Question about IBM Wheelwriter 30 Typewriter
IBM Selectric II typewriter stuck in correcting position
My IBM Selectric II typewriter seems stuck in the correcting position. Correction key, backspace, tab and return all work. Space key does not. Regular keys raise the correction tape and type clear, then type dark but stay stationary as though correcting. Thanks for any suggestions.
  • IBM Master
  • 3,594 Answers
If you know how to remove the right dust cover (black inside the T/W below the carrier) next to the R. side frame is the correction set up mech. spray some WD40 on the arms especially where they pivot, they should free up.
DickyO
Posted on Jul 02, 2009
HOW DO I INSTALL THE CORRECTION TAPE? CAN'T GET IT TO CORRECT TYPING.
Theres a manual here that should tell you everything you need to know.
Dec 05, 2014 | IBM Correcting Selectric III Electric...
I have a couple of IBM Selectric II Typewriters and over the last few months both just quit as if they are getting no power. One started working again but then quit again..any ideas on how to fix. Also had...
Most selectrics at this time are suffering from many gummy parts.
All of these problems are probably repairable with a good chemical cleaning and lube.
DickyO
Dec 11, 2009 | IBM Office Equipment & Supplies
IBM selectric II carriage stuck in right margin
There is a thin metal ribbon in the back that has come off the wheel. It is a devel of a thing to get back on.
Remove the cover and watch ... you will see what I am talking about.
It may have come un-attached ... equally difficult to fix without the little thingie the typewirter mechanic uses.
good luck
Oct 14, 2009 | Office Equipment & Supplies
My IBM selectric II typewriter carriage stuck in right margin
Sounds like the return lever arm is not putting enough pressure on the return clutch, or the clutch is slipping. The exp key uses the same clutch but the pressure comes from your finger. Theres no way you can fix this yourself. Get an IBM mechanic.
Oct 14, 2009 | Lexmark Wheelwriter 15 Series II...
I have a IBM Correcting Selectric II and I'm having trouble clearing out the margins. Can you help?
space to the right side of the machine, hold down the tab clear key and hit return.
If the carriage stops partway back, one of the tab stops has rotated too far on the tab bar.
remove the platen and paper pan, go to the stuck stop, rotate it to the rear of the machine to line up with the other tabs
Jul 16, 2009 | Nakajima AE-710 Typewriter
IBM Correcting Selectric II; correction ribbon frozen in front of typing ribbon.
Move the grey lever on the R. side of the carrier to the R. and remove correction tape, try the machine, if it seems to work OK install a new correction tape.
DickyO
May 28, 2009 | IBM Wheelwriter 30 Typewriter
IBM Correcting Selectric II backspace not working
The tab tensioner is probably broken you need a tech.
DickyO
Mar 17, 2009 | IBM Wheelwriter 30 Typewriter
Changing typewriter ribbon in the IBM Selectric
You haven't told what model of Selectric. If it is a selectric II or III, there is an orange lever on the carrier that you must pull to one side. The correction tape has a silver lever next to the take-up spool that you must pull outward.
Mar 11, 2009 | Office Equipment & Supplies
IBM Wheelwriter 30 Typewriter Logo
377 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
