Question about Kenmore 23822 Top Load Washer
Kenmore 90 Series is NOT DRAINING or AGITATING
Spontaneously quit draining! I went to put my laundry in the drier because the cycle had ended and I found a soggy mess! We emptied out the load and syphoned the rest of the water out of the basket. Upon further inspection, the washer has also stopped agitating.
-thanks
    Problem Solver:
  • 7 Answers
Motor to transmission coupling or transmission itself.
Posted on Jul 02, 2009
Kenmore 90 series washer won't drain and go to spin cycle
Take the power plug off the wall. Be prepared for a lot of water before attempting the following. It doesn't spin because the unit is not draining water. It will not spin with water in it - must drain first. Check drain hose for kink,check exit pipe for blockage. Remove the front access panel, bottom front, screws beneath; if you find a pipe there with a cap -this is for draining water. Could be your "coin trap assembly" is blocked, therefore not allowing all the water to pump out. Remove the clamp (or unscrew) that connects the trap assembly to the pump and clean it out.
If helped pl say so.
Apr 02, 2013 | Kenmore 15864/15862 Top Load Washer
We have a kenmore he2 plus. I put in a load Of laundry and when I came back to put laundry in dryer, washer has no power and the door is locked. How can I get the door open and fix the washer
Maybe the filter is clogged and not draining the water. Have you tried cleaning the filter?
Various control lock features on differing models:
Press the end of cycle signal button for 3 seconds
OR
To reset press the DRAIN/SPIN button and hold it for 15 seconds.
OR
Press and hold the END OF CYCLE button for 15 seconds to reset the control.
OR
Press options and select for 10 secs till LOC is no longer displayed
OR
Unplug washer
Remove lower kick panel
Reach up and locate bottom of door lock switch
Grab the teardrop shaped tab
Pull gently till yall hear a click
The door will be opened
How to video
Sep 09, 2011 | Kenmore Washing Machines
Hello I have a Maytag Washer Model A512 The machine goes through a regular cycle OK - However, it DOES drains the water out during the rinse cycle, but does NOT drain the water out during the spin...
The timer will always advance to the next program if the machine does not fully drain. There is ALWAYS a spin when draining the water out, there is only one pump and one motor. The waterlogged laundry maybe telling the timer that there is still water in the tub. Put the machine on "Spin" and cheat the lid switch into thinking that the lid is closed. Use a clothes peg or wide ended screwdriver and see if there really is a spin....
Apr 07, 2017 | Maytag Neptune MAH5500B Front Load Washer
Kenmore Heavy Duty Series 70 washing machine gets stuck in cycle.
Either your timing motor has broken or the gears that it drives are stripped. The timing motor is easy to replace but if the gears are stripped you will need a whole new dial assembly.
May 09, 2017 | Kenmore Washing Machines
Kenmore 90 series washer. As the tub tries to
It sounds like you have a bad timer. If you change the position of the timer and it does not change what is going on the the timer has to be bad. However I am not certain what you mean by the agitator turns all the time. Is it agitating while spinning and draining?
Apr 15, 2010 | Kenmore Washing Machines
My kenmore 90 series filled with water and went it got to the rinse cycle it quit working and just started making a grindling sound. help please
sounds like the motor coupler broke. it's a plastic piece near the motor and very easy to replace.
here'e a video you can watch to make it easier:
http://www.youtube.com/watch?v=nM4DW2bq7o0
Jan 21, 2010 | Kenmore 22422 Top Load Washer
90 Series Kenmore Washer Not going to spin cycle not draining water
I've had the same problem...you can purchase a replacement lid switch at your local appliance parts store for about $35. Fortunatly, the sales person at the appliance store had diagrams and provided instructions to replace the switch. I was able to finish the job and fix the switch in less than 1 hour. Good Luck.
Oct 25, 2008 | Kenmore 15864/15862 Top Load Washer
Kenmore 80 series washer stopped during unbalanced spin cycle
lid switch is broke lever probley broke off or screw holes broke out due to off balance load forcing tub over against switch lever
Apr 29, 2008 | Kenmore 20172 Top Load Washer
Intermittent spin cycle on Kenmore 90 Series washer
You may try the speed selection switch.....Ive had problems with these.
Jan 23, 2008 | Washing Machines
Kenmore Washing Machine 70 series
You most likely have a broken coupler between the motor and gearcase.
You can buy the part for about $10 or have someone come out and replace it for about $150-200.
If you will post the complete model number from the the washer so I can see which style cabinet you have, I will try to walk you through the repair. It isn't very complicated if you are handy with home repairs.
With the age of the machine it probably just needs a coupler, but it could also have a problem in the transmission or basket drive that has caused the failure.
Nov 13, 2007 | Kenmore 22422 Top Load Washer
Kenmore 23822 Top Load Washer Logo
181 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
