Question about Epson Stylus C88 InkJet Photo Printer
Feeder problem epson cx3700
Hi all, im having a problem with my espon stylus cx3700 printer/scanner/copier. it wont feed the paper through. have checked for jammed paper and nothing there. when it goes to start printing and feed the paper through it starts to pull paper in towards one side and sort of chew it,but wont actually go though. HELPPPPPPP
Inky
  • 691 Answers
SOURCE: Epson stylus photo 830
Yes it can probably be fixed. I hope you poked your friend in the eye for giving you such a headache though. You will need to dismantle the machine and remove the Auto Sheet Feeder (ASF) Once removed, check there is no bits of paper stuck inside. Then turn the pick up mechanisme by hand through a couple of revolutions to re synch everything. Also check the paper sensor is still intact - if not you can construct a new one from a piece of plastic or if the old one is still present, just glue it back together. You can download a service manual to hep you out with the dismantling from either: http://www.TheServiceManualShop.com http://mikeburton.tradebit.com/
Posted on Apr 12, 2007
SOURCE: I Have An Epson Stylus DX6000 Printer Problem
Yes I had the same problem. Well we looked online and found the answer. Pick up the printer and shake upside down (Carefully) and an EPSON badge fell out. On reboot of the printer the error E-04 solved. Printing happily. Well it worked for us.
Posted on Jul 24, 2008
  • 4 Answers
SOURCE: Epson Stylus CX8400 Paper Jam Error
I have the same exact problem of paper half torn removed but I can not see the other half anywhere. The printer has hardly worked for at the most six pages and now showing paper jam error. How do I fix it?
Posted on Aug 12, 2008
SOURCE: Printer will not feed paper correctly
I had the exact same problem and it was a foreign object (*** end lol). I fiddled about abit then turned the printer upside down, gae it a few taps and it was fine.
Posted on Aug 21, 2008
SOURCE: problems with paper feeder-wont feed through-chews up paper
I HAD THE SAME PROBLEM A MONTH AGO. I LOOKED WHERE THE PAPER LOADS AND THERE WAS A PAPER CLIP JAMMED IN THERE. I HAD A HECK OF A TIME GETTING TO IT, BUT I DID. AND IT WORKS FINE. MAYBE SOMETHING IS THERE.
Posted on Feb 01, 2009
Paper not feeding for epson nx400
Check the following:
  • If paper doesn't feed, remove it from the sheet feeder. Reload it against the right side, behind the tab, then press in the tab on the edge guide and slide it against the paper. Make sure the paper is not above the arrow mark inside the edge guide.
  • If multiple pages feed at once, remove the paper from the sheet feeder, fan the edges to separate the sheets, then reload it.
  • If the paper doesn't eject fully, you may have set the wrong paper size. Press the c:\users\home\appdata\local\temp\msohtmlclip1\01\clip_image001.gif Stop button, then open the scanner and remove the paper. Select the correct paper size when you reprint.
  • If it's wrinkled when it ejects, the paper may be damp or too thin. Load new paper.
  • Make sure you use new, smooth, high-quality paper, that is not curled, creased, old, or too thin. Make sure to load it printable side up.
  • Do not load paper with holes punched in it for insertion in a binder.
  • Make sure you load only up to the recommended number of sheets. If you're printing on both sides of the paper, try loading fewer sheets.
Paper type
Load up to
this many sheets
Plain paper
Approximately 120
Epson Bright White Paper
Epson Presentation Paper Matte
80
Epson Photo Paper Glossy
Epson Premium Photo Paper Glossy
Epson Ultra Premium Photo Paper Glossy
Epson Premium Photo Paper Semi-gloss
20
Epson Premium Presentation Paper Matte
Epson Premium Presentation Paper Matte Double-Sided
Epson Photo Quality Self-Adhesive Sheets
Epson Iron-On Cool Peel Transfer Paper
If the paper jams, do the following:
1. Gently pull any jammed paper out from the output tray or sheet feeder.
2. To eject the jammed paper, try turning the Epson Stylus NX400 off and then back on.
If that doesn't work and paper is stuck inside, turn off the Epson Stylus NX400. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus NX400 back on.
Aug 17, 2012 | Epson Stylus NX400 InkJet Printer
My Epson TX 121 Printer Wont power on
is it plugged it properly? what happened to the printer the last time it turned on?
dell printers
Oct 26, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Epsom tx110 wont feed paper
Hi!
Try to check for any obstruction. Fan the paper as well on the paper tray. Closely check the mechanism as well when it acts like grabbing the paper. If all fails. Call Epson for a replacement.
Hope this helps.
Oct 12, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Printing files in a tilted manner.
paper feeder is not feeding the paper properly. it "eats" the paper on one side first thats why it prints tilted. clean the paper rollers and see if it still persist canon e40
Aug 31, 2011 | Epson Stylus Multifunction Inkjet Printer/...
I have a new Epson Stylus SX115 and I find it impossible to load paper into it
To remove your problem follow the simple tecnique.
1. Open paper feeder.
2. In the paper feeder you will see a white feed roller gide.
3. Remove the roll gide from paper feeder.
4. In the center of the roll gide you may see a spring inside it. Remove it and set all the parts of the printer again. I think you will be relive from your problem.
Thank you.
Sep 15, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Printer won't print with Hahnemuhle 300gsm papers.
Brand new printer feed up to 350 gsm paper. Rubber paper paper pick up deterioration. Replace paper feeder. Or find similar solution (repairing paper feeder) on aicaxz's for resolving this.
Feb 02, 2010 | Epson Stylus Photo R220 InkJet Printer
Espon stilus dx7450. doesn't switch on, how can
im trying to install my epson printer scanner have no disc can you help
Dec 31, 2009 | Epson Office Equipment & Supplies
Whats going on with my printer
Replace paper feeder. Or find at aicaxz solutions about fixing paper jam without replacing.
Sep 17, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Epson Sx200- Paper wont feed
Just a thought,as I had a similar problem.The instructions are abysmal,but it may be worth having a look where you feed the paper in and squeezing the grey plastic gizmo,and moving it to the left to allow the paper to enter the feed properly.
Dec 26, 2008 | Epson Stylus Multifunction Inkjet Printer/...
Epson Stylus C88 InkJet Photo Printer Logo
230 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
