Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Green Blinking Light WD-52525
I am amazed at all of the same problems with a WD-52525. I purchased this unit on Jan 02, 2005 for over $3000. So far I have replace the $229.00 bulb from Mitsubishi four times. On Jan 24, 2008 it failed and I had a repair service take to their shop and replace the SM Power Supply for $600. I am at the point where I do not want to sink anymore money into this. I think this is a total disgrace of quality by Mitsubishi. This is not a $500 TV. They need to own up to thier quality issues. Has anyone looked into a class action lawsuit?
  • zeebrew Jul 02, 2009
    Thanks for your reply. The TV has at least 10" all around the sides and back. Would this not be enough air flow? Plus when it blew yesterday it made this awfull sound for about 15 seconds. Could the lamp make that noise when blowing out?
I have replaced the projection bulb in the unit and on reassembly and power plug in the green flashing lite continues.I have pressed the reset but tlet goes out for 1 second the begins to flash again1q1
Posted on Jul 12, 2009
    Champion:
  • 205 Answers
Is it possible your having poor air movement around the set. If lamp is frequently blowing it sounds like over heating. Sorry your having troubles. That tv offers a fine picture.
Posted on Jul 02, 2009
Blinking green light
If you own the model WD-52525 it and the sets made around the same time are all junk----falling apart as we speak and nothing seems to help make a good repair on them.
Blinking green light is called "blinking light of death" and I did not coin that phrase but it is accurate. The green light up front that blinks is the Digital unit in the set trying to boot up----one of the many nasty problems this set can have.
Not fixable in the home and in my view not economical to repair for any reason---if you want to see some of the other issues this set has Google the model number with "problems" and be prepared to read for a while.
May 01, 2012 | Mitsubishi WD-52525 52" Rear Projection...
Blinking Green Light on Mitsubishi DLP 52525
the circut that detects the bulb has been also failing in these sets
and the conversion chip that controls the picture , and the transformers are not putting out the full power they are supposed to.
this set will need to be tested to determine the exact cause or causes
Oct 18, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 with blinking green light problem
The #3 post worked for me. I first just did the capacitors and it did not work at first, but I got it reset. It worked for 2 months and lost power the other day in a storm and the blinking light came again and would not reset. I put in the switch and followed his directions and it work perfectly. Sweeet. The switch was easy. The capacitors were not hard, but very detail oriented. I work on copiers for a living, so I am used to taking things apart and back together. You must be able to solder and reassemble pretty well, or I would hire someone to do it.
Sep 16, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52 in DLP.
You most likely need the V26 DM repair kit at the following link, that usually repairs the blinking led problem.
http://servicemanuals.vstore.ca/
Nov 24, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Replace the 1000uf capacitors on the DM board. thats whats causiong the problem. If you need further help go to this link they have your service manual available for emailing after purchase and that will entitle you for free tech support and one of their techs can fix those sets in his sleep he will walk you through the repair which parts are only about 20 dollars to fix the problem.
May 07, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mit 52525 from blinking green light to still green light.
bad capacitors 1000uf on the PWB, FMT and DM boards will cause those symptoms. All capacitors 9 in all need to be replaced
May 06, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 Status Light --- blinking red constantly.
possible that over night your set took a power surge ,possible power supply fault.
Sep 12, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
273 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
