Tromm Washing Machine small leak
I have a Tromm front loader, and have recently been having a small amount of water that seems to come from the back right corner. Thoughts?
    Problem Solver:
  • 7 Answers
Front load washers will always have some water in them. if, it leaking out, you may either have a bad seal, these are double drums, you may have a leak at the discharge house coupling at washer
Posted on Jul 02, 2009
How do I open to remove the water on an LG tromm front load washing machine to repair/replace the pump?
LG machines normally have a small diameter rubber pipe folded up in the drain pump basket area on the lower left side of the front panel.
Pull out the pipe and remove the small plastic end stopper to allow the water in the tub to drain.
Sep 20, 2014 | LG Washing Machines
My LG front loader is showing an "FE" error. The water seems to continue running into the tub, leaking out the door.
Good morning
I looked this up to make sure I was thinking the right way. The FE means there is too much water in the machine... lol bet you already knew that. Since water is actually coming out of the machine it looks like a bad fill valve. The plastic piece your hot and cold water lines hook into is not shutting off all the way.
I hope this helps
Nov 27, 2012 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
I have an lg wm1814cw front loader with a ue code
Probably the pump filter is blocked.Make sure the machine is empty...Access filter via small door at floor level. Unscrew the filter cap, and clean filter. check that there isn't a coin stopping the impeller vanes. ...When you take the cap off, any water left in machine will flow out!! Leaning the machine back can help.....Good luck...Nomess
May 16, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG Tromm WM0642HW washer leaking water!
I have the same problem - just a small amount of water leaking out from under the machine. I removed the top cover and found one of the water lines rubs on the vent tube and has wore completely through. Should be an easy fix, as the line runs from the #2 spigot on the water inlet to the detergent box - both connections are right on top.
Nov 02, 2008 | Washing Machines
LG Top Loader WF-T8108TP - NOT SPINNING
unplug the machine take the back off and look for a small pipe 5mm going upwards, take it off and blow gently into it you should hear a click and one when you let the air out if so then the place you took the pipe from is blocked clean out the pipe with a pipe cleaner or metal rod replace the 5mm pipe put the back on retry the machine eric
Jan 11, 2018 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG Tromm 8/4 WD R8012
The manual suggests to shut the water off ,
remove the inlet hose and check the screen for blockage.
The ie message is the inlet water is insufficient.
May 22, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
TROMM ultra capacity washer water levels
these machines are mean on water and you can open the door after wash starts
use good quality soap powder that suits front loaders and always wash at 40 deg or above
the black stuff is body fat that is still in machine called scud to me
also if you use conditioner in rinse cycle stop using that
it can cause same problem
Jan 28, 2008 | LG WM-1832C Front Load Washer
Front loader washing machine = black streaks on clothing
I am a recently retired engineer of 20 years once you have ruled out anything getting inside the machine by accident etc, like something in pockets or greasy overalls, then its likely to be the drum bearings, has the machine started to get noisy on the spin the drum bearings are covered by a rubber seal, this seal gets damaged or worn and water leaks into the bearings themselves washing out the grease back into the drum where the washing is, you could also notice slight water marks on the floor underneath the machine on the floor, take the back off and look for water marks coming from the drum outer casing behind the pulley, these marks will be brown and will originate from a small drain hole, if any of the above change the bearings before any real damage is done, either to the clothes or the machine, as repair can be expensive? sorry, hope i have helped you as to where to look at least,
Sep 18, 2007 | Kenmore 46462 Front Load Washer
Washing Machines Logo
101 people viewed this question
Top Washing Machines Experts
