is a short circuit..
Jun 28, 2011 | KitchenAid KESC307 Electric Kitchen Range
ATX-300-12Z was hit with a power surge (thought we had a surge protector). Green light on power supply blinking at 2X/second. No power at USB devices (or anywhere else.) PC was on when surge hit.
There were 2 Switching power supply circuit inside the ATX PSU. There's a Standy PWM circuit whichSupply +5V to the PWM IC of the Main PWM. Stand by pwm still working or insufficient voltage, lower than +5V. This is the reason you still have Green light. Check or replaced small filter capacitor around 100 MFD 16V, open resistor or shorted diode that was nearest of the PWM IC..
Watch out for charge voltage on big capacitors.
Rleo
Dec 30, 2010 | HP ATX-300-12Z (ATX30012ZBD) 300-Watt...
What's the best way to use my 16 in electric saw to cut off tree limbs?
This is somewhat subjective. Eveybody does it a little different.If you are cutting limbs from a tree, start an undercut about where you want the limb to fall free of the tree. Use the upper edge of the chain to cut it about a fourth of the way through. Then start from the top of the limb over where you made the undercut.
Sep 25, 2010 | Remington 16" Electric Chain Saw
Tv broken?
YOU WILL HAVE TO REPLACE THE POWER SUPPLY IN THE TV
Aug 24, 2009 | Samsung LN-T4671F 46 in. LCD Television
Samsung LN-T4671F 46 in. LCD Television Logo
285 people viewed this question
Jerry Greenberg
Jerry Greenberg
