Question about Hitachi 53UWX10B 53" Rear Projection Television
53UWX10B have a digital tuner or converter box needed w/o cable
Do I need a converter box or just an antenna for standard digital TV channels
  • 10,515 Answers
You need converter box.
Thanks.
Posted on Jul 02, 2009
I have serial #107611268,model # f27668,classic #ctc203aas..i need to change from cable to antennae and can nit get any channels to list
This is an analog tuner tv,there are no OTA analog tv transmissions you need a digital converter box btween your antenna & tv
Aug 02, 2013 | RCA Televison & Video
Is the PT50LC13 a digital TV? I didn't buy a converter box thinking that the TV didn't need one, but over time and unable to see any channel even with one, I wonder if the TV is indeed digital or not. I...
This tv only has an analog tuner (NTSC). That is why it works with cable and dvds. You will need a converter box to view OTA signals. (In addition, digital signals have a firm cut-off of signal strength; if the tuner doesn't get enough signal the channel will not be available.) So check with antennaweb.org or tvfool.com for details on the antenna direction for your area channels. antennaweb is very conservative in the channel listing it provides (even with the assumption of an external antenna). tvfool gives the color specifications of the antenna that should receive a given set of channels in your area.
The converter boxes are still available from select vendors but the government coupons program is not. Here's one that is listed as in stock: http://www.radioshack.com/product/index.jsp?productId=3150939&CAWELAID=198809366 . This is one of the standard definition output boxes. High Definition digital to analog converters also exist but are more expensive.
A cheap alternative may be to use a PC TV tuner (either USB or internal card) attached to the antenna and then output to the TV. This TV has a VGA port. (If you want to use component video in on the TV, you will need to check if your video card will support the non-RGB signal or a converter box for that.)
I wish that I could be of more help.
(many shows are available online either from the networks or from hulu.com)
Oct 11, 2010 | Panasonic PT-50LC13 50" Rear Projection...
How do i tune in my digital cable on my analog tv?
You'll need a digital cable box for that, I'm afraid. The analog tuner in the set isn't compatible with the digital cable signal. The cable company in my city just dropped their analog service. Now you either need a digital converter box, or a "cable box lite" called a digital transport adapter. For digital off-the-air broadcasting you need a digital tuner and probably an amplified or outdoor antenna. The analog TV is rapidly becoming pretty useless except as a display device as analog channels disappear.
Mar 11, 2010 | Curtis-Mathis CM19011 TV
I have a LC26DA5U Sharp T.V. This is only 4 years old. Will I need a digital Box to get the new digital antenna channels
This unit does not have ATSC tuner , so you will need to use converter or digital cable box.
Nov 09, 2009 | Sharp Televison & Video
Getting alot of "no signal"
You will need a digital antenna for reception. You do not need a converter box for your tv. I have a digital antenna and get a bunch of channels in.
Apr 05, 2009 | iLO IWT3206 TV
Can I receive a digital signal and if so, how?
I'm pretty sure this TV already has an NTSC/ATSC/QAM tuner in there, and should need no converter box whatsover... I say this because I own one...
Mar 09, 2009 | Insignia NS-27 TV TV
Determining if TV has a digital tuner
No! this TV will need a converter box!
Please rate my quick response!
thank you!
Jan 13, 2009 | Televison & Video
PROBLEM WITH GETTING LOCAL hd CHANNELS
You need to have a set top box.
By law, as of March 1, 2007, almost all televisions should include a built-in tuner (called HDTV, digital, or ATSC tuners) that can receive high-definition programs over the air by simply connecting an antenna. Your HDTV doesn't have such a tuner, you'll need to connect an external tuner (or cable or satellite box) to watch high-definition programming. External over-the-air HDTV tuners currently cost at least $150.
Nov 14, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Can't tell if we need converter box for a Panasonic TV CT 27SC14J
this tv does not have a digital tuner. so, if you used an antenna to get off air channels, you would need a converter box. however, if you have cable or a satellite dish you will not need anything.
Oct 15, 2008 | Panasonic CT-27SC14 27" TV
Channels are not available on phillips tv
HI
CHANGE YOUR TV TUNER CHIP.
ALSO PUT REMOTE CONROL CHIP AND NEW REMOTE .
Mar 24, 2008 | Philips TV Tuner Video Capture PCI Card -...
Open Questions:
See all Hitachi 53UWX10B 53" Rear Projection Television Questions
Hitachi 53UWX10B 53" Rear Projection Television Logo
159 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
