Question about Hotpoint HTS16HBR Top Freezer Refrigerator
My refrigerators ha water under teh freezer, has a continously leack
  • 4,070 Answers
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help. Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Posted on Jul 02, 2009
    Sergeant:
  • 163 Answers
I suggest the supply line for the ice maker is leaking.
Tip
Refrigerator not gettin cold but freezer is good
ok if you have a refrigerator that leaks from the freezer into the frige all you have to do is put all the food in an ice chest turn it off or better yet unplug it for no less than three hours then clean up the mess you just made on the floor and dont forget the standing water under the veggie drawers plug it back in and turn the thermostat setting to 3 and dont forget get your food back out the ice chest and put it back in frige grab a beer and relax cuz your done ha
on Feb 24, 2010 | Refrigerators
Amana refrigirator bottom freezer moderl ARB 2214CW it leacks water on the bottom onto the floor it pudles in small amounts all the time at first I thought I spilled somthing.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 31, 2010 | Amana ARB2217C Bottom Freezer Refrigerator
Water dripping from freezer into refrigerator
Just fixed my refrigerator last week that was doing the same thing. Water was dripping from the back top of the refrigerator and it was the drainage line in the freezer had frozen up and was plugged. Emptied the freezer and removed the bottom panel from the freezer and found large layer of ice. Turned freezer off and let everything melt. Then the hole in the back bottom of the freezer on the metal tray became visable. Contined to thaw until warm water would drain into the tray under the freezer. Was not hard at all and much better not cleaning up the water dripping all the time.
Jun 07, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
Leak in the freezer
I understand that is a freon leack beacause is not cooling.if the leack is in a copper pipe you can bras it and fix it but if in the aluminum coil you better get a new coil, beacause to weld a leack in an aluminun pipe it could be much more expensive than a brand new freezer.
Apr 21, 2009 | Kenmore Refrigerators
No ice or slow ice
The more "frozen items" in the freezer, the less of an impact the introduction of a non-frozen item (water in ice maker) will have. Hence a freezer full of frozen item will freeze water faster than a empty freezer but the difference would be negligible.
clarkco
Mar 05, 2009 | GALAXY Microsystems 25.4 cu. ft....
Water leaking from freezer down back wall inside fridge
Defrost water from a top freezer models exits the cabinet in the rear. This drain line may be plugged.
May 07, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Leak
Is there ice build up under the bottom basket in the freezer??
sounds like the defrost drain is frozen up. especially since your cleaning up once or twice a day. simply defrost the drain and flush the drain line with warm water. you will likely have to remove the freezer cover inside the freezer compartment to do this.
if there is no ice build up under the baskets then its likely there is a leak in the water line for your water dispenser line that runs in the door. if thats teh case you will most likely need a service company to fix it for you..
Dec 19, 2007 | Admiral 26 cu. ft. Side-By-Side...
Hotpoint HTS16HBR Top Freezer Refrigerator Logo
163 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
